Question about Dryers
Dryer timer wont rotate dries just fine - Dryers
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 21, 2011
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
Apr 05, 2013 | Washing Machines
Our dryer is not drying as it has in the past. Have checked the vent, drum rotation and heat, but still does not dry clothes properly. Any suggestions?
If the vent and the heat are fine then the only other thing that could be going bad is the timer motor. The timer motor tells the dryer how long to heat the clothes.
Apr 06, 2010 | Whirlpool LEW0050P Electric Dryer
Dryer does not heat up nor does the timer rotate as dryer runs could the timer be broken causing the dryer not to heat up?
IF you have the timer set in the auto dry setting, then it will Not advance if it does not heat. Set it on the time dry and monitor if the timer now advances.
A no heat issue can be one of many failed components--i.e. thermo fuse, ignitor, coil assembly etc
Affordable Appliance Repair
Serving South Orange County, CA since 1982
(949) 855-0788
Oct 28, 2009 | Amana DLE330RAW Electric Dryer
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Broken dryer
Sounds like a timer problem let me know I can help you..
May 28, 2008 | Roper Dryers
Dryers Logo
Top Dryers Experts
