Question about Solis Master 5000 Espresso Machine
Power surge has burnt out the capacitor where can I find a replacement
  • 6,993 Answers
You can buy capacitors at any Fry's or Radioshack store within your vicinity or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
Make sure you remove the old capacity and use it a sample to get the replacement so that you will get exacyly the same capacitor.
Good luck.
Posted on Mar 21, 2011
A power surge zapped my TV, I turned it back on, it tried to bring up the picture but shut off again. A green light keeps blinking.
if a power surge shut down the unit than a circuit, capacitor or fuse is blown and or burnt and you wont smell that most of the time and since it does have power fuse wasnt blown so a circuit -diode-capacitor is fried somewhere problem is common for an electricial damaged tv but to diagnose an electronic tech would need to tear it apart
Aug 26, 2015 | Sharp Aquos Televison & Video
Burnt by power surge
Any type of power surge most certainly took out the Power board for sure and possibly the main board too depending on the type of power surge. You can get replacement boards from www.tvcircuitboards.com
Nov 04, 2012 | Televison & Video
I have a 2000 36' Winnebago Adventure that got a power surge and burnt out the circuit board and capacitor in the coleman Central Mach ac and Furnace can someone send me in the right direction for
Check here and find your service manual as well as parts. If not 100% sure on what you need, call, or e-mail them, or get back to me with more info on who diagnosed problem, and more on symptoms you are experiencing.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Sep 13, 2012 | Coleman Heating & Cooling
Screen wont stay on when power button is pushed
Get a surge protector.
More than likely a surge caused it.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
May 11, 2010 | HP 2009M Monitor
Chamberlain GDO Model# 41A3519-1 Power surge blew .01M capacitor next to light relay. Can I successfully test 4.5VDC transformer in-circuit?
the keypad intermittently does not function. will waitt several minutes between coding and it still doesn't functioon. however, when trying to troubleshoot, the keypad functions normally. Any ideas???
stevie
Feb 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Describe your Kenmore 53652 / 53654 / 53659 Side by Side Refrigerator Unit is not cooling. Stopped working after power outage
Kenmore Coldspot 106.53652300
I just fixed my neighbors fridge that suffered from a power surge. She explained that she smelt a burning smell in the kitchen and the next day the fridge and freezer were not cold. Of course she did not share the burnt smell part until after I discovered the starter relay and the capacitor were burnt on the compressor. She purchased the new starter kit and capacitor from a local supply company and while installing them I discovered the compressor fan was not running which also meant the compressor was not getting any power. I removed the screws that held the control panel on the fridge side (right side) and inspected the circuit board which I discovered a burnt trace on the board for the compressor control relay. I fixed the board by soldering a piece of solid core wire across it and it works great!
Make sure you shop around for your parts. The BIG local supplier here in Tulsa wanted $65 for the starter kit and $65 for the capacitor. We shopped around and found another supplier in Tulsa that sold them for $25 each and they were FSP parts!
Dec 15, 2009 | Kenmore 53652 / 53654 / 53659 Side by Side...
TV repeatedly turns off after 3-4 seconds
Disconnect all the cables from the TV including the power cord. Make sure that the power cord from the TV is not connected to a power surge protector.
Connect the power cord to the TV after few hours and turn it ON to check if it's working normally. Also, you may try resetting the TV to the original factory settings.
If the issue persists then the problem is related to the main power board and it's required to check and replace any burnt out capacitors.
Dec 01, 2009 | Insignia LCDTV26 26 in. Television
Have lcd tv samsung. Had a power surge now tv will turn on but no picture or sound. What could be the problem?.
If you get no standby light or error blinks, the power supply board is bad. Most likely the power surge will take out some capacitors on the power supply. Replace the power supply board to solve the problem. This is a common failure caused by a power surge.
Note: If you are looking to do it the cheap way, you could try looking for bad capacitors (visually inspect for ones that look "bubbly") and replacing just those but it is not guaranteed to fix the TV as the power supply could have other issues and just cause the capacitors to bubble again.
Oct 08, 2009 | Televison & Video
3 speed Recirculation pump lost middle speed
It sounds like you might have had a power surge and burnt the windings on the medium speed. If it is bothersome, you will need to replace either the motor or the whole pump. (not sure if replacing just the motor is an option.)
Mar 05, 2009 | Grundfos RCP-96 Recirculation Pump for...
Envision 9410e monitor only display for a second.
Hi...there,
It's seems you got unlucky...your backlight inverter got burnt...Need to replaced a new one or repaired it. Caps it a fuse look like a tiny battery that power the backlight...
Nov 30, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Solis Master 5000 Espresso Machine Logo
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
