Question about Sony Playstation 3 (PS3) Console
When i turn it on the green light turns yellow whats going on
    Filmmaker:
    Uploaded 5 video answers.
  • 84 Answers
You have what is called the 'Yellow Light of Death', this means that there is something wrong with your console and it must be sent in for repairs. You should contact Sony immediately and find out if your console is still under warranty. If it is not, chances are it will cost you around $150 to get it fixed. Information about who to contact and what is covered under the warranty can be found here (http://us.playstation.com/support/warranties/ps3/).
Posted on Mar 21, 2011
My playstaion 3 light turns green then yellow and turns off after what do i do to fix it
That is more than likely the PS3's Yellow light of death (YLOD) It is actually an easy fix if you know what to look for. Check out Youtube for videos how to fix.
Aug 06, 2014 | Sony Playstation 3 (PS3) Console
Rear harness was bad they replaced with trailer harness and trying to fig out what yellow brown light green an dark green are on frame of truck it hooked in to so i can fix i un hooked not knowing what had...
Your description, I take it, is a problem with the wiring harness going from the driver's compartment to the rear lights. If that is the case, the normal color code for GM is brown for tail lights, dark green for the right stop & turn, yellow for the left stop & turn and light green for the backup lights. Any black wires should be grounded. The white wire in the trailer harness is for a ground when used on a trailer. It sounds like you have the green and yellow T&S wires shorted together somewhere! Some of the later vehicles use separate stop and turn bulbs... these would have a separate wire for the stop lights only, but I don't think your truck is new enough for that. Good luck!
Nov 25, 2013 | 1993 GMC Sierra
When my PS3 is turned on green light comes on then is goes to yellow then red light flashes. What can I do?
When the green light is on then GO, if the yellow is on SLOW DOWN, and if it is red STOP.
Dec 23, 2010 | Sony PlayStation® 3 (80GB) Console
When turned on the light on the front panel go from green to yellow and then shut down
The game was already turned on. simply turned it off. turn it on once more with the same buttons, should display red yellow and green.
Dec 02, 2010 | Sony Playstation 3 (PS3) Console
How to wire a towbar to a renault laguna ? what
If you have the Renault end, I've got the rest. I have the pinouts for 7 wire, 6 Wire and 4 Wire, One of them will fit the bill
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Blue = Electric2_bing.gif Brakes - 2
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery2_bing.gif, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
A test light and a 12VDC power source can be handy for trouble shooting
Best regards
Aug 14, 2010 | 2007 Renault R18
95 ford f250 trailer wiring trouble what does each wire work and what color
The basic 4-flat trailer wiring colors are as follows.
Yellow-Left turn/Stop, Green- Right turn/Stop, Brown-Running Lights and White-Ground
7-way trailer wiring colors are as follows.
Yellow-Left turn/Stop, Green- Right turn/Stop, Brown-Running Lights, White-Ground, Red or Black-auxiliary power, Blue-Trailer Brakes and Purple-Reverse lights
Jan 15, 2010 | 1995 Ford F250
Looking for a wiring diagram for a 2006 Ford Expedition
7way- black is 12volt (power), brown, running lights, yellow is left turn signal and stop light, green is right turn signal and stop light, white is ground, blue is brakes, and orange is aux power (can be back up lights, if trailer equipped w/ them). 6way is the same, minus orange wire. I have run into some variations to the above color codes (brown, yellow and green only-sometimes these 3 are different than stated, but only mixed as that group, as to what they control- example would be green is running lights, brown and yellow are turn signal and stop lights, the others should be as stated), if you have any trouble with things not working properly, it may be due to these variations, although the above are pretty standard. If you have an ohm meter you can check as you go (check for power at black wire- should be constant 12v, turn on turn signal and check for power-it will fluctuate from approx. 12 volts to 0 volts as the signal power pulses in the wire) hit the brakes, blue wire should show power, etc. Let me know if you need more help as you go.
Apr 11, 2009 | 2006 Ford Expedition
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
What does the yellow light mean?
when the light changes to yellow it is just adjusting to the newly added water. If you let it run the light should turn back to green. I think the light is only indicative of water level. I've had this humidifier for over a year and only gotten a yellow light once. It turned green after some of the water in the basin drained. Hope this helps
Dec 13, 2008 | Crane Cow Humidifier
Sony Playstation 3 (PS3) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
