I have "tradition" free standing
    Brigadier General:
  • 4,736 Answers
If you've checked the auger for jams and there was nothing there, check the receptacle the auger is plugged into to make sure it's working and a circuit breaker in your home's circuit breaker hasn't been tripped. If it has been tripped, reset it to see what happens. If it trips again, check the electrical outlet for wear or a loose wire. If everything checks out alright, you will need to replace the auger motor or the circuitry that operates it automatically.
Hope this helps you troubleshoot and solve the problem.
Posted on Mar 21, 2011
Stove will run for 5 to 15 mins and the auger will stop feeding.
Are the pellets getting stuck or jammed in the auger? Take a look at this website and perhaps it will give you some ideas to look at:
http://www.pelletstovefires.com/pellet-stove-problems.html
Nov 22, 2017 | Pool & Spa
No flame. The auger works fine and the pellets are feeding in. There is no fire to burn them.
Do you have a user's manual? Most pellet stoves need to be lit before starting the auger to sustain the fire.
Feb 10, 2017 | Cars & Trucks
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Traditions the earth stove. how to operate
Try these people who seem to be main dealers.
http://woodheatstoves.com/stove-manuals-earth-stove-user-manuals-c-291_217.html
Nov 03, 2015 | Us Stove Company USSC Eco-Aire Window...
How do i fix ager on my pellet stove?
Hello Ethan, First I would uncouple and remove the auger motor from the auger shaft. Next turn the stove on to see if the auger motor turns. If it does turn, try to hold the motor shaft with your hand to determine if the motor has sufficient torque to turn the auger. If motor seems to be strong enough , use a pair of pliers or a vise grips and try to rotate the auger shaft. If the auger will not turn, it might be clogged up with pellets or pellet dust. The clog will have to be removed. If that is the case, I think the gears in the motor are stripped and a new motor is in order. Note: Damp pellets swell up and turn hard as concrete when they dry out.
Dec 06, 2013 | Home
Pellet stove
vacuum switch helps all to work and power supply if more than 2 bends in the exhaust can b a problem to there is a intake air lever on the back of some that allow more or less vac pressure in to the chamber auger will not turn if door is open to create the vacume
Dec 02, 2013 | Heating & Cooling
We have an Envirofire pellet stove. The auger won't shut off and we can't control the the speed. We had to unplug it. Any thoughts?
You didn't mention which model Envirofire Pellet Stove you have, but generally they all have a heat overload switch, which stops the auger from feeding pellets if the stove gets to hot. They may be faulty. Or The Auger Timing Control Module may have failed. Depending on the age of the stove the gasket material around the door may need replacing. If it's not a tight fit, it's sucking air into the stove and causing it to run more than it should. Normally, I would say, "If all else fails, contact their Technical Service Dept." But, apparently they don't want the consumer contacting them, as there is no contact info on their website. Nor, is there any contact info on the manufacturer's website, Sherwood Industries. "Any technical service questions should be directed to your local dealer."
Hope this helped to get you headed in the right direction in solving the problem.
Mar 13, 2011 | Heating & Cooling
I clean the stove as discribed in the tape i got w/ the unit. But, in about 8hrs. burn time , fire box is over full and feed tube is backed up. I have air wide open and lowest feed setting. Any ideas . If...
That is an old pellet stove. One problem may be that you have recently switched the type (Manufacturer) of pellets. Not all manufacturers make the pellets the same way. So you would have to re-tweek the auger feed an the air intake to the stove. If you no longer have your Owners Manual try searching Google for the Manufacturer and contact them for advice. But, I suspect that the model you have is no longer manufactured, as it does not meet the current EPA standards for emissions.
Jan 27, 2011 | Heating & Cooling
Cheap charlie pellet stove/pel-pro runs for 10min then shuts down
The auger is controlled by a T-stat on the side of the combustion chamber. Open the side of the stove and you can see the auger motor and the thermostat that feeds it. It has a manual reset button on the back of the thermostat, press it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 05, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
