Question about Kenmore Washing Machines
Kenmore Top Load Washing Machine Mod# 110.26922503.. How to remove timer Knob??
duby1990
  • 370 Answers
SOURCE: how does the timer knob come off
Push the knob to the off position then spin it to the left. it should just screw off. There is only one or two models that dont. To acces the timer you have to take the 2 screws out of the corners of the control panel (philips) They are either on the front or the back of the machine, left and right corners. The whole control panel will pull forward and then lift up and flip back. Theres the timer. Any more questions let me know.
Posted on Nov 21, 2008
WRMtech
  • 70 Answers
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
hiltonjug
  • 612 Answers
SOURCE: Washing machine is Kenmore mod. 110 22422100.
You have a broken point inside the timer. I hate to say that there is no cheap solution. You will have to replace the timer. There is no rebuild kit or anything like that to repair the timer. I know of two suppliers where you can buy a replacement. I use these sometimes when I regular supplier hasn't got a part in stock. I checked the price at both for you and found the best price at www.appliancepartspro.com . their cost if $123.08 plus shipping. They ship same day if before 4:ooPM. Their Part Number: AP3020181 . When you go to their site enter either your model number or this part number. If you enter you model #, scroll down until you find the timer, Th part # will take you straight to it. I sure hope this helps.
Please rate solution
Posted on Sep 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a Kenmore Top load Washer won't drain
You must have a lid switch problem . I have a page I compiled which features lid switch replacement: HERE
Posted on Jan 11, 2010
Testimonial: "you were right thank you very much."
  • 1937 Answers
SOURCE: removeing timer switch knob
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
The knob screws onto a medal shaft that goes through the timer.
Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
Then you simply have to disconnect the timer.
The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
Posted on Jun 08, 2010
How to replace the timer on a Kenmore 90 series washing machine?
The timer on a washing Kenmore washing machine is the brains of the unit. The timer controls how long the clothes are to be washed, rinsed, spun and dried. The timer is located behind the timer knob in the main control panel. If the timer fails, it can be replaced with just a few hand tools.
1 Unplug the washing machine's cord from the electrical outlet.
2 Remove the two screws securing the main-panel end caps with a Phillips-head screwdriver. Lift the main panel up and rotate it backward so the inside of the panel is exposed. If your model does not have end caps, slide a putty knife between the main panel and the washing machine's top, then pry up to free the panel from its retaining clips.
3 Turn the knob by hand from one side while looking at the back of the timer from the other side. You should see the timer knob's shaft turning. Grasp the black plastic locking tab in the center of the timer knob's shaft with a pair of needle-nose pliers and pull it out. You should feel a click.
4 Pull the timer knob off of its shaft. You may need to hold the locking tab with the pliers as you do this. Remove the trim plate from under the knob.
5 Unplug the wiring connector from the back of the timer. Remove the screws securing the timer to the main panel with a nut driver and remove the timer.
6 Install the new timer into the panel and secure it with the screws, using a nut driver. Install the timer's trim plate and wire connector.
7 Install the knob onto the timer's shaft. Make sure the locking tab is still pulled out before installing the knob. Once the knob is pushed onto the shaft, hold the knob with one hand while pushing the locking tab in from the other side. You should feel it click into position.
8 Reinstall the main panel and end caps, if applicable. Plug in the electrical cord and run the washer on various wash and rinse cycles to test that the timer is working.
Things You Will Need
  • Phillips-head screwdriver
  • Putty knife
  • Nut driver
  • Needle-nose pliers
  • Timer
Warning
  • Pulling or installing the timer knob without first pulling the locking tab can break the tab, the shaft or the knob.
Apr 24, 2014 | Kenmore 15944 Top Load Washer
Our kenmore 80 series (110.27812692) pooped out on us,... the motor and water pump needed replaced, so we bought a used kenmore 70 series (110.82872820) from a friend,... it works fine, but the control...
First, see the Sears parts site for your washer(s):
Enter the model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Check the part numbers for both machines in the "Console" section.
Also see the following Whirl[pool Service manual for top load, direct drive washers.
Whirlpool top load, washers use one of two different timers. Depending on the timer the knob comes off differently.
For most, by holding the back of the timer shaft with a thin needle nosed pliers, the knob unscrews.
Sep 13, 2010 | Kenmore Washing Machines
Removeing timer switch knob
Jun 08, 2010 | Kenmore 24032\24036 Top Load Washer
Instructions for installing timer part number 8541110 for Kenmore elite wash machine.....
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Then see the following for how to release the console for access to the timer.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5216f244d51176ce1069bbf148b14335
Then see the following Whirlpool / Kenmore Service Manual for top load, direct drive washers. It has troubleshooting and testing procedures as well as a description of the TWO types of timers. Each has different procedures for replacing them.
If yours is the metal type, the procedures call for unscrewing the timer knob before it can re removed.
You may need to use a thin needle nose pliers to hold the shaft on the back side of the timer in order to unscrew the knob.
May 08, 2010 | Kenmore 24032\24036 Top Load Washer
Removal of timer control knob on model 11025842400
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.25842400
Look at the control panel diagram and you should get a good idea of how the timer mounts.
With the basic top load, direct drive washer you should only need to remove the two screws located under the Trim End Caps to get access to the timer.
Sep 30, 2009 | Kenmore Washing Machines
Removing the Push-to-turn-on knob
if you pull on the knob it will come off it has a metal clip that is pretty snug on the stem but it will come off, you still have to take the cack cover plate off to get to the switch and do the actual replacement
May 29, 2009 | Kenmore 22422 Top Load Washer
How to remove knob from panel
If there is a black tab on the back of the timer, it needs to be pulled out of the timer before you can remove the knob
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washing machine mod.# 11026842692
could be a broken 2nd rinse switch. contacts would not open up.
the noise could be coming from the gears inside the timer slipping.
if it is a kenmore, usually, it has these plastic cover on each side of the control panel. pry it slowly and lift it to exposed a screw that is holding the panel.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Kenmore 24032\24036 Top Load Washer
I can't get the timer switch off
on the inside of the timer switch hold the shaft that the Knob is on with a pair of needle nose pliers and pull the knob from the front. " Gently"
Dec 03, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
66 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
