Question about SkyGolf SkyCaddie SGX GPS Receiver
When i turn on my skycaddie SGX I get a rose.exe error and it freezes this is the first time i am using it I tried the 8 seconds...no work...i & flag held down , press centre b, no work. I really don't wabt to take the back of to remove battery. I assume that is where it is.
4 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: sgx skycaddie will not shut
perform a soft reset(a forced restart basically ) . hold power and joystick for 8 seconds. it will turn off. now turn on. if boots up correctly, then ok. if not, then perform hard reset.(remember that this will delete any information already installed..) push the information button (i) and flag button at same time. while both buttons are pressed turn on power. you should be in recovery mode. if so, re-sync.
Posted on Sep 03, 2010
SOURCE: My new Skycaddie sgx had a install problem and now
just wodering if you got the problem sorted. i have similar issue
Posted on Jul 17, 2010
  • 1417 Answers
SOURCE: i have just bought a
Hello.
If you have the update installed, your Sky Caddie Legend willdisplay the information on startup. You can also change the owner information.You may want to change the information if you purchased the GPS used, ornoticed an error in the information.TOLLS NEEDED AND INSTRUCTIONS ARE STATEDBELOW.Software update 2.42 or higher1 Press the "Thumb Stick" to display the Sky Caddiemain menu.2 Scroll down with the thumb stick and select"Options." Tap the thumb stick to enter the menu.3 Select "Owner Information," and tap thethumb stick to enter the folder.4 Enter or change the current owner data (Name,telephone, etc.). Scroll down with the thumb stick and select "OK."Thanks.
Posted on Sep 30, 2011
I can't get my skycaddie to move.It's like it's frozen
Hi Dorothy,
The first thing you should do is remove the battery. After replacing the battery make sure it is completely charged. After that, turn your skycaddie back on and it should work normally. Make sure that you are outside with an unobscured view of the sky. When you secure access to satellite your GPS should record your movements larger than 50 yards or less. I would use my phone to verify my exact location.
Cheers,
Dr. Bob
Jun 11, 2015 | SkyGolf SkyCaddie SGX GPS Receiver
I have a SGX and have lost the antenna cover. Can I find a replacement?
Stay AWAY from the SGX. The quality control is really poor. I know of three other users having the same problem, the antenna cover falls off and the unit does not get satelite reception. It becomes a piece of junk. Once that unit got replaced, in less than 5 months, the rubber covering the knob that allows you to select items had a tear and now the unit is no longer waterproof. This is not covered under warranty and they want you to pay $89.95 for a replacement. I am done with SkyCaddie. I have just purchased the new Garmin G6, awesome device, no annual fees, long battery life and touch screen enabled.
Look at the following link to get other user experiences.
Amazon com Customer Reviews SkyCaddie SGX Golf GPS
Feb 09, 2015 | SkyGolf SkyCaddie SGX GPS Receiver
On starting skycaddy sgx, I get the following message on screen: application servicesd.exe encountered a serious error and must shut down
Find the maual or go to ther website. see if they have a software fix for it if not you are most likely going to have to reinstall the software. Errors like these are startup errors and there is no work around that i know of.
Nov 04, 2013 | SkyGolf SkyCaddie SGX GPS Receiver
My skycaddie is frozen [happened when i tried to sync] and will not turn off. tried the soft reset but to no avail......what's next?
The only thing you can do is dis-connect the rechargeable battery for at least 60 seconds, this should clear the microprocessor.
Apr 13, 2011 | SkyGolf SkyCaddie SGX GPS Receiver
My skycaddie froze in transferring while connected to skycaddie sync. i cant get it to turn off or exit.
perform a soft reset. hold power and joystick for 8 seconds. it will turn off. now turn on. if boots up correctly, then ok. if not, then perform hard reset. push the information button (i) and flag button at same time. while both buttons are pressed turn on power. you should be in recovery mode. if so, re-sync.
Aug 15, 2010 | SkyGolf SkyCaddie SGX GPS Receiver
SkyGolf SkyCaddie SGX GPS Receiver Logo
534 people viewed this question
Top SkyGolf GPS Experts
Oloyede Monsuru
Marvin
Marvin
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
