Cannot connect to set up page http://192.168.1.1
    Problem Solver:
  • 7 Answers
There is a number of things that can be the issue here. First of all make sure you have the right ip-number. If it is a Linksys router it should be the 192.168.1.1 adress you wrote. If it is a D-Link or Netgear router it's usually 192.168.0.1. Other router ip's might be 192.168.123.254 or 192.168.2.1.
If you have the right adress make sure there is nothing wrong with the cable you are using. But since I'm guessing you can connect to other pages I would suggest doing a factory reset of the router and try again.
You do this by holding down a small button on the router for a certain amount of seconds, usually until the router lights up all of the LED-lights and then goes back to normal. The button is often "hidden" in a small indent.
I hope this helps!
Posted on Mar 21, 2011
Tip
Make Firefox Faster To Load Pages
Here's something for broadband people that will really speed Firefox up:
1.Type "about:config" into the address bar and hit return. Scroll down and look for the following entries:
network.http.pipelining network.http.proxy.pipelining network.http.pipelining.maxrequests
Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading.
2. Alter the entries as follows:
Set "network.http.pipelining" to "true"
Set "network.http.proxy.pipelining" to "true"
Set "network.http.pipelining.maxrequests" to some number like 30. This means it will make 30 requests at once.
3. Lastly right-click anywhere and select New-> Integer. Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it recieves.
If you're using a broadband connection you'll load pages MUCH faster now!
on Apr 02, 2010 | Computers & Internet
How can I determine my current WEP key setting so that I can connect a new computer to the network?
You can find it in router configuration page. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings then wireless security then note down the WEP key it is your password to connect wifi. Let me know if you need further assistance. Thanks for using FixYa.
Aug 10, 2010 | Linksys Wireless-G WRT54G Router
WHERE DO I FIND A WPA SECURITY PASSPHRASE FOR MY LINKSYS
Use an Ethernet cable to connect the network-port on your computer to one of the LAN ports on the router.
Start Internet Explorer.
Access: http://192.168.0.1 or
Access: http://192.168.1.1 or
Access: http://192.168.2.1
to access the web-server software "inside" the router.
Login, and run the "Wireless Network Setup Wizard",
to choose WPA, and to set a password or a passphrase.
Aug 01, 2010 | Linksys Wireless-G Broadband Router
How it's The connection has timed out?
For that go to your network adapter tcp ip property and enable ip get automatic so it gets ip from router.
If still not able to access then press RESET button for 10 seconds it is in back side of router.
Then all settings defaults.
Then Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Jun 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I dont know my security key or passphrase
http://192.168.0.1
or
http://192.168.1.1
Then click on wireless and then wireless security then change wep password because it is in * or # format then save settings and restart router then you can connect with that code.
Apr 23, 2010 | Linksys Wireless-G WRT54GS Router...
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Access routers configuration and wireless filter to edit MAC List to add MAC adress
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Then check wireless or wi fi settings you find there MAC filtering or mac security edit that list then save and restart router.
Dec 10, 2009 | Computers & Internet
How to open settings of motorola SURFboard SB5120 modem?
Support for the Motorola SB5120, discontinued product, see next site:
http://broadband.motorola.com/consumers/support/default.asp?supportSection=DiscontinuedProducts
Connecting the device, see the "Quick Reference Guide":
http://broadband.motorola.com/consumers/products/SB5120/downloads/SB5120_Quick_Ref_Guide.pdf
For installing the modem the easiest way is to run the provided cdrom.
When not available perform the settings as showed in the guides.
Motorola 5100 series user guide:
http://broadband.motorola.com/consumers/products/SB5120/downloads/SB5120_User_Guide.pdf
See page 7 "Before You Begin" for the requirements and selecting either USB or Ethernet connection.
Page 22 gives the overview for the pages how to configure ethernet settings.
Oct 31, 2009 | Arris SURFboard SB5120 Modem
Computers & Internet Logo
David Payne
David Payne
