My shredder jammed, I took it apart, fixed it, and used it again. It has jammed again and this time I can't figure out how to put it back together for some reason. I need a diagram of Crofton AL890C interior.
jackiaria
  • 350 Answers
SOURCE: reassembly of graco umbrella stroller
You can do this go slowly and be patient!
Posted on Jan 24, 2009
lessmith49
  • 5 Answers
SOURCE: see above
317b762.jpg4a538aa.jpg067f3f0.jpg5077a62.jpgca392ef.jpge76904e.jpg77309d5.jpgThis is an older b&d stapler but the designs are similar in most cases. The position of the springs, and the order you put them in, are an obvious factor.
The parts that overlap go in after the parts underneath.
When you have one half assembeled you should not have to force the cover to go on, it should just sit in place while you put the screws back in.
If the handle coil spring and the flat spring are not seated properly the top cover will not go on easily.
These types of staplers are designed to clear from jamming without being taken apart, the staples, under normal circumstances, do not have access to the body of the unit past the flat spring.
As with any tool forcing the tool after a fault will only make matters worse, I would try some light oil or spray lubricant first before taking anything apart, these springs can be a pain to get back in, which is why I have not taken this one any further apart. Hope this helps you. If it does please let fixya know.
Regards
Les
Posted on Feb 12, 2009
SOURCE: need wire diagram
A manual can be downloaded from the following link, the wiring diagram is located toward the end of the manual.
http://www.star-mfg.com/documents/Manuals/Star/Fryer/Electric/C_530TD_530TED_-_2M-Z6600.pdf
Hope this helps, please rate me!
Posted on May 12, 2009
wrench57
SOURCE: putting my airgun back together
http://www.flickr.com/photos/wrenchmonkey2k/
Posted on Jul 21, 2009
  • 8404 Answers
SOURCE: REATTACH PARTS
Should slifde right together from the back. If you will go to the company web site, there is an exploded picture there for your convenience.
I hope this helps
a
Posted on Oct 02, 2009
How do I fix the rollers that won't turn when paper is inserted in shredder?
That shredder is as weak as they come - it is probably a broken plastic part inside the mechanism. Recommend you throw it away and get the Amazon Basics shredder, your experience will be much better. Sorry.
Jan 16, 2015 | Royal Office Equipment & Supplies
I have a Royal MC14MX paper shredder that has worked extremely well for almost 2 years. Until now. I normally leave it turned on 24/7, even when the office is closed. The other day I turned it off and
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and
place upside down. Use a small screwdriver and poke at any compressed paper
wrapped around the blades - can take a while.
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Feb 14, 2014 | Royal Office Equipment & Supplies
I obtained a used Steinmax 1800 chipper shredder. I was told it worked, but when we plugged it in, it only gave a hum. My husband (NOT even remotely a fix-it type guy), took some of it apart, loosened a...
I have one of these and LOVE it. Usually what you describe is caused by debris keeping the rotor from turning. Check it again (take off the top part) and be sure the thing spins freely. They're very reliable, in my experience, but you can't let the blade get jammed.
May 09, 2011 | Heavy Machinery
I have a paper jam. Reversing doesn't bring it up enough to grab it. Cooled it off. Reading about shredder oil. Haven't found it nearby. Can any other machine oil be used?
Try graphite powder which you can purchase at a hobby shop or home builder supply - or try rubbing with pencil lead. However, I have also, carefully and observantly, taken the shredder head apart to release pressure on the teeth. After some of the stuck paper falls out, put it back together and try again. Be sure safety guide is in place so it work properly when you put it back together.
Sep 02, 2010 | Tech Solution TS-4500 Shredder
My vf1000mx got jammed. i took off the cover and
It could just be dirty "eyes"....try cleaning them with a soft cloth they are in the middle where you put the paper in.( make sure it is unplugged first) if that dosn't fix it then it will most likely be the pcb...call Royal at 1-800-524-0799 for parts and prices.
Feb 13, 2010 | Royal VF1000MX Shredder
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Apr 29, 2009 | Fellowes Powershred 220 Shredder
Shredder rollers do not turn; motor works good; all gears go arou
Will it work in reverse? Can you see the gears are they all moving? Is there a set pin?
Apr 03, 2017 | Adler Royal HT500X Shredder
Shredder won't run
I had similar problem. I took unit apart and checked the motor by hotwiring it after checking voltage coming off the circuit board connections that the motor is connected to. Motor did not run until I tapped it a couple times with a hammer. Seems ok now.
Feb 16, 2009 | Office Equipment & Supplies
How do I reassemble On/Off switch?
The actual switch will not fall apart. There is a black part that is integral with the switch itself. This is about 1/4" to 3/8" wide, and can only be seen from inside the unit. Then there is a plastic piece that is part of the top shell. The hole in the plastic piece has to fit over the black part of the switch, so when the plastic piece is moved, the switch on the inside of the unit will move with it. SO, center both parts, and put them together. If you actually took the switch itself apart, you would have needed a soldering iron, and there would be no purpose for doing this.
Apr 03, 2008 | Fellowes P700-2 Shredder
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
