Question about Refrigerators
I have a little hole in the water hose in the back of my fridge. When you go to get water or the fridge fills with water to make ice the the hose sprays water from the hole in the hose. Is there a repair kit I can use to fill the hole or do I need to buy a new hose. If I need to repair the hose is it easy to fix?
    Problem Solver:
  • 14 Answers
You need a new hose, as yours is worn out from age. Hardware stores usually have tubing for such repairs. Turn off the water supply, unclamp the hose from both ends. Take the dead hose to the hardware store to match it up. Get two new clamps, too. Then replace the hose. A fairly easy job.
Posted on Mar 21, 2011
Puddle on floor
dear Damian sounds like the drain from the freezer is clogged you need to unclogg it and make sure the water flows through. Now if its not visible you need to unplug the fridge take out the shelves and unscrew the back panel.Then at the bottom of the evaporator (the winding pipes ) there should be a block of ice which needs to be defrosted until you see the drain hole that must also be free of ice and that will be the hardest part. To unclogg the ice from the hole you will need some hot water to pour into the hole let it melt a bit then sponge it out and repeat process until the water flows directly through. hope this helps good luck. regards Tony
Dec 12, 2011 | LG LSC26905TT Side by Side Refrigerator
Amana Fridge isn't filling the ice tray with water...=/
it seems to me (no expert) that you have an ice buildup in the tubing to the freezing portion of that unit. I can only suggest to turn off the Refrigerator for a little while, an hour or two at most, and see if the tubing thaws.
Aug 30, 2009 | KitchenAid (KSRD22FKST) Side by Side...
The refrigerator is dripping water at the bottom of the fridge. Everyday we walk by the fridge and see lots of water dripping from the fridge.
Hi, The defrost drain is plugged. Remove the rear panel inside the freezer section and locate the drain hole. Remove all the ice and flush the drain out with hot water to make sure it is open. Some models require an after market drain heater kit. If you will get me a model 3, I can look this up and let you know if you need the kit.
Vic
Jul 04, 2009 | Refrigerators
The icemaker leaks water from the fill tube into the fridge
my suggestion is to start from the beginning! shut down the fridge for a couple of days store food somewhere else (obviously and see if you get much water at bottom. have mos and bucket nearby. blow into any hoses that are accessible. unplug fridge of course.
Mar 18, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Amana ARB8057CSR Bottom Freezer Ice Maker Arm is broken & stuck
If water still continues going to the Ice Maker unplug the pair of wires on the back of the refrigerator that send water up to the ice maker. Now I see I am a little late answering your post, because I just happened to run across it. I was not here when you first posted the problem. Just let me know if you still need help, Thanks Sea Breeze
seabreezehvac@yahoo.com
Dec 18, 2008 | Amana ARB8057CSR Bottom Freezer...
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerator
The drain line that removes water after the defrost cycle is plugged. Instead of draining down the hose and ending up in the pan underneath the fridge, it is draining to the back on the inside, ending up under the drawers. Pull the pan out from the bottom, locate the hose that empties water there. Blow air up it. Compressed works the best. It may be plugged with ice as well, so turn it off for a little before you try this, to thaw the ice. If this doesn't work or you cant do it, then you need to remove the back panel in the freezer compartment, find the drain hole and stick something in it, like a piece of wire to remove the blockage. A good way to test this, is after you have found the drain hole, pour a little water in it, it should pour out into the pan underneath.
Dec 26, 2007 | LG LFC25760 French Door Refrigerator
Water in bottom of fridge
THE DRIAN HOLE IS CLOGGED ITS IN FREZZOR IN THE BACK BEHIND THE BACK PANEL BUT YOU CAN LOOK UNDER THE FRIDGE AND FIND THE OTHER END OF THE DRIAN HOSE BLOW AIR TROUGH IT TO CLEAN IT OUT MAKE SURE THE FRIDG IS OFF FOR A DAY, OPEN FREEZOR DOOR TO MELT ICE IN DRIAN HOLE AND HOSE AIR PRESSOR MAY NOT BLOW THE ICE BLOCKAGE OUT DEFROST FOR A DAY THEN IT WILL CLEAN UP NICE
Aug 29, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
131 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
