Question about KitchenAid KTT261 Ultra Power Plus 2-Slice Toaster
My toaster flashed a "2" and the lever won't stay
    New Friend:
My toaster is blinking on 2 and not working? My booklet to it doesn't say anything about this problem.
Posted on Dec 25, 2012
  • 277 Answers
SOURCE: lever won't stay down Breville CT20
hi sounds like the problem is the holding down mechanizem clean the toaster well find that spring which caches the lever down you can find it on the external lever side pretty small and simple thing when you push down the external lever the spring kick a little lever which holds the slide in place for heatup only when you will hear a "click" then you'll know its in place and then the electric cicuit will be close and engage the coils to heatup good luck
Posted on Mar 30, 2006
snakehead
  • 1074 Answers
SOURCE: Toaster broken???
these toaster has to be pluged in so that the lift lever could stay down.
Posted on Feb 25, 2007
Falling Down
  • 67 Answers
SOURCE: Russell Hobbs 10617 led bar
may have screws on the bottom and the loader knob usually has to be pried off. Place soft wood like a ruler against the housing and pry carefully from side to side with a large screwdriver. After working on it, plug it in outside to a ground-fault ac plug on a fireproof surface to test.
Posted on Nov 30, 2007
Ian Prins
  • 11 Answers
SOURCE: toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Posted on Dec 06, 2007
SOURCE: Digital Display no longer showing, lever won't stay down
YOU HAVE A DEFECTIVE DIODE THAT LITES THE LCD. A .99 CENT PART. SELLER SHOULD REPLACE THE TOASTER WITH OUT QUESTION.
Posted on Sep 30, 2008
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
GE toaster model 169100. : the lever to toast won't stay down. I researched removing the base to clean the magnets, but not regular Phillips screws. Suggestions??
I have the same GE toaster and now my lever won\'t lock in place when I push it down to cook my toast. The handle does not pull off and when you turn the toaster over there are no screws to take the toaster apart. So I guess I have to say this is a disposable toaster but I am extremely bummed because it is beautiful and match decor and microwave that has the same color scheme as my toaster.
I wish companies would stop making cheap junk that doesn\'t last more then a few years.
Sep 06, 2013 | GE small appliance toasters 169100 User...
De Longhi CT021.A x 2 slice toaser - Won't stay down
Is it plugged in. You may have to do a little handy work, unplug the unit and look to see where it catches when the handle is in down position, you may have to open the bottom door. There is a little catch when the handle is down it may need to be bent a little not much.
Oct 15, 2012 | DeLonghi RT200 Retro 2-Slice Toaster
Tthe lever on my Braun HT 600 toaster won't stay down. 3 years old, but very moderate use. Ideas?
Be sure to unplug toaster first. While inverting your toaster, depress the toaster lever(s) and shake toaster to clear all bread crumbs. It can take up to several minutes of shaking to clear them completely, however, the key is to depress the toaster levers down at the same time. Also, remember to remove bread crumb trays and empty regularly, as the trays are too shallow and allow crumbs to build up quickly, thereby blocking the "locking mechanism" of the lever(s).
If after cleaning your toaster out thoroughly, the levers still won't remain depressed, try various outlets throughout your kitchen. Oftentimes, when one GFI (Ground Fault Indicator) trips, several outlets along the same circuit will also trip.
Also, there is a website called Manuals.com, which has a very good database of many manuals for various manufacturers and models of toasters, should all of the above efforts fail.
I did all of the above and fixed my toaster within five minutes. :- )
Good luck to you.
Yvonne
Jul 28, 2011 | Braun HT600 2-Slice Toaster
Lever will not stay down unless you hold it down to cook the toast
The latching relay is either faulty, or the timer module has faulted. That usually happens when the Toaster has a "Fault" on it. I suspect that the Timer has faulted. Toasters really aren't usually fixed, but if you have a handy appliance repair shop why not get a quote, for a repair, or replacement.
Mar 25, 2010 | Breville CT75XL 4-Slice Toaster
I just bought this kenmore 2 slice toaster and the toast lever won't stay down!?
Make sure it is set dark enough. Some toasters will not stay down if they are set too light.
Feb 11, 2010 | Kenmore 135101 2-Slice Toaster
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Dec 27, 2007 | Kitchen Appliances - Others
When i push the lever down to make toast, it does not stay
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Oct 21, 2007 | Cuisinart CPT-60 Custom Control Total...
Toaster lever wont stay down
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Toaster broken???
Feb 23, 2007 | Kenmore KTES4 4-Slice Toaster
Open Questions:
Very hard to remove the plastic cover from the toaster - Must Release Circuit Card First To my fellow owners of a KTT261. We have enjoyed using our KitchenAid toaster for many years but it eventually got so gummed up we could no longer reliably push the handle down to make toast AND it would also fail to latch or stay latched until the toasting cycle was completed. Not wanting to throw it out I wanted to try repairing it, but there was little info available online. So if you ever need to remove the plastic cover for maintenance here are a few tips. Of course UN-PLUG THE TOASTER COMPLETELY AND LET IT COOL DOWN TO ROOM TEMP!!! Remove the 4 screws on the bottom, two on each narrow side holding the top plastic cover to the bottom and pull off the plastic handle on the right which drops the bread down into the toaster cavity. That is the only obvious task. You will now notice that the cover still can't be removed because something on the right side near the front control panel isn't letting the cover detach from the base. That something is the control panel itself mounted into a white plastic holder glued to the cover and it's very short ribbon cable joining the two electronic circuit cards on the right near the handle which are mounted to the base. What to do. Using a long pair of needle nose pliers, or very small fingers and a long narrow screwdriver -or- all of the above and a second pair of hands, you must release the credit card sized front control panel electronic circuit card from the white plastic holder glued to the blue plastic toaster cover. This is not easy, but ultimately I was able to do it with my wife's help and repaired the toaster nicely. The control panel circuit card is held into the holder by a plastic latch at the top middle of the card. The latch protrudes thru a hole in the card. The bottom of the circuit card fits into 3 finger grooves on the holder. So the task is to release the upper plastic latch by moving it upward, while pushing the card away from the white plastic holder glued to the toaster cover then it will lift out of the bottom groove and be free of the cover. Then you can remove the cover completely, examine and fix the latching mechanism ...etc. IMPORTANT - Remember to study how it was held in originally, what orientation the parts were to each other, because the even harder part for us later after fixing the toaster latching mechanism was to reverse these steps and re-insert the control panel circuit card back into the holder...oye! There is just barely, ...barely, enough length in the ribbon cable connecting the control panel card to the base electronics to do this. Putting it back together was made difficult, because the upper plastic latch on the white plastic holder which secures the control panel circuit card to the cover against it's membrane switches required an enormous force to get the circuit card to latch. I thought I was going to break the card itself, but it did snap into place, barely. Good Luck, "I'm pullin for ya, we're all in this together" (Red-Green)
Jan 18, 2012 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
See all KitchenAid KTT261 Ultra Power Plus 2-Slice Toaster Questions
KitchenAid KTT261 Ultra Power Plus 2-Slice Toaster Logo
207 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Carmen Mikulic
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
