Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
CAN I MOUNT MY HANNSPREE 22 INCH (HF229H) MONITOR TO THE WALL?
JUST NEED TO KNOW THIS FOR IT WOULD BE AWSOME IF I CAN.
  • Fran Bednar
    Fran Bednar May 11, 2010
    Mount it to WHAT !!??
    IF posting a question, try to be alittle more forthcoming in your information Otherwise you won't get help, just laughs.
    FYI: CAPS INDICATE SHOUTING !!
SOURCE: Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Posted on Aug 13, 2008
  • 44 Answers
SOURCE: No XP driver for Hannspree New york 19 inch monitor
Hi David,
Thanks for the comment regarding what type of computer equipment that you have. The integrated video card that you are using definitely is not designed for the widescreen monitors and will not work properly with the widescreen (as you have noticed). The solutions that you can use would be to get a non-widescreen standard monitor or install a new video card that has widescreen capability.
Hope that helps,
Take care,
Michael
Posted on Nov 17, 2008
SOURCE: Compatible with Mac?
HF229H Native res. 1650x1050
Powerbook G4/800
Mirror mode limits ext. monitor to 1280x854 max
    Analog Monitor Modes: (VGA using DVI-I adapter)
  • 512 by 384 (60hz)
  • 640x480 (60,72,75,85Hz)
  • 640 by 870 (75Hz)
  • 800 by 600 (56,60,72,75,85Hz)
  • 832 by 624 (75Hz)
  • 1024 by 768 (60,70,72,75,85Hz)
  • 1152 by 870 (75Hz)
  • 1280 by 960 (75Hz)
  • 1280 by 1024 (60,75Hz)
  • 1600 by 1200 (60,70,75Hz)
  • 1792 by 1344 (60Hz)
  • 1856 by 1392 (60Hz)
  • 1920 by 1440 (75Hz)
  • 2048 by 1536 (75Hz)
  • Digital Monitors: (DVI - 60Hz)
  • 640 by 480
  • 800 by 500
  • 800 by 512
  • 800 by 600
  • 960 by 600
  • 1024 by 600
  • 1024 by 640
  • 1024 by 768
  • 1280 by 800
  • 1280 by 1024
  • 1344 by 840
  • 1600 by 1024 (native 22" Cinema display mode)
  • 1600 by 1200
  • 1920 by 1200 (native 23" Cinema Display mode)
Posted on Nov 20, 2008
SOURCE: Hannspree HF229H monitor and Windows XP. Images stretch to fit.
I had this same issue.
Go into the monitors menu, go down to "Image Settings", go to "HDMI Mode", select "PC Mode"
Hope this fixes it for you. It worked for me.
Posted on Apr 28, 2009
SOURCE: Hannspree Monitor speakers wont work
I don't know if I caused the problem or not. I hooked up my new Hannspree HF237 monitor to my HP pc, and the sound wasn't loud enough so I hooked up my external speakers, and got nothing. So I disabled one without the other, and still got nothing. Now I can't even get the monitor's sound to come back on. Any ideas?
Posted on Oct 17, 2009
I cannot get good resolution in my Hannspree HF229H, what can I do???
The resolution you should be getting is 1680x1050. Under Windows 7, right click on your desktop then open 'Screen Resolution'. If the resolution is set to anything other than 1680x1050, set it to that. If that setting is not available then it is possible that your video card does not support that resolution. This would only effect old computers. If the resolution is set to 1680x1050 but you don't have the proper resolution onscreen, try adjusting the monitor settings using the buttons on the bottom of your monitor. Hope this help and have a nice day!
May 02, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree HF229H will not stay on
railbird56, Common problem for ALL BRANDS of "cold-cahtode-fluorescent-lamp" back-lit lcd monitors! Here are your options!!! Cheapest to most costly!! 1. Warranty repair. 2 DIY repair???? 3. Local or distant repair. 4. possible old + cash swapout with Hannspree for refurbished same model?? 5. Trade-in for new wide screen. My best guess on your monitor (no history) is that the unit's SMPS is in partial or full shutdown mode during it's black screen moments. How much do you know about "electronic ballasts" "switch-mode-power-supplys" and how to repair them?? 12fixlouie
Feb 22, 2010 | Hannspree HW191D LCD Monitor
Adjusting the horizontal & vertical to be proportionate
You need to set the correct resolution for your monitor,
To do this, minimize all windows, and right click on your desktop (not on an icon). Select properties, and go to Settings on the tabs on top.
Drag the slider until your resolution matches that of the monitor. I use mine on 1600 x 1050. However if your card doesn't go that high, try either the next ones down until it looks normal, or try a driver update for your graphics card.
Mar 05, 2009 | Hannspree Computers & Internet
When I plug in my hdmi set top box my monitor says no signal
If an HDMI cable won't work, try Component Cables.
I went through the same hassle as you.
Jan 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree will not supply XP drivers
i found a driver for my dell latitude d800 on dell.com. the download is r105341.exe. monitor works perfectly now.
Dec 15, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Native Reolution?
first, check outlet, make it sure that power is on the appropriate voltage. then your UPS and voltage regulator also. try to check all button switch and your video card
Sep 29, 2008 | Computers & Internet
Hannspree HF229H
I think that you have multiple displays enabled through your video card. Just disable multiple displays.
Aug 16, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
I have the same problem.  Did you find a solution or just return it?
Jul 21, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
HF229H MONITOR XP SYSTEM I NEED DRIVRES FRO XP OPERATING SYSTEM
there are no drivers needed for XP, only Vista. update your video card drivers so that you can set the resolution to the recommended setting.
May 23, 2008 | Hannspree HW191D LCD Monitor
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
106 people viewed this question
Top Hannspree Computers & Internet Experts
richie46
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
