I have the Microsoft Lifechat Lx 3000 headset, and I use Avaya IP Agent via VPN to work, and Windows 7 OS. I had a Logitech headset before and had same issue, so I don't think it's the headset. While trying to work, I loose audio, the callers can hear me but I am not able to hear them. I've tried to troubleshoot this with our Tech Support, and they tell me that Avaya is working fine. What puzzles me is it's so random, I get a couple calls that I can hear, and then the next call, no audio. If I push the dial pad on the Avaya, I may get the call back, if the dial pad responds. (doesn't always) The last couple of days, the beginning of the calls have also changed, before I would get a single tone that a call was there, and now it is broken up, and seems delayed, when I get it at all. This issue has been ongoing for several weeks, and now my job is in jeopardy and I need help!!!
  • Brad Brown Mar 12, 2017
    Hi tammythor998, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the make and model of the computer
  • 101 Answers
SOURCE: Can not access my ip address in order to change NAT settings
Hi Brengolfter3,
My guess is, the IP to your router is still 192.168.x.x. Only way you are going to be able to get to the router, is to set your machine to a static IP, and then try to get to the router.
This site tells you how set it to static, http://corz.org/comms/hardware/router/static.ip.address.php
The IP you listed is assigned to Easton Utilites, so I have asume it is your internet IP. You might want to check the Xbox troubleshooting for the Xbox, so you don't have to disable your Nat, which is a firewall, by default. Good Luck!
Posted on Jan 06, 2008
  • 139 Answers
SOURCE: WBR 2310 Reset Switch
Try this...
--Uninstall the d-link wizard software from your computer...if it actually installed.
--Shut down the computer and router...make sure they're connected together with the ethernet cable
--Turn on the router first.
--Turn on the computer
--Wait about 2 minutes after the computer starts up
--Go to the command prompt and type in the command "ipconfig". This will give you the computers ip address, subnet mask, and default gateway. To get to the command prompt, click on Start -- Run -- and then type "cmd" and click "Ok"
--The default gateway address should be the address of your router...typically it would be 192.168.0.1...but this will tell you if it's something else.
--If the ip address listed after the ipconfig command is blank or begins with 169.... then your computer is probably not talking to the router...the router or network cable may be defective.
--If the default gateway address is something other than 192.168.0.1 ...try that address in Internet Explorer to see if the router will respond properly. If the router responds, you can configure it directly without using the wizard software. Your D-link documentation (on disc?) will guide you through the manual setup procedure...sometimes referred to as the "alternative" procedure.
--Good luck...and I hope this helps!
Posted on Jan 12, 2008
mlake33
  • 427 Answers
SOURCE: Router seems to drop connection frequently
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
Posted on Apr 12, 2008
jgcalifornia
  • 160 Answers
SOURCE: Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Posted on Aug 26, 2009
Hi this is erum here and I've a head set of Microsoft LifeChat LX-1000 and Microsoft site said its not compatible with win7...
Hi Erum,
The hardware specification for this device is supported on Windows 7 also. The below link has the information from Microsoft
http://www.microsoft.com/hardware/en-us/p/lifechat-lx-1000#details
Did you check if the music is audible when it is plugged.
Aug 12, 2011 | Microsoft LifeChat LX-1000 Headset
I have a Microsoft LifeChat LX-3000 head set, it works perfectly fine with SKYPE but I can not get them to work if I want to listen to a YouTube Video. What am I doing wrong? Thanks...
Problem with the Microsoft LifeChat? LX-3000 Headset hi i just bought microsoft live chat lx3000 it works ok with skype or msn but how do i use it to listen to my music or how to instal driver
Jun 07, 2011 | Microsoft LifeChat™ LX-3000 Headset
Microsoft lifechat lx-3000 headset wont play sounds. all in windows points to it yet no go..thisis a usb device. thanks
my microsoft lifechat lx1.3,stop working after update windos!!i have redownloud it agein,at first say is blocked,and agein ,agein,i do not know why,i need help.
May 19, 2011 | Microsoft LifeChat™ LX-3000 Headset
Have the Microsoft Lifechat Lx 3000 headset, and I use Avaya IP Agent via VPN to work, and Windows 7 OS. I had a Logitech headset before and had same issue, so I don't think it's the headset. While trying...
I had the same type of problems using Avaya (road warrior set up - voip) through a vpn. I work at home on remote set up. I have tried changing headsets, using the telecommuter option in Avaya and going through my regular phone line and still had the same problem.
The company that I work for, suggested changing the order in which I log in to see if this solved the problem. I use to log into the computer first, and then double click on the vpn and enter my password and user name to start my work. They changed it to logging into the VPN at start up first and then continue to access my pc with the log in and password required for that purpose.
The sound quality is better using this method but it didn't stop the various sound issues that you spoke of in your question posted on fixya. It did reduce the number of problems experienced.
what I found that solved the issue for me was changing from the wired heatset on road warrior set up in Avaya to using my bluetooth headset from my cell phone instead.
My computer was not bluetooth enabled, so I went to Best Buy and bought an adapter by I/O Gear that works by plugging it in to your usb port on your pc. The adapter cost me less than $20.00. You install the software on your pc first, then put the adapter in your usb port and turn your bluetooth headset in to pairing mode. The computer picked up the signal quickly with my Plantronics Voyager Pro bluetooth headset. The sound quality is great. I am wireles and hands free for 300 to 550 feet and I have 9 hours of talk time after a single charge. This is a new set up for me. I have used it for about three weeks now and have not experienced any problems with hearing so far.
Give it a try.
Mar 21, 2011 | Microsoft LifeChat™ LX-3000 Headset
I just bought microsoft lifechat LX 3000m but i can't hear any sound when i used it to listen to music or watch movie. it has been installed already
Windows 7? If so then right click on the speaker in the notification area in the bottom right hand corner of the screen select playback devices, and right click on the headset and select "set as default device".
Mar 05, 2011 | Microsoft LifeChat™ LX-3000 Headset
I need to downlaod a driver for the microsoft lifechat lx 3000 it got erased
you can download the correct drivers here: http://www.microsoft.com/hardware/download/download.aspx?category=ICE&type=LifeChat&sku=JUG-00001
good luck!
Oct 15, 2010 | Microsoft LifeChat™ LX-3000 Headset
Just bought microsoft lifechat LX-3000 ,,,wnt work with windows 7
You can download the drivers to make your headset work from:
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=ICE&type=LifeChat&name=JUG-00001&os=Win7_3264&lang=en
Aug 12, 2010 | Microsoft LifeChat™ LX-3000 Headset
Is the LifeChat Lx-3000 Compatible with Mac Os X?
I bought the headset recently and on first plug-in --- nothing! But then I realized that I had to open Sound in System Preferences and select them as the output choice. Works fine, though I haven't had a chance to test it out fully. But it works!
Jun 05, 2009 | Microsoft LifeChat™ LX-3000 Headset
How do i connect the Microsoft LX-3000 Lifechat headphon to x box
hi
how do i connect the Microsoft LX-3000 Lifechat headphone to x box 360, i plugged the usb into the front of the x-box and its not working , i,ve got no drivers, but i can down load them , but what do i do with the drivers then?
Apr 16, 2009 | Microsoft LifeChat™ LX-3000 Headset
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
