Question about Sony KDL32L4000 32 in. LCD HDTV
Loss verttical sync and foldover - Sony KDL32L4000 32 in. LCD HDTV
  • Sony Master
  • 8,457 Answers
Ur tv have a bad tv Tuner signal board.That the board,where the tv imcomming broadcasting signal cable plug into it.U can take things aparts and putting back again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole tv Tuner signal board for a replacement.
Posted on Mar 21, 2011
DS 27880. Foldover Problem on Statrup. Is capacitor replacement not a logical fix as I have repaired many TV,S with foldover with Cap Replacement?
I would check for low value capacitors in the power supply if an LCD or a tubed TV check flyback capacitor.
Jul 24, 2017 | Televison & Video
How to fix my mwo 04 nano mouse when it won't sync?
We'll you could take it back or go on the web site and ask for support
May 19, 2014 | Belkin F8E825 USB Mini Wireless Optical...
Loss sync
The T con board is defective. That board has a metal cover on it and 2 wide flat ribbon cables going to the bottom of the screen. Replace that board and you'll have a perfect picture again.
Dec 24, 2013 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Bottom foldover on telefunken lcd tv model number TLCD 32FHDUA
Check all strip wire connections to panel to T'Con board for any loose contact.
Mar 01, 2013 | Televison & Video
No vertical deflection-need schematic
follow the 2 sets of wires off the yoke. one goes to the horizontal sweep section and the other goes to the vertical. the drive ic with the metal tab is blown.that is what drives the vertical deflection. there is a few capacitors there. 1mf at 160v and .47 at 160 and 2.2mf at 50v on most sylvania sets . if the plastic on the top of the capacitor is shrunk,it is getting hot and is no good.that can cause a loss of sweep or foldover.99% of the time it is the vertical output ic that is gone.
Oct 28, 2010 | Sylvania Televison & Video
Need help syncing to IPhone
Just load your iTune library with items with you wants to sync. The connect your iphone & click on Sync button on iphone. Then syncing will start. If you enabled automatic syncing then your iphone will automatically sync while you connects to iTune.
( Note: Do not disonnect your iphone while syncing in progress it will reason for data loss.)
Thanks.
Happy to help you.
Sep 26, 2009 | Palm Zire 31 Handheld
I have vertical shifted up from bottom and foldover from top down
This is caused by a defective capacitor in the vertical circuit. If you can solder, you should be able to fix this your self. Let me know if you wish to attempt the repair and I will supply additional details and instructions.
Dan
Apr 02, 2009 | Zenith B13A03D 13" TV
Vertical Fold over or rolling on Dell Inspiron 1000
Get a new hard drive put into the system, with the cd's that came with the system, restore the laptop back to factory defaults and then after that the F12 function should work and windows will go back to working as well.
Feb 13, 2009 | Dell Inspiron 1000 Notebook
Loss Sync
According to SharpUSA the problem with the "Loss of Sync" error message is that (most probably) the cables (between the box and the display) are not connected properly (so remove and reconnect them carefully, on both units) or a cable is defective.
Also, after you reconnect the cables try turning on the unit, if no success then depress the "clear" button on the external box (under the door on the front and on the bottom left and try turning on the TV again).
It is, most likely, that the cables are not seated properly. Reseat the cables on both the display and the external box.
Hopefully, this will clear the problem
if still does not solves your problem just replace all the cables connected between .u can get the new cables at radioshack web site.just place an order they will provide you. thanks.
Dec 14, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
DS25390 Verticle foldover
If you have a picture but the top is folded over, your vertical IC is probably good and you need to replace the pump-up capacitor next to the IC. When the pump-up cap (typically a 47 or 100uF 35V cap) is open then the picture will have white lines and foldover at the top. The typical vertical output IC is the LA7838, but I am not familiar with exactly which output IC your set uses.
Jul 02, 2007 | Sanyo DS25390 TV
Sony KDL32L4000 32 in. LCD HDTV Logo
199 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
