Question about Cameras
My webcam shows blurry pictures and videos of me
  • 262 Answers
It's not obvious, but the ring around the lens is actually a focus ring: turn it until the picture is sharp.
Posted on Mar 21, 2011
Can youi show me how to fix my webcam so i can get clear view , because i do not know how?
Step 1:
A webcam is first and foremost a camera that uses a lens to gather light reflected by an object. There are a number of reasons why the image captured by the webcam can be blurry, all of which can be remedied. Supplies from a photography store or hobby shop, along with items that most people already have in their homes, are needed. The webcam does not need to be disassembled in any way in order to obtain a sharp and clear image.
Launch the webcam's video program by selecting it from the "Start," and the "All Applications" menu. Aim the webcam towards you so that you can see the blurry image presented in the program's video window. Rotate the knurled focus ring that surrounds the lens at the front of the webcam until the image is sharp; if there is no focus ring, position the webcam closer or farther from you until the video image is sharp. Blow off the lens at the front of the webcam with compressed air. Moisten the end of a cotton swab in photo lens cleaning solution. Wipe the lens with the moistened end of the swab, beginning at the center and rotating in a circle until you reach the outer edge. Wipe the lens dry with a lens tissue in the same manner as was just done, to remove the contaminants that caused the blurry image. Launch the webcam video program that is on the hard drive. Select the "Advanced" or "Options" tab at the top of the program's main window -- depending on how the program is set up to bring up a settings window. Reset the "Sharpness" control to 65 percent of the total possible, using a slider control or entering "65" in a text field. Click the "Apply" button at the bottom of the window, followed by the "OK" button to sharpen the image transmitted by the webcam.
Feb 12, 2013 | Logitech Webcam
I bought the Frontech Diamond webcam and installed the CD and the message shows its successfully installed, as its requested i restarted my system. After i open my cam,, the light will ON but in the CAM...
check if your USB cable is properly plugged.
Also try connecting your webcam directly to your PC instead of through a USB hub
if your webcam's image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Other picture quality problems with webcams can be addressed by changing the video capture properties for the webcam. Most programs that can use a webcam will have an option to access the properties of the video source, which will bring up the video capture properties window.
Feb 13, 2011 | Cameras
Blurry webcam video
check the webcam lense it ajustable turner on it turn it to clear picture just
ok bye..............................
Nov 11, 2009 | Computers & Internet
Video becomes blurry when object is moved using
Most web cameras are that way. cams are rated on there refresh rate. Higher the rate the better the picture and higher the price.
Aug 30, 2009 | Microsoft LifeCam VX-3000 Web Camera
Picture from Philips webcam blurry/unfocused.
my picture is really unclear in the webcam and can't adjust the video setting on the preferred setting. can u help me,please?
Jun 26, 2009 | Philips SPC230NC Webcam
I just installed Logitech 9000 web cam and the video is blurry
The black face plate. Turn to the left and the right untill the picture become clearer. You will need to manually focus the cam
Feb 05, 2009 | Logitech Webcam
Movement causes bluriness
I have a expensive webcam as my main one and a cheap webcam as my less used one and my cheap one does exactly the same thing
It is called Ghosting and there is nothing that can be done about it, it is just a poor quility webcam
Dec 26, 2008 | Logitech QuickCam Connect Webcam
Blurry pictures
TRY TURNING THE RING IN FRONT BY LENS CLOCKWISE OR COUNTER CLOCKWISE,RICHARDM69
Dec 14, 2008 | Logitech QuickCam Connect Webcam
Picture is blurry
You should physically set focus on the cam
Dec 30, 2007 | Creative Labs Video Blaster WebCam NX PRO
Cameras Logo
48 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
