I am trying to open my laptop, hp pavilion zd8000 and the bios not regognized the hard disk, it says "diagnostics not supported" the test status shows "no IDE Device". Please tell me what to do. thank you.
  • 58 Answers
It could be a problem with the hard drive, check if another computer can see the hard drive.
Posted on Mar 21, 2011
Boot hp pavillon zd8000 with usb not possible?
Boot hp pavillon zd8000 with usb is possible.simply plug the USB flash drive with iso and reboot, then press F10 navigeyt Boot Order Mark hard drive, hit enter, Highlight your usb and press F6 so usb was on top of the press F10
May 15, 2012 | HP Pavilion zd8000 Notebook
I am unable to start windows after I formated all existing partitions. Now as my computer boots up it starts to load and say's "BOOTMGR is missing.. Press Ctrl+Alt+Del to restart
The problem could be with the hard drive or internal hardware.
in order to figure out the exact problem, perform hard drive self test.
here are the steps:
turn on the notebook and keep tapping f10 key until BIOS screen comes up
select Diagnostics option using arrow keys
select primary hard disk test
quick test starts followed by comprehensive test .. it may take an hour
if test fails, u need to replace the hard drive
Apr 21, 2011 | HP Pavilion dv6226us (RP297UA#ABA) PC...
My brother laptop Compaq Presario CQ-42 after 3 month used , now appears " Boot Device not found Please install an operating system on your hard disk Hardisk - (3F0) " F2 System...
Fundamentally, it means that the hard drive or hard drive controller has malfunctioned. I'm assuming this is running Vista or Wndows 7 and that the hard drive is indeed a Sata drive?
(If it were running XP, the failure to deterct the hard drive could be caused by there not being a Sata driver installed, however, on Vista or 7, this should not be the case, UNLESS you changed the OS from what was installed originally?)
I would try to prove this by testing the laptop with another working sata hard drive and if that one is recognised in the Bios, then it comes back to your original hard drive being faulty. If this IS the case, then as its 3 months old and still under warranty, I'd take it back without tampering with it any further
Apr 18, 2011 | HP Pavilion dv5-1000us Notebook PC
I am getting the error message-"Hard drive not
it caused the hard drive malfunction try open the bios and try to read the hard drive is your hard disk stll there. in some case on the hp compaq laptop the hard drive was detecting eror but it can be use to external hard drive.
you can find some usb to mini ata or usb to sata to try your hard drive on another laptop or pc(make it external hard drive)
Jan 14, 2011 | HP Pavilion dv5-1132us Notebook
I have an hp pavilion zd8000 when i turn on my laptop the bootmenu will come on then the screen will go blank right befor windows start loading. what do i need to do to fix this problem?
Your ROM BIOS is asking you where to find bootable media, and when you tell it the HDD (hard disk dive), the ROM BIOS can't find a bootable partition on it and just quits, leaving the screen blank.
So, either your HDD is no longer connected to the system bus (was the laptop dropped recently?), or
someone (or something - aka virus/worm/trojan/malware/rootkit, etc.) has erased your bootable
OS (operating system) from the hard drive.
Fix: boot from a "Recovery CD" and use the utilities thereon to repair your OS (or at least find what's left of it), and try to reboot.
Failing that, run any/all diagnostics that your ROM BIOS has - especially memory tests and HDD diagnostics. Why?
(a) bad/jarred loose memory (RAM cards) will prevent booting
(b) an HDD that fails low-level diagnostics may never be salvageable and may have to be replaced -
it actually may have had a head crash - which tends to happen when a ZD8000 notebook is
dropped while the system is running - or a head can crash for no apparent reason.
If you can get the system to boot to SAFE mode - run sfc (system file check) as your first attempt
to repair the operating system - its already in Widows, here's how to run it:
START > run > sfc
As soon as you can get beyond safe mode, update your favorite anti-virus package database and
run one (or more ) deep scans, until the last scan that ran to completion found nothing.
Jan 02, 2011 | HP Pavilion zd8000 Notebook
I have an HP Pavilion dv6500, and while I was working on my laptop it suddenly shut down by itself and restarted. When it rebooted, a message came up saying "Operating System not found". I...
Your hard drive may have failed.
I suggest you remove your hard drive and re-connect it to your laptop to make sure it is make proper connection. Boot up and go into the BIOS to see if the hard disk is detected.
If the hard disk is not detected then most likely the hard disk has failed.
To get your laptop working, you will need to purchase a new hard disk and install Windows on the new hard disk plus the Pavilion device drivers and your programs,
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Dec 18, 2010 | HP Pavilion dv6000z Notebook
HP Pavilion DV6812 is not recovering or restoring!!
If you mean this errors
STOP 0x0000001a (0x00041284, 0xca9a2000, 0x000077e0, 0xc0c00000) MEMORY_MANAGEMENT
STOP 0x0000004e (0x00000007, 0x00007abf, 0x0000f17e, 0x00000000) PFN_LIST_CORRUPT
STOP 0x0000000a (0x00000028, 0x00000002, 0x00000000, 0x8012d2d6) IRQL_NOT_LESS_OR_EQUAL
STOP 0x00000050 (0xc2332b94, 0x00000000, 0x00000000, 0x00000000) PAGE_FAULT_IN_NONPAGED_AREA
Its ram problem,so first if you can access the bios check if your ram are been recognized and load default bios settings.If are OK in bios remove RAM and reinstall again.If the problem still exists try again testing your Ram with the Microsoft program or with that.
If the programs founds an error you RAM are damaged and replace them.
Feb 04, 2010 | HP Pavilion dv6812nr Notebook
How to update BIOS on my HP Pavilion zd8000 laptop running on Windows Vista Ultimate
visit HP's site, http://www.hp.com/#Support enter your system details then download bios. after downloading the bios. close all open programs. remove any external device. make sure ac adapter is connected. then run the bios update. that should do it. =)
Jan 07, 2010 | HP Pavilion zd8000 Notebook
I bought a HP Pavilion ze4300 laptop and it has Windows XP on it and it was working fine for the past three weeks. Yesterday I started it up and am getting a message: ''Operating System not found''. One of...
It could also be the conncetion came loose, which can happen with IDE hard drives if the laptop gets moved around a lot. Remove the hard drive and take it to an electronics store to have it tested, or if you have a friend with an external enclosure (2.5" IDE interface, they cost between$10-20) you can hook it up to another computer via the USB port
Sep 25, 2009 | HP Pavilion ze2000 Notebook
"No IDE device" in BIOS drive selftest in HP Pavilion zd8000
any moisture on the motherboard
will destroy components if plugged in
even if yoru laptop is cold in your car , is ok
but when you bring it inside and plug in fast
condensation can burn out the tiny components, motherboard is bad
Jul 18, 2009 | HP PAVILION ZD8000 SEREIS 100GB (4200...
Computers & Internet Logo
David Payne
David Payne
