How can i take out dispenser drawer - Washing Machines
  • 3 Answers
M
y zanussi electrolux essential 1600 wont let me program any thing into it its saying that the door isnt closed properly
Posted on Mar 21, 2011
Can't put6 dispenser back in
Hi Paulette, this is AP
I understand you are having difficulty reentering the dispenser drawer on your Frigidaire front load washer. On this particular model, FAFS4073NW, the dispenser drawer has a lock tab in the left rear corner of the drawer cavity. You must push this lock tab down before sliding in the drawer, reversing the process you used to remove the drawer originally. Make sure you look in the entry way of the drawer so that you are lining up the track with the dispenser drawer tracks. I hope this information proves helpful to you, thank you for the post.
Thanks,
Mar 30, 2014 | Frigidaire FAFS4073NW Affinity Series 3.8...
I accidently poured my fabric softener in my bleach dispenser!!. I'm not an idiot--I just took migraine med. & I guess my head was fuzzier than I thought!! What should I do?
Pull the dispenser drawer forward until it stops. Push the tab down at the back side of the drawer to allow you to remove the drawer the rest of the way out of the machine. Dump out the dispenser drawer, re-install dispenser drawer.
Sep 25, 2010 | LG WM-2277HW Front Load Washer
My Frigidaire front load washer will not dispense the fabric softner during cycle.
Clean the dispenser drawer if water is introduced into the fabric softener cavity but does not dispense. Pull the dispenser drawer out until it stops and push down the release tab marked "PUSH" and then pull the dispenser out completely.
Lift the dispenser drawer cover and clean the tubes both in the dispenser drawer and the cover.
Turn the drawer over then release the conveyor from the tabs and lift it off. Clean the conveyor and the drawer thoroughly.
Snap the conveyor into the tabs back into position and then reinstall the dispenser cover making sure the tubes are properly seated.
Slide the dispenser drawer back into the drawer opening while pushing down the part marked "PUSH".
Let us know if the fabric softener dispenser still does not dispense while both the detergent and bleach dispensers dispense.
Mar 10, 2010 | Frigidaire ATF6000ES Front Load Washer
How to clean fabric softner dispenser sear 70 series cc3815443
hi friend,
step 1
Pull the dispenser drawer out until it stops.
  • Step 2 Reach into back right corner of the drawer opening and press the lock tab to release the drawer. Pull the drawer fully out of the washer.
  • Step 3 Lift the fabric softener dispenser cup out of the drawer.
  • Step 4 Run the fabric softener dispenser cup under warm water while rubbing it with a soft cloth or sponge.
  • Step 5 Place the cup back in the drawer and slide it back into the washer.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • You can also remove and clean the prewash, detergent and bleach detergent cups by following Steps 1 through 5.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 30, 2009 | Washing Machines
    My washing mahine cycle is working but the comfort doesnt seem to empty from the drawer
    You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
    Pull the dispenser drawer completely out.
    There is a tab that needs to be depressed to release the drawer and remove it.
    Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
    Reach down into this opening to see if an item is inside the hose.
    This is the normal issue that will cause water to leak out of the dispenser housing.
    Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Oct 13, 2009 | Washing Machines
    On spin,water pouring out of washpowder drawer,thankyou
    Oct 12, 2009 | Washing Machines
    MY FABRIC SOFTENER JUST SITS IN DRAWER
    Mar 18, 2009 | Washing Machines
    Detergent drawer gets mouldy and smells all the time bleach and mould removing products don't help what else is there
    Mar 07, 2009 | Washing Machines
    Dispenser drawer
    Mar 03, 2009 | Kenmore 44102 Front Load Washer
    Detergent dispenser drawer stuck
    You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
    Oct 11, 2008 | LG WM-2277HW Front Load Washer
    Washing Machines Logo
    114 people viewed this question
    Top Washing Machines Experts
