Question about Kenmore Refrigerators
Compressor does not start all I get is a clicking sound when it tries to start model#970-65832c purchase July 2004
    President:
  • 1,430 Answers
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at Refrigerator clicking for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine. All parts come with installation instructions. Not all models are available.
Posted on Mar 21, 2011
Sony kdsr60xbr1 problems
Hi, since 2006, you have replaced many parts, why don't you try replacing your TV with new advanced model. Your all problems will automatically fixed
Dec 30, 2013 | Televison & Video
..hi there!...My Whirpool fridge has stopped
yes if the clicking is coming from the compressor,change the start switch and the relay it comes in a kit,,,that should fix it....these parts are located on the left side of compressor,,please unplug unit before doing any repair..
Aug 29, 2011 | Whirlpool Refrigerators
Clicking noise coming from my fridge, why?
Depending on model number and location of noise I believe with any refrigerator that clicking will come from compressor overload when the compressor tries to start. Certain GE Models that fall into the category of Profile/Artica have motherboards that make the same clicking sounds when they go bad. If coming from compressor then it tells me that the compressor is trying to start. If so and the clicking continues the compressor could be damaged. If you need someone to assist you in repair I will gladly assist you. Sea Breeze
Mar 20, 2010 | GE Refrigerators
I have a Whirlpool Side by Side Refrigerator Model # ED25PQXFW01. It makes a clicking noise about every 2 minutes almost sounds like the compressor isn't turning off and the food is defrosting in frig and...
Clicking sound is the protective overload mounted on the side of the compresser to shut the power to the compressor off, should it be unable to start.
After cooling down, it will repeat to try to allow the compressor to start.
Two possibilities.
1. The start components for the compressor are mounted on the side of the compressor and include the protective overload. The parts here are A.the start relay(two styles solid state or current type), B.on some but not all models a start/run capacitor, and C. The overload that you hear clicking. To test these components, you will need a knowledge of electical and ability to use a VOM meter. If you lack these qualifications take them to an appliance parts house and in most cases they will test them for you.
2. Compressor failed. To be totally safe, this test should be performed by a qualified tech.
Compressors carry a 5 year warrant from date of sale, and if the extended warranty is purchased. 10 years.
To allow yourself the most accurate responses in the future on any device you might need help, it is best you start by giving the age of the device. If you don't know, best guess will do.
Oct 25, 2009 | Refrigerators
Refrigerator still makes clicking sound and does not cool after bad start relay was replaced
Couple Video How To Replace Compressors. I Think Its Not DIY.
Hope Thats Helps.
Aug 12, 2009 | Refrigerators
Loud vibrating sound with compressor starts up
remove the back cover and visually inspect the small fan under the fridge, chances are the fan or blade has become unbalanced or the mount has come loose or failed.
Jul 12, 2009 | GE Refrigerators
Compressor won't turn on
Have you checked for a breaker on the unit? it would be out of sight but assessable and look like a small switch.
Apr 02, 2009 | Air Tools & Compressors
Refrigerator not cooling
the most likely problem will be the start relay for the compressor. the clicking noise is the compressor trying to start and then the relay cycles back off. the part number is 8201786 and can be purchased from any loal appliance parts house thru sears.com or any othe online parts source. the kit comes with good instructions so you should be able to repair yourself.
it would be a good idea to unplug the refrig until you get it repaired to prevent possible compressor damage. thanks peyton..
Feb 22, 2009 | Kenmore 53532 / 53534 Side by Side...
Refrigerators Logo
266 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
