Question about Sylvania LC370SL8 37 in. LCD Television
Half the screen is running when turned on it stops after about 20min but time is increasing , now it takes hour or so 37in sylvania lcd lc370ss8 m2
  • Sylvania Master
  • 12,061 Answers
Http://www.schematics.me/purchase.php?id=Sylvania+LC370SL8+Service+Manual+%2F+Schematics
Please find above your service manual, whoever services the unit, will find the manual invaluable.
Hi, well undoubtedly this is some component that until it is heated up to a certain temperature, will NOT work properly. However this in turn will ultimately fail, due to this.
Faults such as this can be very difficult to find, usually we use a can of freeze spray and either a directed heat gun or soldering iron, and one applies heat & cold to the suspected components and usually the culprit is easy found. Of course one has to have a fairly good idea of what components where, to start. but in any case one always starts at the Power Supply, check that these voltages are right, and work out.
These days DIY is not really practicable, primarily due to the instruments, and knowledge required to align and re-program the set, even the simple changing of a board, can require a re-setup before the set will work.
So, the very best thing you could do would be to contact either a local or head office of Sylvania, and ask for a referral to an authorised servicing center.
Now when in contact with them, first ask for a "Quote" as to the costs of the prospective repair.
This way you can make an informed decision as to repair or replace. Sometimes a seemingly straight forwards fault, may indeed end up costing nearly as much as a modern day new unit with a warranty.
Posted on Mar 21, 2011
No power
check if you can down load this manual and check page 35.
http://data.manualslib.com/pdf/17/1675/167466-sylvania/lc370ss8.pdf?0099fed34b9f7b0871613a4d97ce394b&take=binary
The power reset can be done by taking the mains power cable out and reconnecting after 30 secs.
Apr 22, 2014 | Sylvania LC370SS8 Television
Sylvania HDTV Model LC370SS8 won't turn on.
u should check std-by volt .when u press power on , the power on volt must not b drop
Oct 09, 2012 | Sylvania LC320SS8 32 in. LCD Television
I need a new remote for my Sylvania LC370SS8 television. Can I order one, and if so, price please. Thanks
Here is a link to a site that you can order a remote for your television! It will cost you about $20 and it's free shipping!!!
http://www.emtcompany.com/sylvania-lc370ss8-remote/rc64.html
I hope I could assist you in solving your problem! Please rate and comment on the solution!
May 02, 2011 | Sylvania LC370SS8 Television
I have a Sylvania LC370SS8 (37" LCD + DVD) TV. It will stay on for about an hour, then it shuts itself off. The power light flashes while it's off (for about 5-10 minutes) then it comes back on... and...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Sep 25, 2010 | Sylvania LC370SS8 Television
Universal remote
Universal remotes never work good anyway. You will need the original remote anyway to work the different functions for the TV.
The cheapest that I can find one for you is at NewRemoteControl.com, it's $32.95
Here is the link for you:
SYLVANIA LC370SS8 LCD TV REMOTE CONTROL
Mar 24, 2009 | Sylvania LC370SS8 Television
Sylvania LC370SL8 37 in. LCD Television Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
