Question about Poulan 14" Chainsaw
You adequately described the problem. The vent hole in the fuel tank (Poulan 2800 chain saw) no longer has a one-way valve. Thus, fuel leaks when trying to use the saw. Your solution was to replace with a new valve. Problem: None is listed in the Operator's Manual. (1) Where do I get a part number, and (2) who do I order it from? Is there temproary fix I can install to use the saw until I get the new valve? Thanks, Ted
  • Logan Islas
    Logan Islas Oct 05, 2015
    My solution is to take 1/8 inch fuel like. This will fit perfectly in the hole if the rubber stopper is there. Next find a wood screw that is just oversized to the inside diameter of the fuel line. Attempt to screw this in the line, if it doesn't go easy find a smaller screw. Do not screw all the way in so that air can still pass through the screw threads. If done correctly fuel is guaranteed to not pass.
    Sergeant:
  • 344 Answers
530010845
This is the part number for the fuel cap... if it says obsolete, you can find it, just Google this part number, there are tons of vendors. This will get ya going.
Posted on Oct 05, 2015
  • 604 Answers
Cut a small piece of rubber the size of the inside of the cap. buy some fuel proof glue and glue one side down inside the cap (clean the cap very well first and make sure it is dry). this is not a perfect solution, but will allow the tank to breath withouth spilling much gas.
Posted on Mar 22, 2011
Setting carb
The fuel tank vent is built into the body of the saw. There is a plug cover of the fuel tank vent valve adjustment shaft just in front of the saws handle on the right chain drive side of the saw. Seek a professional.
Nov 17, 2013 | Husqvarna 288 Kill Switch Wire Chainsaw...
Chain saw runs for about 15 seconds then dies
Hi chamby12, without having any more info like, did this happen over time or was there something else that happened before this problem, etc.? The only thing that comes to mind with that specific problem is with the fuel tank venting. As fuel is removed from the tank air has to be able to replace it without fuel leaking out. This is usually accomplished by a one way valve on the cap of the tank. The valve that is there is called a duckbill valve because of the way it looks. Inspect the cap and look for dirt or debris also if it is able to open and close. Some other makes of chain saws that use that type of valve install it on the tank itself. I hope this helps you a bit. All the best and good luck.
Feb 16, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Started reving very fast wont idle ;was the correct fuel mix was cutting on side ie not down
Check your all of fuel lines for cracks / air leaks especially near any fittings. Also check the primer bulb (if installed) for any pin holes. The symptom you describe is either caused by fuel starvation or the introduction of air into the fuel system. Also check inside the gas tank looking at the fuel pick up tube END / strainer for debris. Make sure that the gas cap remains vented. If some one has placed plastic over the fuel tank fill hole and then the gas cap it will perform as you stated. This model also has a mini fuel filter that can be clogged causing fuel starvation.
See this link:
http://www.ereplacementparts.com/poulan-p3314-type-gas-chainsaw-parts-c-16962_17147_17782.html
In DETAIL A
There is a fuel line item A7 and a tank purge device item A6 that is often where the air leak presents itself.
in DETAIL B
The primer bulb item B14 and the purge line B13 are also a major source of air introduction.
Once you get the feul system sealed again by repair of the fuel lines or replacement of the primer bulb you should be back in the wood cutting business again WITHOUT making carb aadjustments.
Thanks for choosing FixYa,
Kelly
Jan 05, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Hi have fuel coming out of muffler and was blowing out of breather
This saw has a fuel tank vent that could be leaking a small amount of fuel, or the fuel line coming out of the tank could be leaking. Fuel line replacement isn't complicated, you could try installing a new one. If it's the vent, odds are it's not enough to cause alarm........unless the vent line is cracked. In that event, you should replace the vent hose. Again, not a complicated repair.
Nov 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan wild thing 18" Won't Start, Plug is wet
Check the air cleaner and muffler for plugging. Remove the carburetor, open the lower chamber and check the diaphragm for any holes or cracking. Also check the small fuel control valve that the diaphragm controls--either can cause flooding if not working properly. Hope this helps!
May 31, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Bar oil leaks into storage case when chainsaw not in use???? Poulan Prow, PP4620 AVX 46 cc
The easy fix is to drain the oil tank when not in use. Many saws will leak some oil initially, but should not continue to do so. If it is making a large puddle, oil is getting past the oil pump which may be worn from long use. Make sure the tank vent is not plugged as heat from the engine can increase pressure in the tank thus forcing oil out. Hope this helps!
Mar 27, 2010 | Poulan Pro Chain Saw 46cc 20"
My chain saw is building pressure in the fuel tank!?
Yes, that is a normal occurance, however, all saws have to have a way to relieve that pressure. Many tanks have vents on top, others have fuel caps that vent. Both should be inspected for being plugged with saw dust, or rubber components that have become damaged over time.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 13, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain saw run s for a short time and stops
The engine is unable to draw adequate fuel from the tank on a continuous basis, the filter may be clogged or there is an air leak in the fuel line between the fuel tank and the carburetor.
May 26, 2009 | Poulan Garden
Poulan 14" chainsaw, fuel coming out of fuel cap vent
The fuel cap has a rubber check valve in the top. This check valve allows air to enter the tank so fuel can flow. Much like the vent on your gas can. Sounds like the check valve in the cap is stiffening and not flexing. Best bet is to buy a new cap. Most caps like that sell for less than $3.
Feb 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulon Wildthing 18" Gas Chain Saw
Some Poulans vent thru a fuel line going from the tank to the carburetor. Some vent thru the cap but eventually the duck bill valve starts leaking fuel. Then I suspect some people change that cap to one without a vent, which causes the problem you are describing.
Sep 11, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 14" Chainsaw Logo
258 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
