Question about Procom MN100TBA Heater
When I turn the pilot light on it's an orange yellow flame and it goes out when I release the button. What is the problem
    Brigadier General:
  • 4,736 Answers
The problem is the pilot assembly needs cleaning. This means cleaning the tip and the Oxygen Depletion Sensor (ODS). You will need to turn the gas off and remove the front of the heater's cabinet. Once you do, you'll have access to all the inner workings. Plus, you'll proabaly find a lot of dust and lint inside the heater cabinet. A shop Vac with a hose, brush and crevice tool attachments works well for cleaning all the interior of the unit (Cabinet interior, burner(s), etc). To clean the Pilot Assembly, use a can of compressed air with a straw nozzle ( Like you lean your computer with). Place the straw nozzle just barely into the tip of the pilot and give it a quick shot of air. Look down the pilot from the tip and you will see a small hole in the side of the pilot. That's the ODS sensor. Place the straw nozzle just barely into the hole and give it a quick shot of air. You'll probably see debris blow out the other side. Once you have completed all of this, reassemble the heater, turn the gas line valve back on and light the pilot as you normally would. It may not light the first try or two, because there may be some air in the gas line. Once the pilot lights, hold the Control Knob in for One Minute, then slowly release it and the pilot should remain lit. Turn the control knob to ON and the Burner(s) should light and burn as they should.
If all the above worked, congratulate yourself, you just completed what's called "Annual Maintenance". Which should be done every year, in the Fall, before you fire the heater up for the heating season.
In addition, in case you have misplaced your Owners Manual, I have included a link to where you can find and download and print is for future reference. Just click on you Model Number.
http://www.usaprocom.com/manuals.php?choice=1
Hope this helped you to solve the problem.
Posted on Mar 21, 2011
  • Rich Landrum Mar 22, 2011
    Darrel, glad I could help you. Thank you for the four thumbs up.
I have a Vulcan Freeloader that is over 10 years old. The pilot does not stay lit when I release the red button. Also, the pilot flame is orange. What can be done as the main burner would not work when the...
The pilot assembly is stopped up. It will need to be taken apart, blown out or cleaned and re-intalled. The yellow, lazy flame is preventing the thermocouple from getting warm enough to allow the main burner to ignite. Hope this helps.
Jan 20, 2011 | Heating & Cooling
I am trying to light a heater that is a couple of years old. The pilot will light but the main burner will not. I have changed tanks but no luck. Can you help.
So the pilot flame stays lit after you release the pilot button, but goes out when you turn the knob to on. First make sure the pilot flame is a strong blue flame that is actually heating the thermocouple. If it's a lazy yellow flame, then it is dirty and will need to be blown out with a can of air with attached straw (to remove dust, spiderwebs, etc). You also might check the burner and orifice to make sure they are not blocked by a bug nests, etc and clean out as needed.
Make sure the thermocouple tip is not burn't off from the pilot flame. It should be a smooth rounded tip. If it's not, then replace it.
Lastly, make sure you're not turning the propane tank valve on too fast. To check this; disconnect the tank, reconnect it and then turn the valve on very slowly. Hopefully one of these solutions will fix your problem. Have a great weekend! Douglas
May 28, 2010 | DCS PHFS Phoenix III Outdoor Patio Heater
Pilot turns on but when I switch to turn it on,
When you light the pilot, are you holding it down for 30-60 seconds. When you release the pilot button, does the pilot flame stay lit? Or does it only go out when you turn the knob to on position. Make sure the pilot flame is heating the end of the thermocouple and that it's a strong blue flame, not a lazy yellow pilot flame. Make sure the tip of the thermocouple is not burn't off, which usually happens with lazy yellow pilot flames. Replace thermocouple is nothing else works.
May 13, 2010 | Coleman 5040-751 BackHome Open Flame Patio...
I cant get the pilot lit...I turn it to pilot...hold down the button and light the pilot..but when I let it go to turn it to "on" the flame goes out.
Are you holding the button down for a minute or so after you light the pilot before releasing the button?
If so, almost certainly, your thermocouple is bad. This is the long tube which runs from the control box to the pilot flame. Remove this tube, take it to the hardware store and get an exact replacement.
Once the thermocouple is replaced, your pilot light should stay on.
Apr 04, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
We dont think our cylinder is on we have just moved in and have no hot water
The question is? I'll assume you cylinder is the water heater, right?
