Question about Dishwashers
I found water on the floor and after inspection I found out that the door seal is broken (rotten). It is the one that is mounted directly on the door. How to replace it without a damage of the door?
    Sergeant:
  • 296 Answers
A heat gun. Alternatively, some sort of small knife, then something to oxidize the residue.
Posted on Mar 21, 2011
Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Jun 14, 2013 | Miele Dishwashers
How can I get to the inside
If your dishwasher is Leaking check the following
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your diswasher
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pump. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. .
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Drain:
This is usually caused by a syphon effect or your drain line improperly installed. You can not attach your drain line from the dishwasher without having a loop in it. If you go directly under the floor with your drain hose, all water will drain out upon fill. Safest and recommended installation of drain hose is to your kitchen sink and attach the hose somewhere so it is higher then the bottom of your sinks.
be65763a-411f-4910-88d8-4712ce0a8d7e.gifda9b96d7-ebd5-4e03-8f4c-4d0c49063e70.gifGod bless you, Use the VOM very important
Apr 05, 2013 | Kenwood Dishwashers
Car leaking
are the doors wet or just the floors?
most likely its the door seals, cracked or broken or just plain old and stiff
could also be window seals
check the seals around the windows and open the door and check the door seals
Mar 30, 2013 | Cars & Trucks
Kenmore elite dishwasher leaking below washer
see this causes and use the common sense. God bless you
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
Dispenser Seal
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Some dishwashers have separate drain and circulating pumps. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
Door Hinges
Sep 19, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
Why is th carpet wet behind the driver seat in my '02 thunderbird
This can be from one of couple sources. One would be a broken or missing rubber seal in the firewall. Water can and will enter the passenger compartment if the seal is not good or missing. The firewall is the metal between the engine compartment and passenger compartment. There are many penetrations in the firewall for throttle linkage, steering column, electrical harness, etc. All of these penetrations have seals to prevent water from entering. Check to make sure all penetrations have seals. Inspect from under hood and from under the car, too.
Another source is damage to the floor pan. If you went over a rock or jagged object without having enough clearance, it may have punctured or even sliced through the floor - under the carpeting and sound deadening material under it. If you live in a cold area, and the roads are treated with salt or chemicals to melt ice, it may have caused rusting holes to appear in the floor pan. Water spraying up from tires would enter through the puncture or slice and the carpet would wick the water in. It would take a long time to dry and give a musty smell after just a short time. You should inspect the floor pan from underneath the car. Look for punctures, slices and rust / rot. Clean and seal any openings found in the floor pan and firewall.
Fixed windows and glass in the car body are also sources for leaks. The is especially true if glass has recently been replaced. Many times, the back window leaks into the trunk or metal under the rear seat - and flows to the carpeted floor. Look in the trunk at the bottom of the rear window. Side windows can leak, too - so don't forget to look behind trim interior panels on the sides of the back seat. Your leak could be coming from the windshield, too - this will be harder to locate through the dashboard - but you may find water dripping from wires, etc. Look for evidence of water / rust. Clean and reseal body / glass joints when found.
Aug 27, 2012 | 2002 Ford Thunderbird
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
2002 suburban has leak in driver side rear floor. Cannot see where water would be coming from?
We had same--water on driver side rear floor (soaked!). Driver side front floor seemed dry until feeling UNDER rug, was slightly damp. We found the location of TWO leaks causing this.
Leak #1 was through the parking brake line/cable seal; Recaulked with silicone. Removed plastic trim on floor between floor and door to reveal metal channel filled with water.
Leak #2 was where the door meets the car, near the hinge. It was the accordian-looking tube housing the wiring for the door. The big, rubber, circular plug connecting it to the main part of the car had come loose and water ran down through that, into the SAME metal channel filled with water from leak #1; will seal with silicone.
Note: We found that the channel filled extensively near the front door, BUT the carpet edge from the floor near the rear seat was dipping into it, wicking it up to the rear floor. Also, upon acceleration, the water in the channel gushed toward the back, thus soaking the rear carpet.
These leaks were found by removing all plastic trim (covering edges of carpet by doors), then one of us pouring water into specific areas of the exterior of the vehicle, and the other one watching closely with a flashlight for any signs of dripping.
Feb 18, 2010 | 2002 Chevrolet Suburban
Front door leaking during washing cycle
There are only two ways that water can leak out this way. it can be either the door seal or the door lock mech has become misaligned, causing a slight gap that is letting the water escape through.
I recommend inspecting the door lock mech for its integrity. make sure it is aligned correctly to specs. replace this mechanism if found to be faulty or misaligned. i would also inspect the seal for tiny ruptures as well. the slightest rupture or hole can allow small amounts of water to excape.
Inspect these areas thouroughly.
May 31, 2009 | Frigidaire Washing Machines
Water standing floor of 1991 corsica
That can be caused by the door or window seals. Around all your doors there is a rubber seal, this seal can degrade and allow water into the interior. There are also seals around the windows and front and rear windshields. If I were you I would visually inspect all the rubber seals on all your doors and windows, if any part of the seals is worn it should be replaced. You can buy universal weatherstripping kits off the shelf at any auto parts store to replace any of yours that are bad and it's pretty easy to install. You can also pick up a tube of silicone sealent to seal any small gaps or cracks in the existing seals.
Hope this helps
Feb 18, 2009 | 1991 Chevrolet Corsica
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
