Question about Microsoft Windows Vista Ultimate Edition
Connectivity - Network Printer
I'm trying to add a network printer to my laptop (Win Vista) w/out favorable results. I keep getting told that:
Windows can not connect to the printer. The printer driver is not compatible with a policy enabled on your computer that blocks NT 4.0 drivers.
What kind of assistance can I obtain from YOU?
Thanks,
Chauser
I am having windows vista home basic in my computer. I am not able to share files to other computers connected in my network. also, I am unable to view network computers in my network. How to enable network computers visible.
Posted on Aug 03, 2008
CAN THE DELL AIO 948 PRINTER BE USED FOR SHARING
Yes, If it is connected to a computer on your home network, right click the printer, setup sharing. For example, if you have a laptop on the same home network, Add a network printer to the laptop and print wirelessly without a wireless printer. This may help clarify: http://windows.microsoft.com/en-US/windows7/Install-a-printer-on-a-home-network OR http://windows.microsoft.com/en-US/windows-vista/Install-a-printer-on-a-home-network
Dec 31, 2012 | Dell 948 All-In-One InkJet Printer
Tip
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Office Equipment & Supplies
Fs-1118mfp not printing over the network
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Network printer win 7
If the driver is already available and you're getting the error "Windows cannot connect to the printer" and "Operation failed with error 0x0000000d" in the detail,
I found a solution from Vista that can be adjusted to work in Windows 7:
1. In "Devices and Printers" click "Add a Printer"
2. Select "Add a local printer"
3. Select "Create a new Port" and use "Local Port" as the Type
4. Enter the Network Path to the Printer (ie. \\ComputerName\SharedPrinterName) as the Port Name
5. Choose the printer from the list
6. Choose whether you want to use the driver that is currently installed or replace it
7. Name the printer
8. Choose whether to share the printer or not
9. Choose whether to set the printer as the default printer or not
Jan 07, 2010 | Kyocera FS-1118MFP Laser Printer
Can I use my Kodak 5300, installed as my network printer on a desktop running Windows XP with my new laptop running Vista? If so, do I run the install disk (with Vista drivers) on the laptop or what?
you should be able to as long as there are Vista drivers available.
make sure you first share your printer from the desktop it is attached to. then on the Visa laptop try to Add Printer choosing network printer (as opposed to local printer) and browse for the shared printer. Vista should tell you it has to install software so allow it to. Have the disk ready (does it have Vista drivers on it do you know?).
Word of caution: Vista's a little quirky with networked printers so you may have to delete the printer on the laptop and add it back if it doesn't work the first time (I had to do that even though all machines involved were Vista :/ ).
Cheers.
Mar 31, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hp Vista Laptop won't communicate with XP desktop when trying Prt
u have share your printer and add your printer in laptop u have to connect both pc in lan (local area connection ) or u can use the cross cable of lan when both pc connected then u have share your printer in xp then u have to add the printer in your vista laptop by using printer add visrd there is option on it u have to select the network printer & add it in to vista then u can print it
or
there is onther way u can install your printer in a laptop u need ur printer vista download
Jan 17, 2009 | Office Equipment & Supplies
HP 4550 PRINTER PROBLEM
Go to Control Panel\Hardware and Sound\Printers and add a printer. Select it as a network printer, and stop it searching (unless it finds it of course - which sounds unlikely!) Then click on "The printer that I want isn't listed"
Choose to add a printer using the IP or hostname, and click next.
Type in the IP address of the printer. This can be found by printing out the network configuration page from the printer. The port will be filled in for you. Click next.
The printer should now be added.
Dec 10, 2008 | HP Color LaserJet 4550n Printer
Printing from XP to a Brother 7820N as a networked printer
We have multiple 7820s in our office. This would be a configuration problem with your windows XP computer. From the XP computer, open a command prompt and type "ping x.x.x.x" where x.x.x.x is the ip address of the 7820n. Make sure you get four successes. I would then uninstall the brother software and drivers and go to "printers and faxes" in the control panel and manually add the printer.
To manually add a network printer, with it's own print server, on Win XP:
1 Click "Add Printer"
2 Select "Local Printer Attached to this computer"
3 Deselect "Automatically detect and install my Plug and Play printer" then click "Next"
4. Click "Create a new port" and select "Standard TCP/IP" from the drop down. Click "Next". this will open TCP/IP Wizard
5. Type in Printer IP Address next to IP Address (Port name will autopopulate) and click "Next"
6. If wizard finds printer, it will show you "Finish" button. If you get a "Additional Port Information Required" window, something is wrong with your printer or windows xp network configuration.
7. When the TCP Wizard window closes, it will take you back to Add Printer Wizard. Select "Have Disk" and navigate to the \USA\WXP\Addprt directory on your Brother Drivers disc.
8. Select brxpadd.inf and click "Open" then click "OK"
9. Select "Brother MFC 7820 N Printer" from the list and click "Next"
10. Select name of printer, whether you want a default, print test page and DONE!
Jun 12, 2008 | Brother MFC-7820N Printer
Asus 802.11 a/b/g wireless adapter problem
The problem could be with the wireless network that you are trying to access, or it has something to do with you wireless card tcp/ip protocol.
where you using the same computer now, when you had this issue with the vista? or is this win XP pc that you have now is a different computer?
if you are getting limited or no connectivity, that means that the access point (wireless signal) is not giving you a valid IP address.
you can try to add static to your IP settings, but this will only work if you knew the IP range of that network that you are trying to access.
please provide more info
Mar 25, 2008 | ASUS (wifibralinkuay) 802.11b Wireless...
Connecting to hpdeskjet 5550 over network with windows vista
make sure that your printer is shared in the network. you can uninstall the previous cd driver from the add/remove programs then reinstall again.. make sure to reboot your computer after fresh install is done
Jan 28, 2008 | HP DeskJet 5550 InkJet Printer
Microsoft Windows Vista Ultimate Edition Logo
122 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
