Question about Samsung Refrigerators
Filter has turned red, do not know where filter is located.
    Guru:
  • 1,524 Answers
Open the refrigerator and look in the upper right hand corner.
If not there it is through the grill on the bottom.
Posted on Mar 21, 2011
How to change water filter?
Hi
Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill.
Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 07, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Where is the filter on my rs2630
Removing and replacing a water filter - inside liner location
Filters situated in the interior liner of the refrigerator compartment of Samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Grasp the filter and make a one quarter turn to the left. There should be an indicator line located on the filter bracket cover. The install mark on the filter itself will line up with this indicator line.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard the used filter.
  4. Remove the new filter from its packaging, and remove the red plastic cap from filter cartridge.
  5. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  6. Line the install mark on the filter up with the indicator line found on the filter bracket cover. Push up on the filter. Turn the filter a quarter turn to the right to lock it in place. The remove mark on the filter should line up with the indicator line of the filter bracket cover.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Aug 19, 2011 | Samsung RS2630WW Side by Side Refrigerator
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Jul 29, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Installation of new water filter for model # ED2FH
This unit has the filter in the grill.
Removing and replacing a water filter - base grill location
. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Feb 12, 2011 | Whirlpool Refrigerators
Where is the water filter located and how do i replace it.
The water filter is located in the fresh food or fridge side of the appliance, at the rear - in the upper right hand corner.
To change the filter, open the fridge door, clear the top shelf and grasp the filter. All that is needed is to turn the filter to the left about a 1/4 turn for it to drop down. A few drops of water may spill onto the shelf. To install a replacement, remove the protective cover (shown as a red cap above), and position under opening for filter. Gently push upward while turning the filter to the right. The filter will pop in, and as you turn about 1/4 of the way around, it will be drawn up a small amount until seated. At this point it will no longer turn any further.
More info about the filter is below (taken from the manual).
Please rate this reply - thanks!
The water "Filter Indicator" light
• "Filter Indicator" light lets you know when it is time to change your water filter cartridge. The light
will change from green to orange. This tells you that it is almost time to change the current cartridge.
It is recommended that you replace the cartridge when the light changes to red. (see "Install the water filter" section for more information)
• If you install water filter, throw away the first six glassfulls of water filter, or until water flows clearly to flush impurities in the water supply system.
Using the dispenser without the water filter
• You can not use the water and ice dispenser without a water filter cartridge because the water line
blocks at water supply.
Ordering replacement filters
• To order more water filter cartridges, call 1-800-SAMSUNG and ask for accessory Part # DA29-
00003A or contact your authorized Samsung dealer.
Jan 04, 2011 | Samsung RS265LABP Side by Side...
Where is the filter located in the refrigerator?
1. Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
2. Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill
3. Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
4. Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
5. Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Jan 03, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have a ED5PHEXRQ00 refrigerator. The red light
Your filter is located in the grill of the refrigerator (below your doors) and has a small plastic "handle" or "knob" on it. Turn the handle counter clockwise so that the line of the handle points up and down and pull out the filter. Save the handle to slide onto the new filter. I also believe that you will need to press the light switch in the refrigerator five or six times to re-set the filter status.
Filter is part number 4396710
Jun 27, 2010 | Whirlpool Refrigerators
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
Filter light has turned red
If there is a circle in the grill at the bottom of the fridge it will be there.
Dec 21, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
