Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
When I turn my oven on, it goes to 100 degrees and does not heat up. Continues to click as if heating up, but remains cold. I have unplugged the unit and plugged it back in, in hopes of resetting the control panel. No luck. what could be wrong?
  • Jenn-Air Master
  • 3,053 Answers
Hello, katrina
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and fartherback, It appeared that no one answered some of them, So, I thought Iwould take some of my personal time to see if I can help. Even though this sitemay not have your exact model or brand, this link will help you tons. Here is alink to about everything you want to know about your oven, from
repairto trouble shooting it. Even pictures and video's. Just scroll around and youwill see tons of information to almost any question you might have on yourOven. If you go to this link and click around, I am sure you will find out somuch about your oven, you will know more than the company that made it. Thegood thing about this link is, then you can make the decision of DIY or hiringa pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help andsome kind words written would be appreciated for my free help , I wouldappreciate it. Here is also my direct link to my own pages of other areas of myexpertise for other problems you might have in Automotive,Appliance, andElectronics. Drop In anytime for my help. Thanks, Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Riello 40 gasG900 burner that will ignite but when oven reaches temperature it turns off completely. After temp drops by 4 degrees it turns back on and reheats back to temp then turns off.Why is this?
that would be normal. if it didnt shut off, it would go above the set temperature. the heat is either off or on. it cant me in the middle. it turns 'off' so that the temperature doesnt go too far above 250. when it senses the temperature falling too low below 250, it heats it up again.
Sep 03, 2017 | Ovens
Oven won't heat above 100 degrees
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 23, 2011 | Electrolux Ovens
The oven will not turn off even though both dials are in the 'off' position. The light remains on and the fan continues to run. The oven continues to produce heat.
Hi make sure the knob on the switch is not loose and slipping on the switch. hope I can help Regards Billy
Feb 24, 2011 | Ovens
Turn the oven on to preheat, it beeps says that it is preheated but heats at about 100 degrees less than what I have set it for. This just started.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
Oven won't heat up 100 degrees continues to show on console
Is this a 120VAC. gas range or 240VAC. electric ?
It sounds to me as though it is gas and the bake ignitor is faulty.
If it is 240V AC. You've likely got a control issue or source voltage problem.
Try swapping out the ignitor, that should allow the oven to ignite. The reason it is only showing 100 in the display is the ignitor is the only source of heat. If it is left like this long enough it will also destroy the bake burner assembly as it is likely a hot surface style. so try and fix it asap.
hope that helps,
Good luck
Oct 17, 2009 | GE Ovens
Oven heats, but does not get to correct temperature as fast as it did, lower oven heats OK . When the pre-heat time is complete, oven was still 100 degrees less than designated.
when you first turn it on both elements should come on(your top element may be burned out)if so turn breakers off just take out the screws on the mounting plate pull out and take wires off and replace
Aug 25, 2009 | Ovens
After cleaning the top half oven with a self-clean cycle the oven will not pre heat past 100 degrees. The bottom oven will heat. What might be causing the top to malfunction? The serial number is...
usually it is the thermal cut off( TCO) ,a kind of themal fuse which goes out if the temp exceeds certain limit and cuts off the power to the elemnts.it is to protect the cavity from over heating.it needs to replaced or reset depending the model. u will need a tech to fix this.
Aug 21, 2009 | Electrolux Ovens
Oven will not heat past 100 degrees
More of a clarification request:
Is the oven remaining on all the time(oven light stays on)and the temp not going above 100 ,or is it going to 100 then switching off?
Aug 10, 2009 | Belling XOU270 / XOU271 Electric Single...
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
64 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
