Question about Vizio 42 in. LCD TV
Sometimes when you turn it off, you cannot turn it back on without first unplugging it and plugging it back in.
  • Vizio Master
  • 8,457 Answers
Take the tv back cover aparts.Check the tv power supply board,that the board where the power a/c cord plug into it.U have all the tools and know basic soldering and electronic?Yes.Check for dying capacitors parts,like for bulging up or puffing up on it tops.These capacitors parts are the causes and it dying.By replacing these capactors and put the same capacitors,but with 5 or 10 voltages higher for better functions.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Mar 21, 2011
Toshiba Qosmio G55-q802 won't boot power light blinking orange
Something I found with a search:
Try the following and see if it will turn on.
1. First make sure the device has been charged.
2. Unplug your charger cord.
3. Remove the battery.
4. Press and hold the "Power" button for 30 seconds and see if the device will turn on.
5. If it does, great, now plug back in the power/charger cord. (If it didn't turn on without the cord in, it should turn on once you it is in. Yes sometimes they will turn on, or try to turn on, even with nothing attached/plugged in.)
6. Now put the battery back in.
Apr 27, 2018 | Toshiba Computers & Internet
Turn on without remote control
If the TV was switched OFF by remote control for the last time, you can't switch it back ON, without its remote control.
Just try this. Unplug the TV from AC mains wall socket. Wait for at least 5 minutes and plug it back. Switch it ON by its front panel power ON/OFF switch. Just press any button [Ch UP / Ch DN or Vol UP / Vol DN] Sometimes this might turn ON your TV.
Jun 02, 2012 | Televison & Video
Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
My Mitsubishi WD-52725 will turn off while watching and the lamp led will go red. It will sometimes come back on without unplugging and sometimes you must unplug wait 2 minutes and the plug back in. I...
Thats a common symptom of when the power board capacitors fail. It will make the lamp light turn red and a self diagnosis 34 for lamp abnormality. Usually install the power board repair kit will solve that issue. Heres a link to the power board repair kit for your model. The kit contains the capacitors and detailed instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jul 11, 2009 | Mitsubishi WD-52725 52". Rear Projection...
My toshiba laptop won't turn on!
Place the battery back in and the power cord. Follow the power cord all the way to the plug and verify nothing was unplugged by accident. (the box on the plug sometimes disconnects without the user knowing it) This could have caused your lack of power. Hope this helps.
May 09, 2009 | Computers & Internet
Magnovox HD2763C401 dead sometimes
MINE STARTED DOING THE SAME THING RECENTLY BUT HAS WORKED WITHOUT A GLICHE FOR 22 YEARS
Oct 30, 2008 | Philips Magnavox 27MS343S 27" TV
When i unplug my tv and plug it back it wont turn on, and after many tries of plugging and unplugging sometimes it turns on
Do you have a wall switch on that receptacle , maybe , just maybe, somebody is playing games with ya ...lol...
Oct 12, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Ge 46 inch projection tv
Turn your set on. While it is on unplug the power cord. Let it sit for about 5 minutes and then plug it back in. If the set comes on without turning it on you did not leave it unplugged long enough. If you you have to hit the power buttom to get the set to come on you will likely have sound. Sometimes you will have to go into the menu and turn your speakers back on. Also a satelitte reciever or cable bax can do the same thing. Usually you can unplug them for about 30 seconds and then plug them back in and turn them on to correct the problem if they are the cause.
Feb 01, 2008 | GE 46GW 948 46" Rear Projection Television
Won`t turn on
Try leaving it unplugged for longer period of time. Look on the remote for any possible reset function. Try power button without the remote. If any ot these doesn't work there is a power supply module inside that malfunctioned. If under warranty contact where you purchased it. If not under warranty if you can get the module it is a simple plug up procedure.
Dec 31, 2007 | LG 42LC7D-UB Television
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
