Question about Epson Pro Cinema 7500ub Projector
I have the Epson Powerlite Pro Cinema 7500 UB projector. I recently noticed that when the screen is black, I have a few color specs on the screen. I just knowticed this 2 days ago. Prior to that it was fine. Is that caused by dust? I did about 2 months ago have a bulb explode. Could it possibly be pieces of glass inside the unit causing the color images on the screen? Does it sound like I just need my projector cleaned or does it sound like I might have a major problem with my unit? Thanks' for your help!!!
5 Suggested Answers
chilibball
  • 85 Answers
SOURCE: blue dots in the middle of the screen
The image processor must be getting old and worn out. Call Epson or go onto their website and see if it is  a dDIY project or if you will ned to send it in.
Posted on Apr 27, 2008
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
zabolyx
  • 38 Answers
SOURCE: images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
BILLatNASA
  • 3 Answers
SOURCE: How do I reset the lamp hours on an epson
EPSON PowerLite 7250
Reset the lamp counter hours in 3 steps
1. Make sure, your projector is ON
2. Hold down the Help and Menu buttons for 5 seconds.
The "A.S." screen will appear.
3. Hold down the Tracking and Tracking - buttons for 5 seconds.
Posted on Sep 20, 2010
One Blue line is on the screen
open up the projector and you will see a small screen attached to the lamp and a Flex Cable attached to the screen,
Remove the cable and Clean it with Alcohol Liquid from both sides then put it back and check.
Aug 02, 2015 | Epson PowerLite Home Cinema 3020 LCD...
What should i do when my projector's temperature light is flashing red 30 sec after start up?
try changing the light bulb. they have a time limit on them. with mine, I had to change the light bulb. Not cheap, but it worked for me.
Nov 12, 2014 | Epson PowerLite Home Cinema 8350 3LCD...
Epson powerlite home cinema 8100 problem with picture
Dark pictures after a lamp change normally indicate that the lamp isn't aligned properly, or that it has been touched with bare fingers and caused a black mark, or it's an inferior (budget) lamp.
Aug 30, 2014 | Office Equipment & Supplies
Epson 5010 can't open
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Mar 05, 2014 | Epson ELPLP69 - V13H010L69 Projector...
Blue light flashes, lamp doesn't light
competitive price.
have a nice day!
Jerry Lampdeng Lim
Mar 04, 2014 | Epson ELPLP69 - V13H010L69 Projector...
My epson projector center is blurry
Hello, if it's mounted you may have never adjusted the "focus" on it before. Just slowly turn the end grey colored lens one way or the other with a stationary picture such as the menu on the screen, adjust it to where the lettering is the sharpest.....tks
Nov 09, 2013 | Epson Powerlite Home Cinema 8100 Home...
Red haze at bottom of screen
Shut down the projector and allow time to cool before the lamp is taken out to be examined for any dis-coloration. If so the lamp needs to be replaced, try to test using a leased lamp to confirm Also check for shift in the alignment of the lamp settings and also the Lamp alignment.
Dec 15, 2011 | Epson PowerLite Home Cinema 8500UB...
Can the epson projector 8700ub be used in Australia with our power suppy being 230 volts? Thanks. Mr Tay thengtay@hotmail.com
Rated frequency 50/60 Hz AC Power supply 100 to 120 VAC:
3.1 A (Home Cinema 8350) 3.3 A (Home Cinema 8700 UB) 200 to 240 VAC:
1.3 A (Home Cinema 8350) 1.5 A (Home Cinema 8700 UB) Power consumption 100 to 120 VAC: Operating: 272 W (Home Cinema 8350) 297 W (Home Cinema 8700 UB) Standby: 0.2 W 220 to 240 VAC:
download the manual for this model
Techbelkin
thanks for rate me.
Jan 08, 2011 | Epson Power Supply 110/200 VAC Switchable...
I can't change the aspect ratio on my 1080 UB. It's locked in the "normal" view? How can I override this?
hi,
first of all check the video setting of ur DVD player or satellite receiver which ur connected to the projector. in its video setting select output video format aspect ratio as 16:9. the projecter will output the format what it get in its input.
u can elect the aspect ratio in the projector remote just press the ASPECT button to select different format
ok
Dec 31, 2010 | Epson PowerLite Home Cinema 1080 UB LCD...
Epson PowerLite 83+ goes completely green or red
make sure the signal matches. you could reset the settings to factory default.
Nov 10, 2009 | Epson PowerLite® 83c LCD Projector
Epson Pro Cinema 7500ub Projector Logo
87 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
