Question about Cell Phones
Panasonic phone system extensions have been turned on and they cannot disconnect from this one
  • carolyn577 Mar 21, 2011
    This did not work. Our phone does not have a page/call button.
    It is our main phone that has line 2 lit up alogn with the intercom line that wont go out not a cellphone. We have three lines on a rotary system and line two has remained on and when you call it is busy. Need to get it off.
    I retried this and the phone line did go out after a few minutes.
    Thank you.
    Genius:
  • 1,196 Answers
You can try reset your phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem
Posted on Mar 21, 2011
  • Ishola Olayemi Mar 21, 2011
    Power the 3 phones off and after some minutes power them on.
Panasonic vb-44223-g the light is on
Normally this is the Voicemail indicator light. If you have a button programmed for voicemail you can push that button and if the system calls the VM system it should clear after you listen to the message.
Another way the light can get turned on is if the system call back feature got activated. If this is the case you just need to call the station that called you and turned on your light. Again if you have a message button this will call that extension in the office. Once they pick up the phone the light should clear. Worst case you can try calling every extension in the office and eventually you will find it.
One last option is if the phone is connected to a PBX model 576 or HD576 (This is the brain box in the closet or basement) you can dial *4 plus your extension number or *5 plus your extension number are the default message light codes. One code says turn on the light the other says turn off the light. If your system is an older system 40, 72, or 96 this will not work.
Best of luck!
Jan 03, 2014 | Panasonic Vb-44223-g Dbs Display Year...
Hi Gooday! Im a Panasonic pabx technician...i had a problem with our current project pabx system the CO card or trunkCard always hung and all line always busy...whst is the posible problem of my...
Two possibilities. The C.O. is not sending a disconnect or the timing needs to be set. It's a C.O. trunk time you adjust first and if that doesn't work, call the telco. We have hardware to simulate disconnect supervision if the phone company (or PBX extension like a Panasonic) can't provide it. We have to use them on elevator extensions.
Carl
May 24, 2011 | Panasonic Lands Phones
I reached the limit of the ports on my TDA100 and I have users who need extensions. I want them to share phones. the process is when they come, they log on using an extension number and PIN. if they leave,...
It's fairly hard to -believe that you have used 64 or 128 extensions on a TDA-100, but I don't think it's possible to change extensions without having access to system programming.
In my convoluted mind, it might be possible to set up Incoming Call Distribution groups and log in and out of them to make a phone ring in the ICD group. If they're to only ones in the group, you could start assigning 6xx digits to those phones and they could set a button to light and the phone to ring when that 6xx number is dialed.
Either way, those solutions are beyond the scope of a free forum. Check with you Panasonic dealer/installer for possibilities.
Carl
Feb 23, 2011 | Panasonic KX-T7630 Corded Phone
We have Panasonic TES 824. We connected 3-direct lines, one of them is for fax. However if I call the fax number, it goes to auto attendant. How to disconnect the fax number from auto attendant? Awaiting...
By programming. If the Auto Attendant is the DISA card, you can tell it to listen for the FAX tone and transfer it to the fax extension, or, you can program the 3rd number to ring only the fax extension and no others. Both require programming in the system cabinet.
Carl
Jan 18, 2011 | Panasonic KX-TA824PK Phone
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
Hi would like to know how to set an extension not to ring when any of the co lines is ringing since i have a fax machine connected to this extension and it is programmed to answer automatically
Ringing for each extension and line is done in Panasonic system programming commands 408-410 for Day/Night/Lunch. You turn off ringing for all lines to your fax extension and then just turn on one line for that phone.
Be sure to turn off or delay the fax line ringing to all the other extensions at the same time.
Carl
Nov 03, 2010 | Panasonic KX-TA308 Phone
Answering the phone
Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 to answer external incommincg calls. To answer extension phone press 4 followed by the extension number.
Thank you
Nov 19, 2009 | Panasonic KX-T7730 Corded Phone
The New Voice Mail message appears and the light blinks and there are no voice mails.
What system? A Panasonic KEY SYSTEM (76xx/77xx/74xx/72xx phones) can have messages from other sources than the VM system.
If it's a display phone, try pressing the MESSAGE button without picking up the handset and read the display. It will tell you where it came from and you can press INTERCOM and ring that extension.
It works the same way if you call an extension and press the MESSAGE button...that leaves a message. Panasonic systems have a MW cancel code that usually begins with 700. In a TA system it's 700#, in the TDA/TAW's it's *700 plus your extension.
If it's a Panasonic cordless, it's probably hearing stutter dial tone from custom calling features.
Carl
Sep 27, 2009 | Panasonic Lands Phones
Incoming call rings one time and disconnects
Unplug all phones but one in jack 11 at the cabinet and have someone call in. If it doesn't work, you probably have a bad cabinet. If not, I'm guessing one of your extensions is faulty.
Carl
Apr 06, 2009 | Panasonic KX-TA308 Phone
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
