Sears (whirlpool) Canyon capacity washer wouldn't spin clothes dry and kept giving an sd code at 6min mark on rinse/spin cycle. I took the back off the machine and removed a penny from the pump, replaced the pump and ran a wash while I watched to see what was going on if the code came up again. Then I noticed a big black blob swishing around in the water of the machine-between the wash drum and water basin of the machine. After looking at it carefully it appears to be a giant blob of lint. The wash ran through okay but there is still water at the bottom of the basin and the clothes are wetter than normal. I think the lint is clogging the water as it gets down very low from getting into the pump as it is spinning them dry. When I did a wash with soap it ran through the cycle but left suds on the clothes because the water left in the bottom of the machine spins so fast it becomes very sudsy. My question is how to get that lint out. When you take the pump of the machine the opening th the water catch basin is covered by a plate so I can't just stick my fingers in a pull it out. Any ideas would be appreciated. I really don't want to remove the drum, I think it is out of my level of technical ability. Thanks!!
  • 2 more comments
  • gosullivan Mar 21, 2011
    Thanks I will look for the model number when I get home and respond.
  • gosullivan Mar 22, 2011
    Sorry for the delay.
    The machine is Kenmore Oasis HE, Model 11027062601
    Type 580 Series CT3471092
    It is a top load machine, no agitator and was bought new around 2005/6.
    Thank you. I will try to muster up the courage to attempt this over the weekend. It looks like I can manage it. I'm a bit unclear on step 4, but when I get there it will probably make sense. I will contact you with questions during the process if I need guidance. Not to worry about timing on replies I realize you can't respond immediately. My biggest fear is putting it back together incorrectly and causing bigger problems. Any thing to be extra careful on during re-assembly??
    Thanks so much for your help
  • gosullivan Mar 25, 2011
    Well that was easy enough to do. It was a SOCK!! I ran a load, I'm still getting a lot of suds left on the cloths and they aren't as spun dry as they used to be, but much better than before. One thing I've noticed is that if I take the drain hose out of the stand pipe on the spin cycle and put it in a bucket about a foot lower it drains more and the clothes are dryer. If I hold the drain hose up the same height as if it were in the stand pipe it stops draining. Could the pump just not be running at full power? It sure seems to be spinning as fast as alway. I've checked the impellers in the pump, none are broken or missing. Any thoughts? We have septic, it could be full, we've had lots of snow melt, but no water is back washing into the machine I watched for that. Also, I am not getting Ld or Sd codes. Thanks for any ideas you might offer.
  • Washing Mach... Master
  • 2,605 Answers
Welcome to FixYa.
I'm pretty sure I know what you're referring and in fact I can explain what needs to be done to gain access to this "lint ball" or sock or whatever it is ( via removing the tub...it's pretty easy once you see how ) but I'll need you to provide the model number to be sure and save time potentially explaining irrelivant information.
I'll watch for your post and we can go from there. Thank's for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Mar 21, 2011
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald Mar 21, 2011
    Great. Thanks for the reply. I will watch for the model number in your post.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Mar 22, 2011
    Hello again,
    Thank you for the reply, the timetable is at your convenience...I just hope I can accommodate most of the time with different time zones on-line as we all are.
    Your machine is as I suspected, so we'll begin by telling you how to access the inner basket area.
    **First unplug the washer... safety first**
    1) the top needs to be lifted, this is best done with a puddy knife or something similar to depress the clips on both sides, i.e. (these tops are quiet heavy and the lid has heavy springs so be careful...leave the top in the "up" position until you can rest the entire top against a wall or something to allow you to work un-impeded as show below as well )
    Lean it back if possible...watch that lid again, those springs are heavy duty.
    2) remove the re-circulation hose clamp for the top deflector/splash guard...and remove the guard via the clips around the tub.
    Pull's off,
    3) remove the "agitator" assembly (we'll call it that anyway)...first the cap, then the 7/16" bolt, pull straight up (you may need to wiggle it back and forth until it lets loose )
    7/16' bolt,
    4) once removed you'll see the outer basket hub, you may not even need to remove this via the philips head screws...sometimes it helps to loosen it, but don't take it off completely. Then the entire assembly will lift out ( again you may need to wiggle it around )
    Then you'll see a small plastic cover over the pump outlet/sump area. It's a good idea to remove it and check around or clean out.
    That should give you a pretty good start or in fact all you need to clear up the lint ball problem. Let me know how you make out and we can go forward from there if necessary. Good luck.
    I'll be watching for your post on progress/completion.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hello again,
    Let me know when you're tackling the job.
    In step 4 I'm referring to the hub in the center which has 6 philip head screws holding it in place...you'll see when you get down that far. If not I'll be around to assist you for sure.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Mar 26, 2011
    I didn't realize you had posted a reply/result I must have missed it.
    Anyway, Glad to hear you found the culprit, socks are very common. I think I may have mentioned that, but anyway. As for the drain issue, It isn't possible for the pump to only run at half or anything like that. In theory it could be receiving only half the voltage, but in that case it would not run at all. I would be curious how your drain hose/pipe is arranged. Insure it isn't shoved into the stand-pipe any more than 4"-6" and that the drain hose isn't too high...typically just to the top of the washer is sufficient. Other than that you may want to run a few cycles without any items on "hot" and add just white vinegar ( no detergents ) to purge the tub & lines of soap/detergent build-up.
    Hope that helps get you to a completed resolution. Please remember to take a moment to rate my assistance and a brief testimony is really appreciated.
    I will continue to help in any manner I can from here of course as well.
    Regards,
    Macmarkus :)
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Not spin drying the clothes
check to make sure the pump is not restricted or drain hose kinked.
May 20, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Water not draining out w/ spin cycle
sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
