Question about Dewalt Garden
Please confirm the right gas for my Dewalt 3100psi max pressure washer and also the type of oil ?
    Sergeant:
  • 259 Answers
You can use cheaper grade gas at the pump and for oil use 10w30.
Posted on Mar 21, 2011
Hi, My Dewalt 3100 pressure washer pump wash leaking water from a check valve or overflow plug Do you know whats wrong?
The Dewalt 3100 came with 2 different pumps. The Blue Cat pump and the oil free pump that was made by DeWalt.
You may just have a bad Thermal relief Valve on the unit.
You can find the parts diagram at www.allpartsinc.com
Sep 08, 2011 | Dewalt DPH3100 Gas Pressure Washer
What type of oil do i put in the DPD3100?
In the Pump Dewalt recommends
DeWalt DP70 Pressure Washer Pump OilIn the engine Dewalt Recommends
SAE 10W-30 is recommended for general use
Jun 26, 2011 | Dewalt DPD3100 Gas Pressure Washer
Where do you add the oil on a DeWalt 3100psi pressure washer?
Hi and welcome to FixYa, I am Kelly
From reading everything I can find, i.e User's manual & parts manual the only thing you add oil too is the engine. The pressure pump does not have a liquid sump.
You can look at parts here detail D:
http://www.ereplacementparts.com/dewalt-dpd3100-pressure-washer-parts-c-1009_7440_7445.html
So too add oil to the engine you would remove the dip stick from the crank case located on the opposite of the side of the engine as the oil sensor.
I recommend you use 30 WT SAE oil for 3 oil changes then on the 4th oil change use an HD 30 WT oil. The oil drain plug is located in the center of the side of the engine crank case base. On the 5th Oil change switch back to SAE 30 WT oil. Oil brands are not really important. They all have to meet SAE the same standards to carry the label of SAE. (Yes you can use a generic 30 WT SAE oil )
Thanks for choosing FixYa,
Kelly
Dec 06, 2010 | Dewalt DPD3100 Gas Pressure Washer
What type of oil do i use in a dewalt 3800 pressure washer
in the enginge you can use a standard 4 stoke engine oil.
in the pump you can use hydraulic oil
Dec 05, 2010 | Dewalt 3800 PSI Pressure Washer
I would like to know if this pressure wahser use only gas or (Gas and Oil) is mixed?
If your engine has a place to put oil, then your power washer uses ordinary gasoline.
The only type engine that uses 2-cycle oil and gas mixture is engine that has no place to put oil.
Oil for pump comes half way up >>> pump uses SAE20 or SAE 30 non-detergent motor oil
Oil for engine comes half way up dip stick and uses 10-W30 motor oil
Oct 15, 2010 | Dewalt DPD3300 Commercial Pressure Washer
Dewalt Pressure washer keeps shutting off for no reason. plenty of gas and oil, water running to it. starts fine and as soon as I start spraying it shuts down.
Had a similar issue with my dewalt 4200 pw. Unit starting shutting off after spraying for about 5 min. Then difficult to restart, but would start again eventually only to shut down a few min later. Had new engine oil, new pump oil, good gas. I changed the spark plug and unit runs great again!
Aug 08, 2010 | Dewalt 3800 PSI Pressure Washer
Need to know type of oil DeWalt pressure washer 3800psi
Pump is specialty pump oil available at Home Depot. Engine is 10W 30 motor oil.
Mar 16, 2010 | Dewalt 3800 PSI Pressure Washer
Power washer not starting what type of oil to use dpd3100
10 w 30 for engine
10 w 30 and specify for [PUMP OIL]
ANY AUTO STORE
THANKS AND PLEASE RATE JJ505
Apr 11, 2009 | Dewalt DPD3100 Gas Pressure Washer
Garden Logo
229 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
