Question about Admiral Washing Machines
While agitating, the washer continues to fill, then causing an over flow issue.
    Brigadier General:
  • 6,277 Answers
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Posted on Mar 21, 2011
Whirlpool washer fills sometimes and won't agitate or spin or drain what should i do
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Jul 24, 2014 | Whirlpool Washing Machines
Ftf2140fs1 water fills up tub and over flows with door open when not using it
Hi Greg Meigs - If your washer will not stop filling up with water and overflows the tub, check for one of these problems:
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off and on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
2) There could be a problem with the water level switch. Call in a professional.
3) There is a pressure switch hose that is attached to an air dome. This switch tells the washer that there is water in the tub and allows the agitator to start.
- Remove the control panel and you will notice a small hose. See if it popped off of the air dome. If it did, secure it with a zip tie.
If water flow continues, but drains out immediately, then raise the drain hose above the highest water level line of the tub. Do not seal the drain hose to the discharge pipe. This could cause a siphoning action.
Nov 13, 2012 | Frigidaire GLTF2940ES Front Load Washer
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Sep 30, 2012 | Roper Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
Agitating to many times
Have you verified that you do not have a siphoning condition? The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Please double check the installation and placement of your drain hose. If the top of the standpipe is sealed off, or if the drain hose is shoved too far down into the standpipe, this can create a vacuum. This can cause the washer to constantly siphon out of the wash tub on the fill cycle and the washer will continue to fill (as needed) to maintain the water level. In other words, what may appear to be a significant problem, can be something as simple as a simple placement issue with the drain hose.
If you have further questions, please let me know. If the diagnosis is not correct, please post back and also let me know, so that I may be able to assist you further. I hope this helps you.
Jan 19, 2009 | Frigidaire GLWS1649A Top Load Washer
Washer filling over and over
Check the placement of your drain hose. This may be a simple issue of siphoning. The following link explains:
Make sure you have a sufficient air gap at the top of the drain stand pipe, and that the drain hose is not placed in the standpipe too deep. This can cause the water to constantly siphon out of the wash tub and the washer will continue to fill to try to maintain the water level.
Please let me know if you have questions, or if you require additional assistance. I hope this helps you.
Maytag washer PAV2300 water over flow
from what I am reading on-line, it is the mix valve, aka water valve. Unplug the washer, then see if it still fills. If so, it's most likely stuck open, and needs to be replaced. about $22.00
Feb 21, 2008 | Washing Machines
I had the same problem and went out to a website for Maytag washers. That website advised that the problem could be mechanical or electrical. In my case, the problem was a clogged tube and it took only ten or fifteen minutes to fix.
0. Unplug the machine.
1. Open up the front of the washer. Along the left hand side is a long transparent tube. The tube connects to a wallet size container on the side and near the bottom of the tub.
2. Inspect the transparent tube. It may be clogged where the tube meets the wallet sided container.
Note: When the tub is full, it creates pressure in that wallet size compartment which sends air up that tube to a pressure switch located within the panel at the top of the washer. The pressure switch flips and tells the machine - stop filling the tub with water. My machine had a visible clog in the bottom of the tube that carries the air from the bottom of the tub up to the pressure switch.
3. Disconnect the tube and clean. I used a pipecleaner to get most of the mold out. To completely clear the tube, remove the top panel and disconnect the tube from the pressure switch in the top panel and blow air down the tube.
4. Reconnect, test - and you should be good to go. If not, your pressure switch may be dead.
Dec 05, 2007 | GE Profile WPSR3120WWW
tidalwave If the water continues to flow even when the washer timer and the power to the washer are off then you are right and the water inlet valve has to be replaced. If it does it only when the washer is on then it could be different problems. In that case the first thing you have to check is the water level switch. This is the device which controls the water level. Remove the power first.Open the control panel and you will see the switch on the left side. There is the clear plastic hose connected to the switch. Make sure the hose is not loose. This is one of the most common cause of overflow. If it got loose, drain out all water from the washer before you reconnect the hose. If this is not the issue then you have to check the continuity across the water level switch therminals. When there is no water you should measure the continuity across therminals 11 and 12 (gray and orange wires). Whet the tub has filled up with water you should measure the continuity across therminals 11 and 14 (gray and light blue wires). If the continuity is wrong replace the water level switch. If you are going to do it, make sure there is no water in the tub before you will remove the clear plastic hose from the old switch. Good luck. Gendos. post back...
Jul 07, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
