Question about Salter Health & Beauty
My Salter mi body has worked great for ages, then suddenly it's changed my *** from male to female overnight and I cant change back
2 Suggested Answers
SOURCE: male/female image on scale:which?; normal muscle mass/bone mass range
The tiny triangle in the shape of a dress is female; the tiny triangle with the broad shoulders is male
Posted on Apr 30, 2011
What should I do to make f-pin coax coupler I bought (to link two coax cables to extend the range of my cable box) receive and display cable programs?
Female to female couplers will only connect to a male plug either side. If the two plugs are female you won't be able to do it, till you either change to two males or get a male to male coupler!
Sep 21, 2013 | Cable Wholesale F-Pin Coax Coupler, 1GHz...
Wap.2go.im/sms.php?id=SmsBDcGCCjJBdyt405
I want to change my location
Jan 11, 2012 | Cell Phones
My Toshiba Dynadock DVI has been causing all sorts of problems lately. These include: Blue Error Screens Graphic Driver crashes Display going black while plugged in Reduced GPU...
NO FUN!
I suspect your power supply MAY be your problem? As supplies age the capacitors inside begin to filter the DC poorly! Stray AC voltage (or AC content from your supply) will/can drive your components inside your Dock crazy with AC hum as false data?
Looking at the photos for your Dock I see your provided power supply does not look too beefy for all it must support? TEST with another well filtered supply...
Next check the PINS INSIDE your male connectors! Make sure none are pushed into it's body ~ below it's mates?
Also check the FEMALE connectors too ~ looking for broken MALE pins still inside the female connector bodies?
Finally try new cables?
Hope this helps!
Anthony
See this link:
File 9 pin sub connector male closeup jpg
Nov 25, 2017 | Toshiba Dynadock Port Replicator, Docking...
I cant figure out how to change the setting for the sportline heart rate watch i pressed mode and it switched options ...now it has an A and an F for female and then a number with a heart next to it. what...
The large A stands for age...when hit mode and that screen appears, hold the mode button until you see the number start flashing...Then use the buttons on the right to toggle to your age..then you can hit the mode button again to switch from the number to the F and you can change that to an M for a male...
The purpose of this is to let the watch know your gender and age in order to properly calculate your heart rate percentage..
Dec 28, 2009 | Sportline 1000 Memory watch
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
Health & Beauty Logo
106 people viewed this question
Top Salter Health & Beauty Experts
vince
Andrew Taylor
Andrew Taylor
richie46
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
