Question about Compaq EVO D510 CMT P4 2.5/20GB/256MB (268899999) PC Desktop
Connect to internet
Was conn. to int. accidently lost power //lost int.conn.when power turned back on what can I do as I am old & comp. illiterate --possibly stupid as well.
  • 1 more comment
  • robartee Aug 04, 2008
    I used incorrect account name 7server name etc when setting up int. explorer now can`t get in to change or correct now it won`t load..What is the answers
    ok the first problem solved ,thanks you did good as they say ..//next I have a problem with int. exp. as explained in previous comment,ie Have filled in the wrong info. when signing in ,now can`t get back in to fix it up ,What to do ??
  • robartee Aug 05, 2008
    thanks to all for the well meaning advise.however it seems that when I had a power out I lost the info.so all I needed was to start ouer ..thanks again
  • 3,037 Answers
The first thing to do is call your service provider. If you can get online, but not logged in, then they can reset your account and give you the username and password. If you can't even do that, then you should uninstall the provider software and reinstall it and try again. If you need the software, then you should again contact the service provider and have them send you new software which may take a few days. Please let me know if you have any other questions
Posted on Aug 04, 2008
  • Benjamin Patri
    Benjamin Patri Aug 04, 2008
    I'm sorry are you referring to me? What exactly did you do so far? You are using what kind of connection and who is your service provider? When you open Internet Explorer what comes up exactly to keep you from using the internet?
    Please answer these questions as well as you can.
    What can't you get back in to? Please be specific of what you used to do to get in and whether any errors are coming up or what. thank you
  • 6,487 Answers
Just turn your modem off for 30 seconds and also you router if you have also turn your computer off for 30 seconds also.
Then after 30 second turn modem and router on then after that the computer, that should be ok now.
IF still not working call your ISP.
Hope that helps..........
Posted on Aug 03, 2008
  • Mark Gil
    Mark Gil Aug 04, 2008
    If that's teh case you need to call your ISP and they will walk you through with the process in putting your correct log in for the internet..
Lost IP address in settings
press the reset button on the router and unplug it,now search for wireless with your comp,click on your router and enter admin password
Jun 27, 2015 | Dell Inspiron 530 Desktop Computer
Tip
Cannot access internet!!!!!
Using Windows Operating Systems:
Windows XP:
1.Powercycle equipment (Unplug power wait 15 seconds then plug back in)
2.Go to Start/Run/Type ncpa.cpl then hit ok.
3.Double Click Wireless Connection (Router Connection) Hit Properties.
4.Click on tcp/ip then hit Properties
5.Ensure Obtain ipaddress automatically is checked as well as Obtain a DNS server automatically is checked.
6.Restart Computer, If still unable to access internet check you Firewall:
Start/Control Panel/Windows Firewall/Change Windows Firewall Settings/Turn Off not recommended.
7.Last Go to Start/Run/CMD/Hit ok
A.Type netsh int ip reset reset.log Press Enter after every Command
B.Type netsh int ip delete arpcache
C.Type netsh winsock reset
D.Type ipconfig /flushdns
8.Restart Computer
9.If still having issues check for viruses or malware in your computer.
10..Refer to your manufacture.
Windows Vista/7:
2.Go to Start/Search Bar/Type ncpa.cpl then hit Enter.
3.Right Click on your connection usually (Wireless) then click Properties.
4.Uncheck Internet Protocol Version 6 IPV6
5.Click on Internet Protocol Version 4 IPV4 Then hit Properties (Do not uncheck IPV4)
6.Ensure Obtain ipaddress automatically is checked as well as Obtain a DNS server automatically is checked.
7.Restart Computer, If still unable to access internet check you Firewall:
A.Start/Control Panel/Security/Allow Program Through Windows Firewall/General Tab/Turn Off.
8.7.Last Go to Start/All Programs/Accessories/Right Click on Command Prompt then hit Run as administrator and hit continue.
10.Refer to your manufacture.
on Jan 11, 2011 | Computers & Internet
I m using a toshiba L310 laptop & it was fine with a wireless internet connection but suddenly it lost connection & its not connecting anymore. what can I do now?
restart your comp and your router, if that doesnt help try and update your drivers to your wireless card in your comp., if everything is updated and the wireless in you comp is searching then it might be the router, they commonly overheat for heavy use
Sep 18, 2010 | Internet Computers & Internet
Hi... I am using dell vostro 1510. I can see bluetooth sign on my laptop. but unable to use bluetooth. Please help me to use bluetooth
U can connect your system to internet using ur mobile phone through bluetooth.For this u need to set Bluetooth Personal Area Net(PAN)or use ur phone as dial-up modem.Check information of ur mobile to see if it can support either of these methods.Once the PAN is set, u can use net .If ur phone could be used as modem,do following to connect to internet.
Make sure that ur phone is paired with with ur comp.For more information,see Set up a Bluetooth Enabled Divice.
2.Click to open the connect to Internet Wizard.
3.If u already have Int.connection,Click Create new connection any way.
4.On the "How do u want to connect",Click "Dial-up"and follow the steps.Be sure to select ur phone.
5.On the "Type the information from ur Int.service provider(ISP)" page,in "Dial-up phone no." type ur phone no. or carrer no.
Contact ur mobile service provider to get required ID,Password,carrer code or phone no.
Apr 10, 2010 | Computers & Internet
My astec atx202-3515 power supply blew up. I accidently changed the watt to 115. It was 230 watts before. Will the power supply still work oe will I need to purchase a new one?
just flip it back to 115v hook it up and see if it works. if itdoesnt work replace it . I did that once it was fine the comp didnt turn on til i turned it back 115v
Mar 09, 2010 | Astec (ATX202-3555) (ATX2023555) 200-Watt...
Im with talk talk broadband and have a bt homehub 2.0 wirless router. is there any way to reconfigure the router so that the internet can work?
I AM ON TALK TALK LAND LINE AND HAVE LOST MY B/B CONN THE MODEM SHOWS TWO GR LIGHTS AND ONE RED I HAVE DIS IT AND RECON IT AND PUSHED THE RESTART BUTTON BUT IT WILL NOT LOAD WHEN I CHECK CONN IT SHOWS RED CROSS BETWEEN COMP AND CONN
Nov 19, 2009 | Computers & Internet
How do i get my pc to pic up my xbox drive.
mabee this way ????
must be an ms28
download jungleflash plugin all your stuff turn on your comp and half open your tray half way then turn off the conn kit and leave the tray half open turn off comp then back on (power off at the conn kit) load jungleflash turn on con kit switch go to one of the blades that says unlock sammy benq liteon (dont erase or flash) something in there puts it in service mode do a little reading first about it if not sure
if this helps give me a tick ok
Aug 04, 2009 | Microsoft Xbox 360 Console
Internet Explorer 7 ''error cannot display the webpage''
my recommendations is install a new firefox 3.........try this
Feb 04, 2009 | Gateway Computers & Internet
HP Tower (2000 Media Edition)
Sounds like your power supply unit is dead. Do you get any power or hard drive lights on the unit? If not, I'm afraid it's a repair shop problem.
Sorry to be the bearer of bad news!
Oct 30, 2008 | Computers & Internet
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
