Question about Cameras
USE A NIKON F-801S GET THE MESSAGE ERROR fEE 8 and a bip bip bip sound the film is new/ battery full / use a lense Tamron af
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Turn the aperture ring on the lens to its smallest opening (largest f/number). If the ring has a lock, lock it in place. You can control the aperture from the camera, the same was as on a lens without an aperture ring.,
Posted on Mar 21, 2011
Error: FEE on Nikon AF N6006 film camera with Nikon lenses.
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as with a lens without an aperture ring.
Feb 05, 2013 | Nikon Used N6006 AF 35mm SLR Autofocus...
Want inexpensive 2x af teleconverter for d70 nikon lens 80-200 ed
You can order the Tamron 2x teleconverter here. Be aware that not all lenses are compatible with teleconverters, and you can actually damage some lenses by trying to use them with a teleconverter.
Jul 14, 2012 | Tamron 2x Auto Focus Teleconverter with...
Is tamron af 35-90 compatible with nikon d200?
Tamron makes lenses with a variety of mounts. Assuming the lens has a Nikon mount, then it is fully compatible with the D200.
Aug 05, 2011 | Tamron AF 35-90 f4-5.6 for Nikon AF
Is the nikorF AF 35 to 105mm Lens compatible to Nikon D7000? How about tamron 70 to 210mm with 52 adaptor?
The Nikkor lens is fully compatible. The Tamron is dependent on the mounting. Tamron makes lenses for a variety of cameras. A lens with a Canon mount, for example, will not fit onto a Nikon camera. If the lens has a Nikon mount, there should be no problem using it with the D7000.
Remember that the D7000's sensor is smaller than a frame of 35mm film. This will cause the lenses to produce a field of view that is smaller than on a 35mm camera. The 35-105mm, for example, will give a field of view similar to what a 53-160mm would produce on a film camera.
Jun 05, 2011 | Cameras
What nikon camera will this mount to
Tamron is a third party lens manufacturer and make lenses to fit all popular makes of cameras both film and digital. I'm sure the top two would be Canon and Nikon. So if the lens you have there is a Nikon Mount it will fit Nikon Auto Focus cameras both film and digital
Jan 04, 2011 | Tamron AF 28-200mm f/3.8-5.6 LD Aspherical...
I have a Nikon d3000 and a Tamron AF 55-200mm lens. I cant get the lens to autofocus with my nikon
The Nikon D3000 does not have a focusing motor built-in, relying on the lens to have a motor. The Tamron AF 55-200mm does not have the necessary motor; it only auto-focuses with Nikon cameras that have the motor in the camera body.
For Nikon lenses, you need lenses designated AF-S. For Tamron, you need lenses designated USD and/or BIM.
That probably wasn't the answer you wanted to see, but there it is.
Aug 08, 2010 | Tamron 55-200mm f/4-5.6 Zoom Lens for...
FEE message in display when using 50mm lense
The FEE message indicates that the lens is not set to smallest aperture (highest number). The camera body expects this so it will have full control of the aperture. It sounds like you may be accidentally bumping or turning the aperture ring on the lens while using it or changing lenses. There is a little slide lock to lock it at f/22 to prevent this. Turn the aperture ring to 22 and move the slider so the white dot is next to the orange mark on the lens barrel.
Feb 28, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon D40x
you will not have AF...only MF
full list of compatible lens for your camera here
Oct 16, 2008 | Tamron SP AF 11-18mm f/4.5-5.6 Di II LD...
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Cameras Logo
82 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
