Question about Samsung Wave S8500 Smartphone
Looked at the timne this morning after being at work a little bit (started at 8pm) thought damn its going slow today looked again a little wile later said the same time 8:21 tryed turning it off wouldnt respond took the battery out and now wont turn on recently its been not allowing me to hear people when making phone calls please help.
    Scholar:
  • 78 Answers
There could be many problems, but none of them can be solved by troubleshooting.
The two most likely issues are water damage, or a hardware/electrical problem caused by damaged internal components.
To determine if there is water damage, open the back panel and remove the battery. Behind where the battery normally rests, or below it, there will be a small circular sticker. If that sticker is white, then it has not been exposed to moisture. If it is any other color then your phone has water damage.
If you cannot find water damage then your phone is either suffering from a damaged hardware. However, in the off chance that your phone is only suffering from a minor error hold down the power button while the phone is not plugged in and there is no battery inserted for about one minute. Then insert the battery and attempt to turn the phone on.
If this doesn't help your only hope is contact your carrier and see if you can get it replaced.
Posted on Mar 21, 2011
    Genius:
  • 1,114 Answers
I would recommend that you reset the device. You can do this by taking the battery out when the handset is powered on, wait 1 minute, and then power the device back up. If this does not resolve the issue, then I would recommend that you contact your wireless provider. The handset should have come with a 1 year manufacturer's warranty, and they can initiate the exchange, it should be free. If that is not an option for you, then I would recommend that you seek a cellular repair shop, they can resolve the issue for a fraction of the cost of a new handset.
Low oil pressure on 08 gmc seirra
With fuel injection if the pressure goes to low the fuel pump will stop and the lifters will get noisy.If you are seeing 10 lbs hot at idle I wouldn't worry to much.
If you have a high mileage vehicle and live in a warm climate,go for 20w50 oil at your next oil change,some use straight 40w oil to help oil pressure on worn engines.
Apr 10, 2017 | GMC Sierra 1500 Cars & Trucks
1990 Plymouth Voyager won't turn over
Last time my van did that it was the alternator failing to recharge the battery.
Sep 26, 2012 | 1990 Plymouth Voyager
Jeeps runs for 2 minutes then shuts down
Hello Marc Miller,
BAFFLED:
I am a bit confused by your remark
"at night after 8pm" but I think I understand.
I have personal experience that FULL-MOON affects
PEOPLE... but the CARS/TRUCKS... Not so much.
My guess is a READ-OUT of your DIAGNOSTIC
TROUBLE CODES
(DTC) would (in the hands of
an accomplished mechanic is going to point out
your issue(s).
Some muffler shops and parts houses provide
these services for FREE...
(just know your options/prices before you go
(see below)).
Other than I personally believe you are
headed HOME (family, hearth & heart) you
probably suffer the torment all day long...
but it really stings when you want to be home...
I doubt any OTHER relevance to "8pm"...
ESPECIALLY since about 70% of this planets'
people just set our clocks forward AN HOUR
only a few weeks ago...
Another thing that has baffles... is your muffler.
Although the exterior MAY look intact...
195,000 miles is not a bad ... I have experienced
your trouble...
When a car runs "sometimes" that eliminates a
TON of considerations... (things that are OK).
Once the code are read... the FIRST MISTAKE
EVERYBODY makes is to change out perfectly
good OXYGEN SENSORS...
They are only upset because your
catalytic converter AND/OR muffler
are LIKELY keeping your EXHAUST from
getting out...
Just a thought...
ROCKAUTO
1997 JEEP CHEROKEE 4 0L L6 Catalytic Converter RockAuto
Carnac the Magnificent
May 09, 2017 | Cars & Trucks
On my 2006 Ram 2500 truck. Last week I hit a bump while traveling about 60 MPH. The front tire started shaking, I thought I had a blow out. When I slowed down to about 30 it all stopped. When I...
A few possibilities.... bent rim, broken steel belt in tire, or a wheel weight that keeps the tire/wheel combination in balance has fallen off. Not sure how big the bump was, so other options would be suspension related. I would check the tire and/or wheel first.
Sep 27, 2010 | 1999 Dodge Ram 2500 4WD
Smoke from steering wheel
Sounds like a small electrical fire of some sort behind the dash
Jun 15, 2009 | 2002 Pontiac Grand Am
Samsung 753s monitor problem
try to check the B+ line voltage. Check the FET and resistors on this line.
Mar 17, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung Wave S8500 Smartphone Logo
164 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
