Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Changed stk110s but still seeing double
What do converge resitors look like,and how do i know if they are bad ?
  • Panasonic Master
  • 8,617 Answers
You will have to unsolder the resistor and lift one side out of circuit. The convergence resistors are usually located right next to the Ics and there should be nummerous that are all identical with the same color bands or markings.
Posted on Aug 03, 2008
Jvc av-48wp30 blue to align convergence
Tv colors R,G,B don't alignment any colors.Tv have a convergence problems,it dead.Tv convergence board require changes 2 STK convergence ICS and some or all it resitors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 11, 2010 | JVC AV-48WP30 48" Rear Projection...
My picture from comcast is very blury almost as if there is a bad connection but there is not. Any idea on what it could be
Convergence is dead.U know how to solders?Must replaced the 2 Convergence ICS,and all it resitors.Buy a convergence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost U 300 for parts and labors.
Feb 04, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Color convergance will not manually adjust, what could be wrong with my set?
Convergence it dead,require change two convergence ICS and all it resitors.Know how to solders.Tries Tv repair World.com,Tvrepairkitscom for the convergence to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 03, 2010 | Toshiba 42H83 42" Rear Projection...
My zenith convergence wont turn on
Hi, thank you for visit fixya.
Do you have shadows on picture? ( like double image). So,
Do you have problems with convergence deflection board.
Replace STK 392-120 (2) and resitors around STK IC's.
Any question I will be here.
Thank you
Nov 28, 2009 | Zenith R57W46 57" Rear Projection...
Convergence problem with 53tw53tg
did you check the convergence feed resistors? its not uncommon for a few of those to go open when the ICs go out.
Aug 03, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Convergence problem
I can't imagine how you would have enough electrical contact on the STK110s without soldering them in place, so I would think you need to solder them before testing further. Running the TV without them soldered in place and properly heat-sinked could cause additional damage to the TV and/or other components.
Aug 02, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Seeing double
need to replace the convergence ICs and possibly the convergence resitors . You need STK392-110 ICs you can get the ICs and the convergence resiistor kit for your model at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Jul 28, 2008 | JVC AV-48WP74 48" Rear Projection...
Convergence
Did you check the resitors out of circuit? As its very rare when a Hitachi doesnt open at least two on the affected circuit. If you checked the resistors in circuit an open resitor will read good even though its actually open.
Jul 08, 2008 | Hitachi 46F500 46" Rear Projection...
Convergence
Nana
Look under the chassis on the bottom right side. I found a sheet that describe most of the componet values
Good luck
Sep 26, 2007 | Televison & Video
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
