Question about Garden
When blade are engaged on my ct172 husqvarna ride on lawnmower nothing happens
5 Suggested Answers
  • 634 Answers
SOURCE: I have Husqvarna yth2148 riding lawnmower belt
goto husq site and type in model ect and should give parts and diagram
Posted on Jul 06, 2009
  • 168 Answers
SOURCE: i have a husqvarna 172 ride-on lawnmower. Running
This unit probably has a safety switch built into it and it could be below the gas tank. If this switch isn't adjusted properly then it's designed to cut off the motor. I think you should concentrate on that before attempting anything else.
Posted on Aug 02, 2009
heres2maine
  • 84 Answers
SOURCE: Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Posted on Apr 15, 2010
  • 146 Answers
SOURCE: When engaging the blade for my Husqvarna riding
It's possible the repair folks didn't properly reinstall the mower deck belt. Check that it's in place, and under good tension. If that's OK, look at the wires to the mower engagement switch (PTO switch) and make sure the connections are on tight. Then check the motor pulley where the PTO clutch is, making sure those wires still in place.
Posted on Jun 10, 2010
Husqvarna Riding Mower when turn lever blade will not engage.
If the engagement is done by lever, yes it is controlled by cable. It could be disconnected or the cable could be broken.
Oct 29, 2016 | Husqvarna Garden
Jim, I believe your tractor has an electronic knob for engagement (if I'm right in you having a matching post about a husqvarna with a knob for engagement. And it also has a PTO clutch off the motor. Having a little slack in the belt is not bad if it's not so much that it doesn't grab at at all. Does anything happen at all when you pull the switch? If nothing happens at all, the switch could be bad, the PTO clutch could need adjustment or be bad, OR you may simply have a very weak battery that isn't supplying enough current to engage the PTO properly under loads. Sometimes the batteries and charging units in riding mowers are very borderline in being able to handle the loads and a weak battery can cause unsuspected problems.
Aug 10, 2013 | Garden
My Husqvarna riding mower won't start. I was
Check to see if you left the blades engaged. There is a safety switch that prevents starting with blades engaged. Easy to miss, happened to a friend of mine last month.
If this really helpful, please rate.
Jul 11, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
When engaging the blade for my Husqvarna riding mower, nothing happens. I recently had the mandrel assembly replaced for the left blade, and this is the first time I've tried to start it up.
Jun 10, 2010 | Husqvarna 165HP 42" Lawn Tractor
Yth2448 riding lawnmower blades will not disengage
My craftsman lawn mower will not engage the blades
Jun 08, 2010 | Husqvarna Garden
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have an A680L John deere riding lawnmower. The transmission does not seem to engage. It burns the belts.
Burning belts sounds like something is locked up. Make sure there's nothing wrapped around any of the blades and that they turn freely.
Sep 09, 2009 | Swisher 52" 20 Hp Riding Lawnmower #Zt2052
I have a husqvarna 172 ride-on lawnmower. Running
Aug 02, 2009 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
