Question about Bosch Washing Machines
Bosch wfd2460 washing machine..fault water pouring out of machine drum even though mchine is switched off and door was open, please help
    Brigadier General:
  • 6,277 Answers
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill! It's not closing correctly and closed is its 'default' and no power position.
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Posted on Mar 21, 2011
Hi, I am not able to open the door of my Whirlpool washer dryer AWZ 5140 E after it finishes the cycle. It shows up E13 with ticking noise. There is no water left at this stage and I am able to open the...
E13 is a dispenser error the appliance diagnostic believes the appliance is full of water so won't release the lock first thing to try is the drain filter bottom right hand corner at the front unscrew it clean and refit just be prepared it's likely u will get some water out it when u remove it.
Dec 08, 2013 | Washing Machines
Open the door
This is either blocked pump, pressure chamber or a heater fault. The door will not open if there is excess water in the drum (check filter) or if the pressure switch does not drop out to indicate drum is empty (pressure chamber blocked). If the unit does not heat during the cycle the unit will time out and you have 1 min left on display (heater short or open circuit). Probably not a PCB fault but a specific component. Turn the machine off at the mains for a minute and then select a cycle but don't start the machine, the door should opne after a minute or two if the fault is not one of the first two mentioned above. There is a slight possibility that it is the door lock itself.
Hope this helps
Apr 10, 2013 | Bosch Washing Machines
Hi! re BOSCH washing machine WET 2820 Program will start, and then for 30 secs approx start normally, water starts to enter the drum. Then it stops, nothing happens. I have cleaned the soap dispens
BOSCH washing machine WET 2820 This video will show you how to change the door eal washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 07, 2011 | Bosch WET 2820 Front Load Washer / Dryer
Hi, I tried inserting a drill bit and turning clockwise (into the Bosch Nexxt 300 washer) but the little round door won't release. I can feel the spring inside depressing when I push in the drill bit....
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 09, 2011 | Bosch Nexxt 300 Series WFMC2201UC
HI, I have a Bosch Maxx5 washer/dryer. I have an F18 error on my screen and some water is still standing in the machine. I am trying to open the little circular door at the bottom right of the mahine. It...
Suggestions-
John C
Aug 26, 2011 | Washing Machines
Bosch Excel 1200 washing machine stops at spin cycle, doesn't seem to be draining properly. If I open front drainage hatch to let water out the machine will start its spin cycle. Happening every wash...
Your filter will be clogged, causing the empty pump not to drain in time (usually they get about 8 minutes and fault out). If the picture I have of your machine is correct, there is a small door at the bottom of the machine on the right. Open the door, unscrew the filter, clean and replace and all should be well. NOTE: It's worth tipping the machine back by 45 degrees when you do this so any water left in the machine doesn't pour out, but having a couple of towels to hand would still be a good idea.
Please add a comment if the above has not fixed your problem and I will try to help further
Aug 23, 2011 | Bosch Washing Machines
Our Candy CNA135 washing machine will not drain the water and the filter wont open?
Suggestions- pour anticalc/limescale fluid into any gap there is around the cap then also empty the machine and you can switch it off providing the door is open! Pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
John C
Apr 29, 2011 | Washing Machines
Washing machine won't complete cycle by draining and spinning unless i turn it off then set it to spin.The drainage cap at base of machine will not unscew enough to open either. please help
Here are my guidance notes on what I did ;-0)
ALSO CHECK THE MOTOR'S OPERATION WHEN THE FILTER IS OUT- JUST IN CASE IT IS STRUGGLING AGAINST GUNGE!
Good luck
John C
Mar 03, 2011 | Bosch WAS20160UC Front Load Washer
E o4 displays. will not unlock. tried pouring
turn off at mains checking no water left in drum should release after that sound like faulty door lock or not draining fully, it wont let you open the door till the water has gone well below the door seal.
Oct 27, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
WFD2460 Bosch washing machine
WFD2460 Bosch washing machine This video will show you how to keep your soap draw clear and how to service the parts
Sep 02, 2009 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
43 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
