Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Governor does not seem to work - Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
    Sergeant:
  • 259 Answers
Sometimes the governor gear inside the engine breaks and you have to replace it. Did you try to adjust the governor by putting the throttle full and unloosen the screw on the governor arm and push the governor piece the same direction as the throttle opens and tighten the screw.
Posted on Mar 21, 2011
  • dwerty6 May 23, 2011
    When I start my mower (John Deere L120, Briggs 20 HP) It revs full throttle. Could I have screwed up the governor when replacing the crankcase gasket.
  • Tim Venetis May 23, 2011
    It is possible you might want to pull it apart and check the governor assembly
My 22hp Kohler engine back fires through carb won't start, need to know how to adjust the governor.
that isn't a problem with the governor, that is pre-ignition. The spark is firing too early. Normally because the engine needs timing, or because of overheating.
It seems to be a known problem, so have a read.
22 hp kohler engine backfire through carb Google Search
Apr 01, 2018 | Garden
Adjusting the carburettor springs on a mountfield sp530 to run correctly
most governor springs do have slack... they are designed to apply pressure during operation... the governor tries to run the engine wide open, the governor spring brings it back to a safe usable rpm... most small engines run well between 3200~3600 rpm's... I don't know what engine you have so I can't help more
Oct 20, 2014 | Garden
How to adjust the Governor on Honda Engine
Automatic governor. Replace or rebuild carb. Ensure float is functioning properly..
May 30, 2014 | Honda Genuine oem harmony ii hrr216...
Revs racing on Vanguard twin 18hp
down load the manual pdf file from B& S on the model you have.
Jan 23, 2013 | Tools & Hardware - Others
Toro briggs OHV runs too fast
throttle spring could be broken stretched or missing
Nov 14, 2012 | Toro Lawn Mower With Toro Power Tools
2000 Dodge Durango - P1757 GOV Pressure Not Equal
I have had to replace the governor on those dodge transmissions, and there is a filtering metal mesh screen around the governor inlet port that seems to always get plugged up with small metal shavings. The governor is located under the transmission pan to the rear of the main valve body.
May 05, 2010 | 2001 Jeep Grand Cherokee
10 hp briggs runs at high speed, govenor don't seem to be working
One possible cause for this problem is debris,sticking,or frozen linkage between the governor and the throttle butterfly. Depending on the make and model of your engine it will either be a mechanical governor that has a arm that goes down into the case or a air vane governor that is behind the recoil shroud of the engine. Move all the linkage that connects between the governor and throttle and speed lever to make sure it doesn't bind or sticks. If it does pray a little silicone or wd 40 spray on it to help reduce friction. Also on air vane governors they can become stuck from debris that inhibits it from moving make sure there is nothing in the way of the governor. If all of the linkage is working properly and you still have the issue try adjusting the the fuel mix screws and the high rev. settings on the throttle lever (if equip.).
Jan 29, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Engine revs wide open when starting
Check to see if the throttle shaft on the carburetor is actually moving (with engine off) Does it slow down when you move the throttle control on the dash?
Start it up and try moving the linkage on the governor shaft, if there is little or no resistance but the engine slows when you move it, most likely you have a broken governor gear inside the engine. Another possibility is that the screws that hold the throttle plate to the shaft have come loose and the plate is jammed in the throat of the carburetor
Sep 14, 2009 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
3,188 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
