Question about Alpine CHA-1214 12-Disc CD Changer
Cd changer works but while in use locks volume at one setting. cant turn it up or down
  • 1 more comment
  • MARK LOVELL Mar 22, 2011
    The volume works perfectly when not in cd changer mode. Once in cd changer mode about 3 speakers dont produce sound that do when not in that mode and the volume on the head unit stays at med-low. volume control shows 1-30 and will increase or decrease when you turn the knob but does not change the actual volume level while in this mode. hope this clarify's more clearly
    WHEN YOU SAY UNIT DO YOU MEAN THE STEREO HEAD OR THE CHANGER.....
    ok... i will get my son to check for dust. but...........how do you reset the system... he is running a alpine head unit that works perfectly when not in changer mode. also there is a cd stuck in the stereo itself. he was afraid to try to get it out so he bought the cd changer. could the stuck cd also have something to do with it. i must say again though the stereo works great in all modes even playing the cd that is stuck. it is just when he goes to the changer mode. so i will get him to remove the stuck cd from the stereo, look for dust in the changer itself and blow it out with canned air and then with your direction on your next reply tell me how to reset the system. i know there is a reset on the stereo.... is there one on the cd changer???
    Guru:
  • 1,833 Answers
According to you the sound controller doesn't work while your player is in changer. Look It may happens for the CD changer may stuck with internal volume control unit. Dust also may probable cause for this problem. So first clear the dust. You can open the top panel to check if there is problem in sound controller unit. If can't find any problem then Reset the total system, it may solve your problem.
Posted on Mar 22, 2011
  • Aloke Das Mar 22, 2011
    To reset the system you should follow the owner's manual.
    President:
  • 1,768 Answers
Your unit is in need of service or replacement.
1. the logic controller on the main board is failing and is possible due to a regulator or filter circuit or infrared receiving circuit . Cannot be diagnosed here>
2. an electronic technician need to repair it.
  • Harleen Nash Mar 22, 2011
    If the controller is in the Stereo head then that will need service.
    logic to the cd changer is controlled by a programmed logic.
    They work in tandem with response from a remote signal sent to the controller that has a infrared receiver.
  • 5,370 Answers
Is the volume very low or very hight./Also every time you turn off then turn ON the unit.Does the volume gets stuck on the same setting.Or it stuck at low or high volume.May be its possible that volume control button is got loose and its actually not functioning.Its just got loose from the cd changer unit.Press the button bit hard or spin the button by pressing it hard. Check the volume control button.------------Keep updated,.Thanks.Helpmech.
Posted on Mar 21, 2011
I cant hear the music very well... it is very faint and i have my speakers plugged in. how do i turn up the volume? i cant find any buttons to do so.
CD changers don't normally drive speakers (the lack of a volume control and speaker connections being a HUGE clue). What are you using for a speaker amplifier?
Sep 18, 2011 | Kenwood CD-223M 200-Disc CD Changer
Cant get the clock to set
most you hold down the time button and push up or down. try something similiar, hold down a button and push an up button? just play with it but don't reset it andcause more problems
Jun 01, 2009 | Pioneer DEH-245 CD Changer
Sony radio cdxgt210
Use the main control knob. The one that turns your volume up and down. If you press it in it should go through bass, treble, fade, balance, and sub. Then use that same knob to adjust it by turning it left or right.
Jan 20, 2009 | Car Audio & Video
Hi i have a older cdx-65 cd changer
IT WILL NEED A SERVICE, POSSIBLE THAT ONE OF THE SWITCHES IS FAULTY
oops caps lock was on sorry :)
Mark
www.blueice-electronics.co.uk
Nov 04, 2008 | Sony CDX-656 10-Disc CD Changer
Mutant mt2000 car cd radio
PRESS THE DISPLAY BUTTON AND HOLD DOWN THE CLOCK WILL FLASH TURN THE VOLUME KNOB RIGHT TO CHANGE THE MINUTES AND LEFT TO CHANGE THE HOURS THN PRESS DISPLAY AGAIN AND ITS SET
Feb 17, 2008 | Car Audio & Video
DEH 245 Lights
Try Turning the Power off holding down the clock button till the clock display flashes then use the volume and tuner keys to set the time.
Dec 17, 2007 | Pioneer DEH-245 CD Changer
Denon UD-M50 amp/3 cd changer
The tact switch behind the panel is being pushed in by a defective front panel button, the small switch is bad behind the button, or the volume control IC is bad. Good Luck
Aug 11, 2007 | Denon DCM-35 CD Player
Volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark www.carradiospares.co.uk
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
Nakamichi cd-35z
There is adjustment for bass, mid and treble. Access this by pressing the button to the right of the volume knob. I leave mine set at +1/2, -3, +2 . I also set LOUD on which is done by holding the same button down. With these settings everything sounds pretty spot on, occasionally need to adjust the bass up/down and treble dependant upon the CD.
Mar 09, 2007 | Nakamichi CD-35z CD Changer
Alpine CHA-1214 12-Disc CD Changer Logo
60 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
