Question about Hitachi P50H401 50 in. Plasma HDTV
I connected my dvd player to my hdtv and its only in black and white. I have adjusted the settings numerous times and it isnt fixed. the cables are all in the right color matching holes..how do i fix this?
  • Hitachi Master
  • 8,457 Answers
Ur RCA AV component cable set might bad replace it with another RCA set of cable or tv have HDMI and also DVD player too for HD connection by a HDMI cable through HD hub?Buy and used a HDMI cable connect tv and DVD player to together one HDMI cable for a better functions.
Posted on Mar 21, 2011
My DVD is playing my videos in black and white .. It's a Panasonic tv model is tc-L32c5
follow the steps. God bless you
Insert a DVD lens-cleaning disc into your player and press "Play" to clean the DVD laser, eliminating picture problems due to read errors. Do not use a CD cleaning disc as the brushes on these discs can damage your laser.
  • 2 Wipe your DVDs clean of all visible marks and dirt using a lint-free cleaning cloth moistened with rubbing alcohol or glass cleaner. This further fixes read errors which can damage the quality of picture and sound.
  • 3 Disconnect your DVD player from the TV or receiver you have it connected to. Reconnect the DVD player directly to the "AV" or "Video In" port of your television, firmly pushing the plug into place, to eliminate possible noise from the receiver and ensure a clean connection.
  • 4 Connect your DVD player using an S-Video, component video or HDMI cable. Standard yellow/red/white RCA connectors cannot carry the high-quality signal that DVD discs are capable of transmitting, and will display a particularly poor picture on flat-screen high definition televisions. Use an HDMI cable, if your television and player support it, or a red/blue/green component video cable.
  • 5 Press "Setup" on your DVD remote and enter "Picture Settings." Make sure your DVD player is set to display images in the correct screen format ("Widescreen" or "16 x 9" for HDTV sets, "Standard" or "4 x 3" for older square sets) and scan mode. If you are using a DVD player that supports "Progressive Scan" on an HDTV or flat-screen set, activate this setting; for older sets, choose "Interlace" if given a choice.
  • Nov 14, 2012 | Televison & Video
    When u put a dvd in it shows coloured,but regular tv channels shows black and white
    Most likely the cable between the cable/satellite box and the tv is not fully home. Push all the connections firmly home and try it again.
    May 03, 2011 | Televison & Video
    Have a Magnavox (31YA--??) DVD/CD recorder/player which due to moving and busy, I have NEVER installed; and have at the same time lost the manual. HAVE PLENTY of cords to match colored terminals; but "S"...
    The S-Video "holes" the tv and the dvd player each have a S-Video.Hook it up with a one black video cable to the S-video to the hole in the tv and the other side to the S-Video in the dvd player.U have a RCA cable have 2 plugs lead each sides have 2 connections one RED,one White lead connections. Plug that RCA cable 2 connections in INPUT holes in the Tv ,and the other sides 2 connections one WHITE,ONE RED to the DVD player for sound.
    Apr 03, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
    DVD picture is in Black & White only.
    Are you trying to play an NTSC disc in a PAL player, If so,your player has a switch or
    on-screen setting to select the output format for NTSC discs,
    Or maybe you have connected one of the component outputs (Y, R-Y, or B-Y) of
    your DVD player to the composite input of your TV.
    Please rate this solution
    Jan 20, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
    Black and white images from dvd player
    after a lot of patience ,perseverance and switching around of numerous cables,we were able to rectify the problem.Now all is well.Thanks for your concern and for asking!
    Jan 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
    DVD's play in black and white
    anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from dvd player you have to connected to component input in the set.
    component signal will use green red and blue for video and red and white for sound.
    Jul 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
    Trying to connect sony dvd player to hdtv
    You will need some cables first. It's really not that difficult once you know what each cable does.
    Since you're only connecting from the DVD player to a receiver, this should be simple.
    There are 4 solutions depending on what cables you have.
    Composite - Yellow, Red, and White ended connectors.
    S-Video - Black 4-pin connectors.
    Component - Green, Blue, Red and sometimes extra Red, White for audio.
    HDMI - heavy cable with a wide/flat connector.
    Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
    S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
    Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
    HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
    Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
    If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
    I hope this helps.
    May 12, 2008 | Sony DVP-NS725P DVD Player
    DVD plays only in black and white
    Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
    HDTV:
    Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
    DVD:
    Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
    May 02, 2008 | Televison & Video
    No audio
    yeah sometimes we all get fustrated with stuff like that, the trick is not to hit the thing with a hammer,,
    any way ensure that yougot the cables connected propperly in the L/R audio output from the dvd player (RED AND WHITE its alo labeled) and connect it to the in in the tv..
    check your player settings (audio settings and and check your tv audio settings to ensure they match) some HDTV's only use 5.1 or higher
    if your dvd remote got a volume controll on it ensure the u\volume is all the way up and that it isnt muted.
    try your player on a next tv to ensure its working , if it is the problem is with your settings as stated above
    Jan 05, 2008 | RCA RC5510P DVD Player
    Black and White
    There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
    Apr 03, 2007 | Zenith C13A05LG 13" TV
    Hitachi P50H401 50 in. Plasma HDTV Logo
    108 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
