Question about Lands Phones
I wish to change the after hours call diversion options
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Lands Phones Master
  • 102,366 Answers
Step 1: Determine the make and model of your phone/answering machine.
Step 2: Repost your query, being sure to include the information from Step 1.
Posted on Oct 19, 2011
What other bikes monoshock will fit xj600 diversion 1998@
Hi, Stephen parts swapping is common with most motorcycles when it comes to interchangeable or compatible parts from one model with another the best thing to do is call your local Dealership Parts Department or a reputable independent shop. If your location is not near a shop then go online and find a parts catalog or "FICHE" and match part numbers depending on your criteria.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Rear Shock Replacement Options Page 17 XJRider com
monoshock backwards step
Yamaha XJ600 XJ600N 1995 1999 Workshop Repair Service Manual Download... $15
OEM parts for Yamaha
Yamaha Diversion XJ600N Owner Manual
Oct 21, 2017 | 1998 Yamaha XJ 600 Diversion S-N
1995 Yamaha XJ 900 Diversion fork oil capacity
Hi, Sharon for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha XJ 900 Diversion 97 03
Motorcycle Fork Oil Change Part 1
Yamaha 95 XJ900S Service Manual
Yamaha diversion 900 XJ900S Owner Manual
Jun 02, 2017 | 1995 Yamaha XJ 600 Diversion S-N
How do you shut off call devirter
This works on 99% of carriers. If this does not work on your carrier, give them a call and let them know what is going on to see if they have it set up differently; however, this is how all of the major carriers have it set up so it will most likely work.
To switch off Call Diversion, follow these instructions: To switch off"divert all calls" dial: #21# To switch off a diversion you've set up forcalls you don't manage to answer within 15 seconds dial: #61# To switch off a diversion you've set up when your phone is engaged dial: #67# http://www.optus.com.au/shop/support/answer/how-to-add-change-or-remove-call-diversions-mobile-phone?requestType=NormalRequest&id=1764&typeId=5
Dec 12, 2015 | Cell Phones
How hard is it to change out the gauge cluster on 1993 Yamaha XJ 600 Diversion S
Hi, David for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Yamaha XJ600S 1992 Service Manual
Yamaha XJ600S Diversion
Yamaha Diversion
Oct 20, 2017 | 1993 Yamaha XJ 600 Diversion S
2010 Yamaha XJ6 Diversion hard to downshift
Hi, Parker_marti and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. A loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
Intermittent Shifting Problem Technical Mechanical Problems
Motorcycle Message Board Motorcycle USA
2010 Yamaha XJ6F XJ600 Diversion Service Repair Manual Download Manuals... $10
Yamaha XJ6 Owner Manual
Jun 01, 2011 | 2010 Yamaha XJ6 Diversion
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
Hi! How often the engine oil change is needed on Yamaha XJ600S Diversion 1992
It depends on two things if your bike is used every day and does high speeds ,I would change your oil every 3000 to 4000 ,If your bike is in storage like winter .the engine will get affected by damp and if stored for long periods the oil should be changed before use ,
Mar 31, 2010 | 1994 Yamaha XJ 600 Diversion S
Takin off the dash lights on a 1995 yamaha xj600
Hi, Ctw2k4 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha 2009 Diversion XJ6S Service Manual
Yamaha XJ 600 Diversion 1995
Yamaha Diversion
Mar 01, 2010 | 1995 Yamaha XJ 600 Diversion S-N
Help, call waiting stopped working people sent to answer machine
You have set automatic call diversion to your 'message bank' or answering service when your line is busy for a preset time which may allow you to pick up this second call.
Unless you know the prodecures to change your telephone line options (which may be on the internet or via telephone key pad sequences), talk to your friendly telephone company help desk and ask them to reset your default to what you wish to do.
Hope it helps!
Dec 25, 2009 | Lands Phones
Yamaha Diversion 900 backfiring
carbs need stripping and cleaning then balancing. this should sort it.
Feb 16, 2009 | 2000 Triumph Trophy 900
Lands Phones Logo
18 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
