Question about Panasonic PT-AE2000U Projector
I have an panasonic pt-ae2000e projector, how do i get sound?
  • 442 Answers
The sound must be sent to an external amplifier system and speakers.
Audio cables must be connected from each peripheral device directly to the audio reproduction system
Posted on Mar 29, 2011
Projector will not switch between eco and normal modes
Hi imustafa
Sounds like the lamp may be on its way out... at least is low on output.
May 05, 2008 | Panasonic PT-AE700U Multimedia Projector
Tip
Panasonic TYLA1001 Manual Lamp Replacement Instructions Models No. PT-52LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Are you missing the Installation Instructions for your Panasonic TYLA1001 Replacement Projector Lamp?
A digital, pdf version of the TYLA1001 Lamp Replacement Instructions can be downloaded from here.
Once installed, reset the lamp timer of your Panasonic Multimedia Projection HDTV by following these steps.
I hope that helps.
on Apr 11, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
I'm am new at this forum. Please help. I've
Check first if/that all connections are connected as the should be. That in order go to the menu on your tv. Go to picture and adjust the brightness. K
Dec 23, 2017 | Panasonic PT-AE3000U LCD Projector
Do you have a diagram for where the iris is on the Panasonic PT-AE900U projector? we are trying to repair a grumleing sound
http://www.scribd.com/doc/44911427/AE900-servicemanual Check that link. Page 22 on the document details how to remove the Iris unit, including a picture diagram on how to remove the unit. Hope this helps.
Mar 06, 2011 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT LB50NTU - LCD projector need to connect to my IMAC - what cord do I need?
The Panasonic projector PT-LB50NTU or E have two type of data inputs.
One is RGB or VGA cable and second is VIDEO cable. If your IMAC have video or vga output than you can connect.
Two type of cables witch are using with projector good_help_0.jpggood_help_1.jpg
Jan 14, 2011 | Panasonic PT-LB50U Multimedia Projector
Panasonic PT-AE2000U All three HDMI Ports stoped working. I have tried different HDMI cable and a three different HDMI Feeds. I can get a picture using the red green blue component cable. Any ideas?
WOW. I just experienced the same thing. None of my HDMI ports are working, though component is fine. I've had my unit since November 2007 and had no problems until this. I think the HDMI board has gone bad and will require replacing.
May 20, 2010 | Panasonic PT-AE2000U Projector
Have panasonic pt l701u projector using RCA input can't get picture can get sound. Tried changing settings and it didn't help.
Pleeaes connect Rca cable in Yellow port for video and white port for audio.
Also check input settings in projector Menu. it should be "video".
For your ref, diagram is below
Thanks,
Mar 25, 2010 | Panasonic PT L701U Multimedia Projector
Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Open Questions:
See all Panasonic PT-AE2000U Projector Questions
Panasonic PT-AE2000U Projector Logo
141 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
