Question about Jenn-Air JCD2389G Side by Side Refrigerator
Water doesn't stop
My water dispenser works great, however water continues to flow for a few seconds. The problem seems to get worse as the water flows for longer and longer every year. The unit is in a summer home and is drained over the winter.
  • RFOX Aug 04, 2008
    water doe not stop...had a repair man out replaced electronics for $250 but it still did not work.....i think it is an intermittent problem caused by the elasticity of the rubber used in the boot which covers the mechanical lever which you push your glass against when you want water. If this was a thinner rubber or better rubber resilient material you definitely would not have this problem. The trouble is I do not know if Jenn-Air has solved this problem and that a new boot would do any good if it were the same material.
  • 943 Answers
Hi thanks for the question the problem seems to be a water valve especially a summer home sediment from well water gets stuck in the water valve or just a weak spring in the water valve i would replace the valve thanks the appliance doc
Posted on Sep 17, 2008
Filtered water dispenser not working; water seems to be going into fridge instead
This could be a freeze up in the line or blockage or the filtre is plugged and needs changing. If you go to the website and type in the model number there is a lot of information there as how to service it.
Mar 06, 2014 | GE Q Series GSS23QGT Side by Side...
GE Profile Arctica PS123SGNA every fall the water dispenser stops working although the ice maker continues to work. Any ideas??
Strange, obviously the colder days dont effect the ice harvest so water is still coming in, has to be the water dispenser itself or the water filter may be freezing up stopping the flow.
Nov 24, 2013 | Refrigerators
Changed filter and now water flow is limited
If the water shutoff valve has a seal like a faucet instead of a saddle valve it's possible a piece of it has broken off and is partially blocking the water line to the fridge. Check the line to see if you can see it or disconnect the line at the inlet to see if the filter screen is plugged.
May 10, 2017 | Maytag Refrigerators
My Matag water dispenser is behaving strangely. When I press the dispenser button, water flows for about one second, then stops, and seems to switch briefly to ice dispensing before resuming water flow for...
Hi Alan,
You need to check the wires on the back of the dispenser console to be sure that they are seated correctly. If the wires are all OK, you will need to replace the display console. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 08, 2012 | GE GSH25JFR Side by Side Refrigerator
Old filter in and water started to sputter, made clunky noises and flow very slow. Removed filter and used plug - water ran fine not filtered.- Replaced with new Maytag filter and water sputtered, flow...
Hello there, when new filters are fitted usually they are expected to spurt for a little bit before they normalize and begin to flow properly. Dispense water continuously for 10 minutes. This usually arises when the flow of water through the unit not being allowed through properly and usually takes the new filter a couple of minutes to get accustomed to the water flow and get water circulating through all its components hence the spurts. Alternatively you can check to ensure that the water supply is turned on full and the filter is properly fitted. If all of these are in place then the dispense mechanism might be faulty.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 23, 2011 | Maytag MSD2756G Side by Side Refrigerator
Water dispenser dripping water all the time
First be sure the refrigerator is connected to a cold water supply. After connecting the refrigerator to a water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, and then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until a total of 12 L has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system, water may spurt out of the dispenser.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Hope this will be useful.
Thank you
Jan 04, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
New water filter, very slow water dispensing
you have to reset the pressure stabilization feature in the water filter circuit before it will deliver a continuous flow of water . sometimes the directions are on the filter itself . if not , you'll have to look it up in your owner's manual or perhaps go online to obtain the information .
Mar 13, 2010 | KitchenAid KSCS25FKSS Side by Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Jenn-Air JCD2389G Side by Side Refrigerator Logo
78 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
