Question about Canon NP 6035 Copier
Error code e010 - Canon NP 6035 Copier
  • Canon Expert
  • 270 Answers
This is the code for the main motor. Something is making this motor work extra hard and not rotate as fast as it should. Take off the back cover and turn on the copier. See what direction the motor is turning. See if you can make it move by rotating the motor in the right direction. The fuser may be binding, the drum, or developer. You will have to isolate the problem. I've never had to replace a motor but yours could be a first. Good luck.
Posted on Apr 14, 2011
Toshiba 256 error e010
E010 is paper jam error, u need to check where the paper stop...
Mar 22, 2018 | Toshiba Office Equipment & Supplies
Canon ir 2018n error code e010
check the drive of the main motor >may be a broken gear .If that is ok then check the main motor in another machine.If that is also okie then u have got urself a fried DC controller PCB.Replace it
Mar 28, 2012 | Canon Office Equipment & Supplies
How to fix error E010 fo canon ir1600
I am getting the Error "E010 Locked" can you help me how to unlock.
Feb 27, 2012 | Office Equipment & Supplies
I have canon np 6650 it shown E010. i have try to reset, checking the fuse on the dryer paper please help me
if error E010 occure, it means your Main motor not running,
motor or motor drive board or mother board problem,
if show E010 after running the main motor, check motor driver board or mother board,
but 99.9% case of E010, cause of main motor problem so check the main motor first,
Aug 11, 2011 | Canon NP 6650II Copier
Once the np 6050 is turned on it displays error code E010 switch off and on again
E010 code is main motor lock. Open front cover, Release Transport/Fixing Unit tray. Pull the tray out untill it stops. Try rotating the larger knob to see if Fixing unit will turn...if not, raise the exit/stripper assembly to check for jammed paper. If no paper present and the Unit turns freely, reinsert Transport/Fixing tray into copier. Latch into place. Close front cover. Power on machine.
It is possible that the main motor has failed, but not likely.
Jun 19, 2009 | Canon NP 6050 Copier
E010 error code is a main motor lock .
Check for jammed paper in the Fixing unit.
Pull transport/Fixing Unit tray out and rotate large knob on left side to check Fixing unit for obstruction/turnability. Other than this, it could be main motor failure.....
Jun 08, 2009 | Canon NP 6050 Copier
Canon NP 6030 Error code E010
chiudere sportello superiore destro
Oct 04, 2007 | Office Equipment & Supplies
Canon NP 6035 Copier Logo
78 people viewed this question
old marine
old marine
