I have a whirlpool washer. Model MTW6600TBO. It is giving me an UL error code.
  • Greg Smith Mar 22, 2011
    its is giving this code complety empty.
  • Greg Smith Mar 23, 2011
    Thanks
  • Washing Mach... Master
  • 1,902 Answers
Hello & Welcome to FixYa
UL error means unbalanced load, If the load is unbalanced, the washer will display this code while running an imbalanced load correction routine at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load then close lid and press START. Please get back to me if you have any other questions.
Kevin
Posted on Mar 21, 2011
  • Kevin White
    Kevin White Mar 22, 2011
    The problem is then with the clutch assembly.
    President:
  • 1,554 Answers
The problem is either the wash impeller is restricted, the basket is not getting fully disengaged during the fill or the basket is not getting fully reengaged after draining. As the machine fills, the basket floats until the drive shaft and basket splined hubs disengage. The machine/motor controller operates the motor intermittently while the machine fills to detect whether the basket is disengaged by analyzing the current drawn by the motor. When the current drawn by the motor is more than what it should be when the basket is disengaged, the machine continues to fill until the basket disengages and the current drawn is nominal. The machine then overfills and flashes the fault code when the current drawn by the motor does not drop to its nominal value either due to the basket cannot disengage or the wash impeller is restricted. As the machine drains, the basket drops and the basket reengage for the basket to spin.
Small garments can get caught under the wash impeller and restrict the impeller. It will cause "oL" code
to flash during the wash cycle as if the machine is overloaded or "UL" during the spin cycle as if the basket is unbalanced. Remove the wash impeller and inspect it.
Insert the blade of a small screwdriver into the slot in the impeller cap, then pry the cap up, and remove it.
Remove the 7/16? hex-head bolt holding the impeller to the drive shaft, then lift and remove the impeller from the basket. Lift the basket to remove the impeller easily.
Raise the washer top to the service position then take the basket out to inspect the drive system including the hubs if the wash impeller is not restricted. Dirt accumulation can wedge the hubs and prevent the basket to fully disengage. Clean the drive system including the hubs and it should resolve the problem.
Tape the washer lid closed then using a putty knife, press and unlock the two front top locks located approximately 6-1/2" from the outside edge of the washer and then raise the washer top. The basket can now be lifted put of the tub with the wash impeller removed and the washer top raised.
Let us know if you need further advice. Please accept the solution should you find it helpful or informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Mar 22, 2011
What does code uL mean. this comes on in the drain spin cycle
Hi, a UL error code means a load not balanced. The washer is running a load-balance correction routine. Please allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.
Aug 14, 2016 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Maytag bravos top loading washer; LD error and all lights blinking. It seems to be draining now after I turned off and tried rinse only
Why is my Maytag Bravo washer Model #MTW6600TBO ...
www.shopyourway.com > Manage My Life > Questions
May 12, 2010 - LD error please check for the following: Check for kinked or clogged Drain Hose: ... Bravos® Top Load Washer w/ PowerWash® System.
Aug 08, 2015 | Maytag Washing Machines
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Ul code on empty machine
Sounds like you need to replace the bearings... not a difficult task. http://appliancejunk.com/forums/index.php?topic=8960.0
Mar 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have an error code on maytag washer model # mtw6600tbo what does code mean
Error codes are given whenever the washer has a problem. Could be overuse of soap to overloaded clothes. Who knows? You ain't said what the error code is. Their are several styles of these machines. The Oasis, the Bravos, and the Cabrio are all tailored after the Fisher and Paykel washers. I have written a tip which features the error codes HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 30, 2011 | Maytag Washing Machines
Kenmore Oasis washing machine is giving me a UL code with every wash now. Do I have to call for service or can I fix it myself?
See the following Whirlpool Service Manual for their Cabrio washer which is the same as the Sears Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
You may get an idea of the (UL Unbalanced Load) problem and solutions.
Mar 30, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My new Whirlpool Cabrio stops repeatedly with the UL flashing it never finishes a wash load, do you have a step by step CD explaining the use of this washer? I am about to return it to the store and get a...
I believe this model has a defective control board under the control panel. The new control board has longer times between the drain and the spin. Eliminating the unbalance when it tries to spin with water still left in it. Also check for slow drain this will enhance the problem. The control board is a warrany repair if covered.
Mar 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
