Question about Nikai TK-018 Beard Trimmer
I just bought a Nikai HC38 hair clipper. It is a plug-in clipper, but when I plug it in and try to turn it on, it won't turn on. It is unused, but quite old. How can I turn it on?
How do I get my clippers to cut?
Try giving the blade an extra 1/2 a turn of tension, done by turning the red knob 1/2 a turn clockwise. It sounds as though the blades are jamming up which could be a lack of tension.
May 01, 2014 | Andis 68035 Progress Cattle And Horse Hair...
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
Nov 12, 2011 | Health & Beauty
I have an A5 clipper, with three blades. I have had difficulty with this clipper, ever since I bought it. I have a schnauzer with very fine, soft hair, a bouvier, with very thick hair, and a Lakeland...
hi, on some ocassions when the clippers get hot the metal gear shaft moves meaning the movement of the clipper is limited, you can remove they gears in the gearbox when its hot and see if there is any side to side movement.
Nov 26, 2010 | Oster Golden A5 2-Speed Universal Motor...
New clippers
what type of hair clipper are you looking for. mannyssharpening.com has very good warranty they fix what they sell
Sep 26, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
I HAVE A 115V USA HAIR CLIPPER.LIVE IN UK, SO
Look on the side of the clipper handle. You ahould see what appears to be a screw. With your clipper plugged in and turned on, turn that screw with a screw driver in either direction, the noise you are talking about should quiet down quite a bit,
Aug 21, 2009 | Oster Health & Beauty
Clipper blade
Try the link.It may help.
http://search.store.yahoo.net/cgi-bin/nsearch?unique=40afd&catalog=shavers-and-replacement-parts
Jun 01, 2009 | Braun Cruzer 3 Electric Shaver
Clippers jam and won't cut when trying to use attachments
OIL THE CLIPPERS AND CLEAN THE HAIR OUT REALLY GOOD.
Jan 11, 2009 | Oster 76076-010 Hair Trimmer
Hair Clippers not clipping
for Shorty8 adjust power screw,check connector fork,if too tight losen tension inside the clipper
Aug 28, 2007 | Andis 01690 Hair Trimmer
Nikai TK-018 Beard Trimmer Logo
35 people viewed this question
Top Nikai Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Nikai Health and Beauty Expert? Answer questions, earn points and help others
