Question about Olympus FE-190 Digital Camera
Camera won't turn on
My son left it in a backpack in the humidity outside, now it won't turn on. Have charged and recharged battery and ordered a new battery and fully charged that one. Is there a reset button?
My daughter FE-190 just had the same problem. Make sure the little red tab is locked over the battery. Hers now works properly. I think it is possible with this camera to put in a battery and it NOT have good contact.
Hope that helps Brian
Posted on Aug 06, 2008
How can i charge rechargable batteries without usb cable for GE c1433 digital camera
The C1433 is a camera, not a battery charger. It uses standard AA batteries, either disposables or rechargeables. If you choose to use rechargeable batteries, you must charge them outside the camera using a separate battery charger.
Feb 11, 2013 | Cameras
Nikon camera battery keeps losing charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 12, 2012 | Nikon Coolpix S3000 Digital Camera
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
Nov 06, 2012 | Samsung i85 Digital Camera
I cant charge the battery through computer
The C183 isn't a battery charger. If you use rechargeable AA batteries in it, you must charge the batteries outside the camera using a separate battery charger.
Aug 01, 2012 | Kodak C183 Digital Camera
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
Camera turns off itself
This is likely because:
  1. You are using the wrong types of batteries (Alkaline, Ni-Cd or Ni-MH batteries are recommended for digital cameras) NOTE: don't mix different types.
  2. The battery is out of charging cycles and won't retain charge. (Most rechargeable batteries can be charged only about 1000 times after which they won't hold charge)
  3. The batteries aren't 'powerful' enough. (low quality rechargeable batteries with low capacity shouldn't be used on digital cameras, Always buy batteries specialized for cameras (from camera stores or studios))
  4. The wrong battery type is selected in the camera's settings. (Most cameras let you select the type of battery you are using from it's settings. Browse through the settings and see if this is the problem)
Hope that fixed it. Good luck.
Apr 28, 2011 | Nikon COOLPIX L4 Digital Camera
How do i charge my new Kodak easyshare c182
The C182 isn't a battery charger. It uses standard AA batteries, disposable or rechargeable. If you use rechargeable batteries, you must charge them outside the camera using a standard battery charger.
Oct 28, 2010 | Kodak Easyshare C182 12MP Digital Camera
I have a new refurbished kodak easyshare c160 -- the camera will not last but for one or two pictures without completely draining the batteries. i have tried about 4 new sets of photo batteries....is this...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Kodak EasyShare C160 Digital Camera
Why won’t my camera recharge my batteries?
Not all cameras can charge batteries. CAUTION: Rechargeable batteries must never be used in the HP Photosmart 210 and 215 series digital cameras. The overload protection and control circuits are not designed to handle the kind of power intensity delivered by rechargeable batteries. If the camera is a model that does charge batteries, ensure the batteries are rechargeable: The only acceptable rechargeable batteries for HP Photosmart cameras are NiMH cells. Neither lithium nor alkaline cells are rechargeable, and they will not be charged in the camera. The camera must detect the type and condition of the batteries The camera will only charge batteries when it detects the batteries are rechargeable and in good condition. New rechargeable batteries, and/or batteries than have been unused for a long time will not be recognized as good batteries. If the camera fails to charge NiMH batteries, charge them in an external charger once, then use them in the camera. If this does not correct the problem, the cells are old and/or damaged and new cells must be purchased.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Olympus FE-190 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
