Question about Minolta bizhub 200 Copier
Need help changing default copier paper size from 11 x 17 to 8.5 x 11 bizhub 200
  • Minolta Master
  • 6,696 Answers
Go user settings/choice setting tab #6 set default tray to what you want
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 22, 2015
4 Suggested Answers
NALDZ
  • 38 Answers
SOURCE: Cannot print on 11 x 17 paper from one program.
U MUST NEED PROGRAM THE SELECTION OF THE PAPER TRAY...MOSTLY U SEE ON THE THE PAPER TRAY PROGRAM
Posted on Nov 30, 2008
  • 92 Answers
SOURCE: canon ir 2016 digital copier
you can have 1 of 2 problems.
the cassete paper are in A4 position ,or you can trie to clean the registry roller.
Posted on Nov 02, 2009
xeerie
  • 347 Answers
SOURCE: bizhub 200 Copier: Copier says malfunction...
if copier is saying malfunction, then look it will also showing the code, note the code then inform me...........
Posted on Jun 18, 2010
Paper type for 8.5 x 11 paper was reset to A4. I want it to be LTR. How do I change back?
I would start with the easiest solution, look to see if there is any paper jammed behind the paper tray. There are switches behind the paper tray for paper size. Also, make sure the paper tray guides are in the correct position against the paper in the tray, they tell the copier the paper size. Good Luck
Oct 31, 2013 | Minolta bizhub 200 Copier
By pass tray on bizhub 250 only detects letter when i place an A4 paper, how do i make it detect A4
Clean the paper size sensor and change the by pass paper tray size setting on the display "Paper tray change" setting mode.
Mar 16, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub c200 giving message put paper in bypass tray
Check your default paper settings in your setup menu. Also, check the paper size is set correctly on you paper trays for the type of paper that is in them. Make sure that the documents that you are printing are set to proper paper size that is in your printer. All the issues, will cause this condition plus some. But those are the easiest, let me know if it continues. Good Luck
Jun 04, 2012 | Minolta bizhub 200 All-In-One Printer
Bizhub C350 envelope problem
Load the envelopes in the bypass tray select paper on the copier control panel select by pass tray change tray select normal DO NOT select envelope select custom enter size, on printer preference select envelope tray and print
Apr 18, 2012 | Minolta bizhub 200 All-In-One Printer
Paper size
check default setting with bypass try
usually it is letter size change into the a4
Apr 21, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Deleteing an incoming fax job that has stopped printer . The incoming job has the incorrect paper size.. and i cant choose that paper size. I can not delete the job as usual, the delete button does not...
On most Bizhub Copiers if you have something stuck in memory that is tying up the machine you can turn it off and unplug it from the wall for 10-15 seconds and then turn it back on. Doing this will erase the Random Access Memory and should clear all fax and print jobs from the machine.
Aug 12, 2009 | Minolta bizhub 200 All-In-One Printer
Printing envelopes
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
Jun 29, 2009 | Minolta bizhub 200 All-In-One Printer
Changing Mode?
There is no way to change your machine into printer mode only. machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE. So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
Jun 23, 2008 | Minolta bizhub 200 All-In-One Printer
Bizhub 200 printing custome envelopes
Do not know if this helps, but I could not print Com 10 envelops until I said the type was "normal" - Type "envelope" would tell me I had the wrong size.
Dec 12, 2007 | Minolta bizhub 200 All-In-One Printer
Minolta bizhub 200 Copier Logo
46 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
