I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
  • ybeech Dec 05, 2008
    My washing machine won't spin and flashes SE some one help please.
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Posted on Nov 22, 2008
My whirlpool amw8121 front loader won't spin. It
There should be a door-actuated limit switch which detects that the door is closed, which is probably defective. Look for the plunger, listen for the click. It is the most likely component to fail, and is inexpensive to replace if you're handy. Be sure to have your machine unplugged during repairs.
Sep 04, 2012 | Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
My westinghouse mastermind 708 is flashing SE or 5E? what does this mean please?
most home appliances have many ELECTRONIC components......these components are very sensitive to electrical irregularities that enter your home electrical system......these irregularities can cause some components to freeze up.......pull the plug and leave your westinghouse 708 unplugged for several minutes.......plug it in again and it will reset all of these control components........hope that helps!
Jan 07, 2011 | Westinghouse Washing Machines
Westinghouse mastermind 700 flashing HE
I just had to lighten the load. I think that HE means heavy. It works fine now.
Aug 24, 2009 | Westinghouse Washing Machines
SE shows on the display
Water Sensor Error. You need to have this changed as it has failed
Aug 15, 2009 | Washing Machines
Error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Oct 21, 2008 | Washing Machines
Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Aug 12, 2008 | Washing Machines
Washing machine dosnt spin dry, front loader westinghouse mastermind 708, 7.5 kg
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Jun 03, 2008 | Washing Machines
Washing Machines Logo
524 people viewed this question
Top Washing Machines Experts
