I read about just ground the parking brake wire it should serve your purpose. Don't
need a code, just get a toggle switch and hook that to the yellow/blue
wire and with the other side ground to the small lil screw where you
will see a small lil short wire and then all u have to do is fallow the
screen with the e brake but just flip the switch 3 times with the whole
one sec then off for 3 sec then on.
I quote the post from other owners problem...
The
way you bypass the E Brake is you have to ground the wire to the radio
sleev itself. There are two different peices. The radio itself and the
sleeve that holds the radio in place. Take the yellow wire (the ebrake
wire, not the yellow ignition wire) and open the metal connector up just
slightly. Attach that wire to the top of the sleeve on 1 of the teeth
located near the front of the unit. You have to make sure that the
connection is good or it will not ground. Next slide the clear plastic
over the wire so the only connection is with the tooth.
Then Insert a
cd or dvd in the player. Press play on the remote and then push stop 2 X
times on the remote. After you have done that press 26604 on the
remaote and then press enter. This will permanently unlock the parking
brake feature and allow you to watch dvds while in motion. The anti theft default code is 0000. If you need
any further help you can eamial me at [email protected]
END.
Hope helps.