On the heater (water) you will find or see the red controls and a sheet metal cover over a hole. Remove the cover and this is where you light the pilot light. Press down on the red dial and turn it to pilot. In that position you will be able to press the red button . Geyt a long match or bbq lighter, then, holding down the red button dow for a minute or so and place a match or lighter into yhe area where the lines go The flame will catch the gas and lite the pilot if yo simply move your glame around. When the flame catch on the pilot, continue holding the button down for sveral minutes until the buld the flame isheating gets hot. Then release the buton and turn the main dial to on. The main burner should fire up. If not, and the pilot goes out, repeat the process. The bulb in the pilot flame is a thermocoupler that shuts all gas off if it doesn't detect a pilot flame, so hold the button down longer. If the pilot goes out when you release the button, The thermocoupler is no good and needs replacing. Good Luck_Ned_
Oct 31, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
Oct 19, 2009 | Heating & Cooling
Can't get pilot light to light. Comes on
you can only test this with a volt meter capable of testing milivolts. or replace the thermocouple. the thermocouple is what the pilot flame is burning onto. the pilot flame could also be weak due to a dirty pilot orifice in which case the flame will appear lazy and yellow /orange. the thermocouple should test 30mv + - 10% you should contact a service company if replacing the thermocouple doesnt fix because gas isnt somthing a un-qualified DIYer should risk there home with.
Sep 24, 2009 | Heating & Cooling
Pilot goes out once button is released
If the new thermocouple was installed properly, with its tip in or across the pilot flame so as to be heated by the flame, then the control valve may be faulty.
Note: The pilot primer button may need to be held down for a longer period of time.
Aduz
Mar 24, 2009 | Water Heaters
Lighting the pilot light
The steps involved can vary slightly depending on your furnace model and pilot valve type, so if possible try and find the instructions inside the furnace door cover or in the instruction manual. This is for a gas fired furnace, but applies to any gas-fueled appliance including water heater. Two of the most common types of pilot valve body assemblies either have a red reset button and a gas valve or no reset button and a valve knob that can be depressed. But whichever type you've got, if you have an older model furnace with a standing pilot (flame is lit all the time) then this is the basic procedure.
  • Turn you thermostat to 80 degrees or to a setting that will demand heat. Make sure the thermostat is in "Heat" mode.
  • Go to the furnace and find the pilot valve. The pilot valve body is a box shaped device into which the main gas line will run and is located near the gas burners. It will usually have a gas **** or valve knob that reads "On, "Pilot" and "Off." Locate this gas **** or knob.
  • Turn the knob or gas **** to the "Off" position and wait about 3 minutes for any residual gas to clear away.
  • Find the pilot. It's located near the gas burner tube assembly in the furnace.
  • Get your match or lighter ready. Sometimes the pilot is hard to reach. If possible, try and use a long fireplace match when you light it. If you don't have a fireplace match then a butane BBQ grill lighter works well too. If you don't have that, then you can fasten a match to the end of a stick when you light the pilot
  • If you have a pilot with a red Reset button, turn the gas valve from "Off," to "Pilot."
  • If you have a pilot with no red button, turn the knob from "Off" to "Pilot."
  • Place the lit match or ignited lighter tip at the pilot and depress and hold the button or depress the knob as appropriate. Depress the button or knob for about 30 seconds. This maintains gas flow to the pilot until the thermocouple gets hot enough to open the main gas valve.
  • Once the pilot stays lit, slowly release the button or knob and turn the gas **** or knob from the "Pilot" position to the "On" position. This will ignite the burners and keep the flow of gas supplied as required for the burners as called for by the thermostat.
  • If the burners fail to ignite then it may be because the thermocouple did not get hot enough to open the gas valve. Wait a few minutes and then repeat the above procedure. This time hold the red reset button or depress the knob for about 45-60 seconds.
  • Once the main furnace burners ignite, adjust the thermostat to the desired setting.
  • If you've followed the previous steps on lighting the pilot and it still does not light after, or will not stay lit, then you probably have a problem with the thermocouple or an adjustment needs to be made to the pilot. You'll need a furnace service technician to replace or repair these parts. You may find that the pilot lights, but it is an anemic looking flame. That's a different problem we'll look at in the next section.
  • If the pilot lights but the flame is a weak yellow flame, it will not get hot enough to heat the thermocouple to its set point allowing the gas valve to open.
    A natural gas flame should be a bright blue with the tip of the flame having just a tinge of yellow. A propane flame should have a bluish green flame with a tinge of yellow at the tip. The flame should be strong enough to hit the thermocouple tip about 1/2 inch from the tip end. If the flame is weak or shaky looking, check to see that a breeze or draft is not blowing on it. Adjusting the Flame
    There is usually a small screw on the pilot valve body that will adjust the flame. You may have to refer to the manufacturer's instructions to find the screw. Turn the screw as needed to adjust the flame throw. Yellow Flame
    A yellow flame is caused by lack of air and incomplete combustion. It can be caused by a dirty pilot tube tip. Split Flame
    This is caused by dirt in the pilot tube. Take a needle or small nail and gently clean the tube. Flickering or Wavering Flame
    A flame that flickers is usually caused by a draft.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 18, 2009 | Water Heaters
Pilot light will not stay on when egnition switched is released!
the little copper tube that sits in the pilot flame is faulty. this is called a flame sensor. replace this and you should have no problems
Dec 03, 2007 | Empire ECS HB06M HearthRite Heater
Heating & Cooling Logo
256 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
